Re: Hemi or Wedge
[Re: Hemicuda7]
#2323836
06/19/17 09:33 PM
06/19/17 09:33 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
How fast do you want to go? I've made more HP per C.I. on my N/A wedge builds than on any N/A Hemi build 1000 HP on a wedge shouldn't be hard with a good race block and a good set of B1-MC or Predator heads I've built one 542 C.I. B1 bracket motor that made 920 HP pretty easy with a non max tuned carb. :shruggy My next bracket motor for myself will be set up for either E85 or straight Alky with a set of B1-MC heads on a Koleno 4.500 bore block with a 4.375 stroke crankshaft(555 C.I., I think) with BB Chevy rod journals I'm expecting north of 1000 HP on that motor using one of those fuels My 2750 lb.(with me in it) tube chassis bracket 1970 Cuda has gone 9.00 @ 147.+ MPH with a mild 505 C.I. bracket motor on E85 with a set of non ported Eddy Victor M.W. heads with a Mikes Monster glide and a 9 inch Continental converter built for a lot bigger higher H.P motor that was in the car before I bought it without the motor, it came with that trans and converter.
Re: Hemi or Wedge
[Re: Hemicuda7]
#2324061
06/20/17 10:34 AM
06/20/17 10:34 AM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
The hemi will be 2 or 3 grand more expensive I bet than a comparable wedge. One will not require any more maintenance than the other as long as you buy quality parts...mainly valvetrain.
I'd absolutely run a powerglide...behind either motor.
Re: Hemi or Wedge
[Re: hemi-itis]
#2324541
06/21/17 04:05 AM
06/21/17 04:05 AM
Cab_Burge
HEMI.........either you have one or you want one............ I've had five or six and built a bunch more for other people, that is one of the reasons I call them Hemiroids motors I built a new pump gas street blown Hemi Mega block that was 4.310 x 4.250 with a Littlefield 10:70 street blower and a pair of Carb Shop blower Dominator carbs, it made 924 HP at 7300 RPM on CA pump swill making 7.0 lbs of boost, we change it to race gas and change the pulleys form 12% underiven to 13 % over drive which raised the boost to 12.0 lbs at 6500 RPM making 1027 HP and then went into detonation I built a bracket 542 C.I. B1 motor with a single Dominator carb. with right at 13.0 to 1 compression ratio that made 920 HP 6500 RPM on 110 octane race gas not tuned up My message is there are more than one way to make good power with Mopar BB motors
Re: Hemi or Wedge
[Re: Hemicuda7]
#2324596
06/21/17 10:42 AM
06/21/17 10:42 AM
Posts: 4,209 New York
polyspheric
New York
RB + Procharger = cheap power, far fewer $$$ parts. Remember: as Larry Widmer says, "RPM" means "ruins people's motors"
Boffin Emeritus
Re: Hemi or Wedge
[Re: gsmopar]
#2324619
06/21/17 11:45 AM
06/21/17 11:45 AM
Posts: 3,097 back in Georgia
dthemi
back in Georgia
I'd agree, and I do so love a hemi.
The best head we have available at present, in my opinion, is Predator. I think you'd have to pull off a plug wire to get down to a thousand with a good set of predators.
A hemi is the same money until you buy rocker arms. A good set is double the cost of good wedge rockers. Go for the top line rockers and you'll spend 4-5 thousand. I don't think I spent 5g's, but I'll check my receipt: The T+Ds are great rockers for sure, and what i run the most of, but not the best rockers for a hemi. Buck up for Jesel with tool steel exhaust, and 5G will vanish before you can crank it.
Re: Hemi or Wedge
[Re: polyspheric]
#2324625
06/21/17 11:56 AM
06/21/17 11:56 AM
an8sec70cuda
RB + Procharger = cheap power, far fewer $$$ parts. No, not really. Prochargers aren't cheap by any means. No cheaper than an equivalent nitrous motor or roots blown combo to make the same power. No cheaper than a N/A combo either depending on what power level we're referring to. The cheap/fast/reliable saying comes to mind here. Pick 2 and ride w/ it.
Re: Hemi or Wedge
[Re: Hemicuda7]
#2324637
06/21/17 12:14 PM
06/21/17 12:14 PM
Posts: 19,376 Las Vegas
Al_Alguire
Las Vegas
I have done both the Hemi and Wedge in a tube chassis 68 Barracuda. IMO a wedge based deal is the way to go, if for no other reason weight, and the aforementioned cost of rockers. I have had a few 1000+HP Wedge head deals. We currently have 2 B1's and a Predator. FWIW my 525" B1 in my Cuda went 171 at 2975.
Re: Hemi or Wedge
[Re: Hemicuda7]
#2324783
06/21/17 03:47 PM
06/21/17 03:47 PM
polyspheric
New York
Nitrous "mistakes" tend to be just that tiny bit more expensive... like taking out the whole car. Prochargers fit under the hood, and don't blow up.
My street car is turbo because it's factory, but it's a lot of work if you have no support.
Boffin Emeritus
Re: Hemi or Wedge
[Re: polyspheric]
#2324798
06/21/17 04:12 PM
06/21/17 04:12 PM
an8sec70cuda
My street car is turbo because it's factory, but it's a lot of work if you have no support. LOL, quality information right there.
Re: Hemi or Wedge
[Re: polyspheric]
#2324862
06/21/17 07:12 PM
06/21/17 07:12 PM
Posts: 12,396 Taxes & Virus's R-US, NY
Dragula
My 2 cents.....and I love Hemis, but they can be a pain at times. If the right matching parts are used, it will make great power without going crazy on compression and cam lift. Ours make over 800hp on pump gas...Had some issues half way into the first year with it, kinda working them out now...but my issues have been with the oiling system and lack of a big enough pan on my current engine and we hadn't put oil restrictors in the heads. Had many others over the years. But what I have seen on the Predator headed motors, is no goofing around no BS valve train with just dead on geometry...Meaning it all fits and works really well with astonishing spring pressures and crazy lift ratios and it holds up...Hemis don't like all that with respect to high lift and big ratios on the valve train. Its a lot of maintenance and its tough on parts with them. They tend to reach a point of sacrificing lift for less maintenance unless you go spendy with the T&D Barton setup. Me, I would be open to trying one of those Predator engines, probably would have if there were sombody making headers for them. Obviously, not a lot of people go this route, so no off the shelf headers...That is one expense that can be $1300 or $2500.... I think its going to depend on your preference and goals. I think in the long run the Predator is cheaper, and a better choice, but that's just based on my watching these guys...One other Predator expense you might incur other than headers is a offset distributor or jesel belt drive one. I do not believe a standard MSD will clear.. And a glide will be fine behind either at that weight...
Re: Hemi or Wedge
[Re: Hemicuda7]
#2324941
06/21/17 10:11 PM
06/21/17 10:11 PM
polyspheric
New York
Just a historical note: Powerglide was useless until about 1970 when Marvin Ripes of A-1 developed a good converter for his C1 Corvette. This means in a practical sense that even if $$$ "bullet-proof" (hah!) internals are used, a PG is only as good as the converter as to both careful selection (stall) and quality (efficiency, slip). This means $$$ well spent.
So far, purpose-built carburetors have made blow-through, with a good hat into the right aftermarket (not fabricated) manifold, affordable with very little power loss... in a race engine. Still a PITA for a street car, and the extra $$$ for quality EFI is what ruins the budget.
Boffin Emeritus
Re: Hemi or Wedge
[Re: Hemicuda7]
#2324945
06/21/17 10:18 PM
06/21/17 10:18 PM
polyspheric
New York
A blower (centrifugal, roots, turbo) develops lower peak cylinder pressure, and less strain on the walls, than a NA or especially nitrous (which has a giant bang that must be kept far away from TDC!!) engine with the same average power. The wider torque range will ET better with the same gearing.
It is also happy at lower RPM, which means; cheaper, smaller port volume heads with better manners less manifold volume for better response lighter pistons with (almost) no dome less rod beam section and a bit less $$$ rod bolts less cam duration, overlap and lift less rocker $$$ less valve spring for longer service life tuned exhaust less important, just big
Boffin Emeritus
