Re: Roadrunner day two street racer ideas.
[Re: nz383man]
#2325080
06/22/17 03:38 AM
06/22/17 03:38 AM
Posts: 43,193 Bend,OR USA
Cab_Burge
I would use that in a heartbeat Have fun degreeing the cam
[Re: Cab_Burge]
#2325093
06/22/17 04:59 AM
06/22/17 04:59 AM
Posts: 520 New Zealand
nz383man
New Zealand
I would use that in a heartbeat Have fun degreeing the cam I was hoping someone would say that! I'll use a Ramchargers one on my Hemi & this Dovovan one in the Runner, both were made by Donovan & they still make replacement part which fit both!
[Re: nz383man]
#2325151
06/22/17 11:28 AM
06/22/17 11:28 AM
Posts: 8,873 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Originally Posted By Stanton circa '78. Brand new fenders from the dealer $77 each !! 383, 12.5:1, tunnel ram w/2 600's
Are those fiberglass genders from the dealer? Nope, genuine Mopar stamped steel. Still have the bill somewhere.
[Re: nz383man]
#2325152
06/22/17 11:36 AM
06/22/17 11:36 AM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Have fun degreeing the cam LOL !! I had one and was bound and determined to use it ... till I tried degreeing the cam. I'm no quitter but I finally threw in the towel on that one and sold the unit. If they'd make the idler gear the same size as the crank gear it wouldn't be a problem but they're not. And the marks are on the three gears, not just the crank and cam. So when you turn the motor over you loose all reference. That seemed to be my problem anyway. But I don't think a gear drive was a "day 2" mod in anyone's budget unless you had a pro stocker.
[Re: Stanton]
#2325157
06/22/17 11:43 AM
06/22/17 11:43 AM
DaytonaTurbo
Manitoba, Canada
Have fun degreeing the cam LOL !! I had one and was bound and determined to use it ... till I tried degreeing the cam. I'm no quitter but I finally threw in the towel on that one and sold the unit. If they'd make the idler gear the same size as the crank gear it wouldn't be a problem but they're not. And the marks are on the three gears, not just the crank and cam. So when you turn the motor over you loose all reference. That seemed to be my problem anyway. But I don't think a gear drive was a "day 2" mod in anyone's budget unless you had a pro stocker. But the gear drive whine when cruising, you'd have been the coolest day 2 guy out there back in the day!
[Re: grancuda]
#2325169
06/22/17 12:20 PM
06/22/17 12:20 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Make sure you stick some white lights w/toggle on the dash mounted down on the back of the traction bars or hook a toggle to the reverse lights so you can cruise with them on meaning you are looking for a race. Never heard that before. We always just stopped at McDonalds till they asked us to leave. Must have been because we did't buy any food. LOL
[Re: Stanton]
#2325250
06/22/17 02:50 PM
06/22/17 02:50 PM
Cab_Burge
Have fun degreeing the cam LOL !! I had one and was bound and determined to use it ... till I tried degreeing the cam. I'm no quitter but I finally threw in the towel on that one and sold the unit. If they'd make the idler gear the same size as the crank gear it wouldn't be a problem but they're not. And the marks are on the three gears, not just the crank and cam. So when you turn the motor over you loose all reference. That seemed to be my problem anyway. I've installed and use Donovans, Milidons and Keith Black gear drives on 426 hemi and B and RB wedge motors with instructions and by memory. Start with the cam dowel placed around 4 o clock by looking at the front of the motor and go from there. If the lifters are close to being even heights in the lifter bores your close Once I have it where I want the intake lobe center I mark all three gears with matching mark with a drimel tool
[Re: rowin4]
#2325293
06/22/17 04:08 PM
06/22/17 04:08 PM
Posts: 372 Western NY
maxi426
Western NY
Make sure you stick some white lights w/toggle on the dash mounted down on the back of the traction bars or hook a toggle to the reverse lights so you can cruise with them on meaning you are looking for a race. Never heard that before. We always just stopped at McDonalds till they asked us to leave. Must have been because we did't buy any food. LOL Most cars rode around with the reverse lights on because you usually couldn't reuse the back drive linkage from the column with an aftermarket shifter. The column collar was left in the reverse position so that you could turn the key to lock and get the key out. When we saw a car go by with the reverse lights on, we'd say "there goes another Hurst shifter"
[Re: Cab_Burge]
#2325311
06/22/17 04:32 PM
06/22/17 04:32 PM
nz383man
New Zealand
Have fun degreeing the cam LOL !! I had one and was bound and determined to use it ... till I tried degreeing the cam. I'm no quitter but I finally threw in the towel on that one and sold the unit. If they'd make the idler gear the same size as the crank gear it wouldn't be a problem but they're not. And the marks are on the three gears, not just the crank and cam. So when you turn the motor over you loose all reference. That seemed to be my problem anyway. I've installed and use Donovans, Milidons and Keith Black gear drives on 426 hemi and B and RB wedge motors with instructions and by memory. Start with the cam dowel placed around 4 o clock by looking at the front of the motor and go from there. If the lifters are close to being even heights in the lifter bores your close Once I have it where I want the intake lobe center I mark all three gears with matching mark with a drimel tool I guess I need to get back onto Donovan for a set of instructions as I want to run these on two of my cars, if it has been done many times before it must be possible with the right information & a whole bunch of patience I would imagine.
[Re: nz383man]
#2325495
06/22/17 11:36 PM
06/22/17 11:36 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Originally Posted By Cab_Burge Originally Posted By Stanton Quote: Have fun degreeing the cam
I've installed and use Donovans, Milidons and Keith Black gear drives on 426 hemi and B and RB wedge motors with instructions and by memory. Start with the cam dowel placed around 4 o clock by looking at the front of the motor and go from there. If the lifters are close to being even heights in the lifter bores your close thumbs scope Once I have it where I want the intake lobe center I mark all three gears with matching mark with a drimel tool thumbs
I guess I need to get back onto Donovan for a set of instructions as I want to run these on two of my cars, if it has been done many times before it must be possible with the right information & a whole bunch of patience I would imagine. In Hindsight, I would mark the cam and crank gears and forget about the idler gear even being there. That's what was throwing me off. And I had no instructions for the set I had.
[Re: DaytonaTurbo]
#2325583
06/23/17 03:26 AM
06/23/17 03:26 AM
nz383man
New Zealand
Have fun degreeing the cam LOL !! I had one and was bound and determined to use it ... till I tried degreeing the cam. I'm no quitter but I finally threw in the towel on that one and sold the unit. If they'd make the idler gear the same size as the crank gear it wouldn't be a problem but they're not. And the marks are on the three gears, not just the crank and cam. So when you turn the motor over you loose all reference. That seemed to be my problem anyway. But I don't think a gear drive was a "day 2" mod in anyone's budget unless you had a pro stocker. But the gear drive whine when cruising, you'd have been the coolest day 2 guy out there back in the day! I like the way you think! As it happens I do have a Don Carlton Pro Stock Hemi in my Duster with a Ramchargers (by Donovan) gear drive so why not have one in the "day 2" car as well!
[Re: nz383man]
#2325584
06/23/17 03:30 AM
06/23/17 03:30 AM
Cab_Burge
Is that Hemi motor one of the destroked 396 C.I old Pro stock motors? if so do you race it and if so where do you shift that motor at?
[Re: Cab_Burge]
#2325785
06/23/17 03:49 PM
06/23/17 03:49 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I would use that in a heartbeat Have fun degreeing the cam Degreeing cams is easy. Put cam in, and find intake lobe max lift (Centerline.) Lock cam in position, or at least mark the cam gear to block position. Install degree wheel, find TDC, and zero degree wheel. Rotate crank so degree wheel reads the installed centerline you want. Install timing chain or idler gear without moving cam or crank position. Done.
[Re: nz383man]
#2325788
06/23/17 03:59 PM
06/23/17 03:59 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
As it happens I do have a Don Carlton Pro Stock Hemi in my Duster with a Ramchargers (by Donovan) gear drive so why not have one in the "day 2" car as well! You're deviating so far from "day 2" stuff you may as well back half the car, put a full cage in it, gut the interior and throw a new paint job on it !!
[Re: dustergirl340]
#2326022
06/24/17 06:50 AM
06/24/17 06:50 AM
nz383man
New Zealand
looks good but I think you stole that towel from Holiday Inn. Na bought it off eBay, they haven't made them like that for years!
