Dvorak 426 Hemi Rocker Stands #2323016
06/18/17 12:41 PM
06/18/17 12:41 PM
Utah, USA
tweeter1 Offline OP
tweeter1  Offline OP
Utah, USA
Anybody using this product?
I am considering purchasing this product, but I would appreciate some input.
Thanks Bob
Re: Dvorak 426 Hemi Rocker Stands [Re: tweeter1] #2323139
06/18/17 04:31 PM
06/18/17 04:31 PM
Utah, USA
tweeter1 Offline OP
tweeter1  Offline OP
Utah, USA
HemiRockerStands_small.jpg.dvorakmachine.com/images/dvoraklogo_trans.gif
Re: Dvorak 426 Hemi Rocker Stands [Re: tweeter1] #2323143
06/18/17 04:43 PM
06/18/17 04:43 PM
Utah, USA
tweeter1 Offline OP
tweeter1  Offline OP
Utah, USA
so with the new DVORAK MACHINE Hemi rocker support package. Made from 6061 T-6 premium virgin Aluminum and hard anodized, AND the head bolt hole is sleeved and protected from crush with “HEAD SAVERS”. Simply bolt them on as usual and then remove the shaft hold downs, similar to what is used on the 440 engines, to lift off the shaft and rockers as an assembly.
You can remove the intake shaft/rockers independent of the exhaust shaft/rockers and reinstallation is a breeze because there is always a position to rotate the engine in which all 4 intake valves (or all 4 exhaust valves on a given side) are closed or almost closed, making compressing the spring gentle and break proof. The supports are drilled and tapped for grade 8 3/8 studs, HD washers and 12 pt. nuts and the clamps are hardened steel that “surround” the shaft giving the rocker arm itself plenty of surface contact area to support the hard shims. All of the above mentioned hardware pieces are included with the kit. The simplicity of design and ease of use is outstanding, but there is much more.
NOT ONLY do you not have to loosen up the head to remove the rockers, the engineering design of the stands allow for improved rocker arm tip GEOMETRY in two important ways, correcting poor factory geometry and allowing for the changes and improvements that are necessary when building and blueprinting the incredible HEMI engine.
First, we raised the height that the shafts will stand by adding .060” of material to the bottom of the supports. Even the least invasive valve job and valve grind will benefit from the extra clearance but so many times, much more grinding is needed and done to establish necessary valve to piston clearance and valve to valve clearance.
As all of the components of the hemi are fine tuned and tweaked for best possible performance and fit, the geometry always suffers and will ultimately need to be addressed. Unfortunately until now there has been much too little that could be done about poor geometry, save butchering the valve tips and opening a new Pandora’s Box of trouble.
Second, raising the shafts will only correct part of the problem. As we all painfully know, as the valve moves into the head either by thinning or sinking, either on purpose or by correction, the tip of the valve moves AWAY from the tip of the rocker at the same time that it moves upward! SO, we moved the shafts OUTWARD toward the exhaust valves and the intake valves, yet another .060”! The final tip alignment, and contact area, or “scrub angle”, which makes the geometry with these movements built in into the stands, is nothing short of phenomenal, from stock to heavily modified. You will measure the difference, you will feel the difference and you will see the difference. You will also realize the difference in valve guide life, maximized lifts and best horsepower. Never before has so little yielded such dramatic results and the price for the whole kit is less than the factory replacement pieces.
RSSH-K Shaft Supports, studs, shaft surrounds, nuts and washers, hardened alignment shims
RSHI 2 intake shafts, .250” wall heavy shafts induction hardened, easy clean TM tapped holes with revised oiling to rocker arms.
RSHE 2 exhaust shafts, .250” wall heavy shaft, induction hardened, easy clean TM tapped holes with revised oiling to rocker arms.
Contact Dvorak Machine | Webmaster | Legal | Copyright 2004 © Dvorak Machine, Inc. All rights reserved.
Re: Dvorak 426 Hemi Rocker Stands [Re: tweeter1] #2323190
06/18/17 06:16 PM
06/18/17 06:16 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
I didnt know Dan was still in buisness,have you talked to him?
Re: Dvorak 426 Hemi Rocker Stands [Re: tweeter1] #2323208
06/18/17 06:58 PM
06/18/17 06:58 PM
I did some R&D for RAS Hemi steel rocker stands like in that description years ago, they ended up in deciding to not making them for sale work
Probably due to flexing of the shafts at each stand, not enough support to hold the shafts straight and rigid shruggy
Re: Dvorak 426 Hemi Rocker Stands [Re: tweeter1] #2323216
06/18/17 07:16 PM
06/18/17 07:16 PM
Utah, USA
tweeter1 Offline OP
tweeter1  Offline OP
Utah, USA
I haven't called Dvorak, yet!!
I will call Monday, I am using stock stands Indy rockers. I am not happy with location of the roller on the valve tip, ran the rockers through multiple cycles, trying different pushrod lengths without getting carried away, and just couldn't bring it in. So I started searching the internet. I could try diff rockers, but that could get expensive.
I was hoping someone had used his new stands and shafts.
Thanks for responding Bob
Re: Dvorak 426 Hemi Rocker Stands [Re: tweeter1] #2323256
06/18/17 08:25 PM
06/18/17 08:25 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Do you have lash caps on the tips?
Re: Dvorak 426 Hemi Rocker Stands [Re: tweeter1] #2323264
06/18/17 08:37 PM
06/18/17 08:37 PM
Utah, USA
tweeter1 Offline OP
tweeter1  Offline OP
Utah, USA
Yep, I used lash caps, with the correct retainers.
