Anyone tried Summit Racing M2008 Carburetors? #2320148
06/12/17 08:39 PM
06/12/17 08:39 PM
Tacoma, Washington USA
Adam71Charger Offline OP
Im looking at the square bore 600cfm vacuum secondary Summit Racing Carburetor model M08600VS
https://www.summitracing.com/parts/sum-m08600vs/overview/
The price is only $290, and it has a ton of positive reviews, and they have sold a ton of them. I was looking for a 600cfm edelbrock 1406 when I stumbled across these, and they really are not much more expensive than most used edelbrocks Ive come across.
I want to throw it on a stock 318 with a performer intake and dual exhaust. Has anyone used one of these yet, especially this model? Looking for some feedback on these vs the eddys.
Re: Anyone tried Summit Racing M2008 Carburetors? [Re: Adam71Charger] #2320149
06/12/17 08:40 PM
06/12/17 08:40 PM
They even have refurbished for $200
Re: Anyone tried Summit Racing M2008 Carburetors? [Re: Adam71Charger] #2320233
06/12/17 11:00 PM
06/12/17 11:00 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I wouldn't put a new or referb'd one on anything I was planning to have start up and drive decently.
Would rather buy a standard 4150 DP or VS, even an Edelbrock
JMO
Re: Anyone tried Summit Racing M2008 Carburetors? [Re: Adam71Charger] #2320269
06/12/17 11:57 PM
06/12/17 11:57 PM
Why? What negative experiences have you had with them?
Re: Anyone tried Summit Racing M2008 Carburetors? [Re: Adam71Charger] #2320332
06/13/17 01:19 AM
06/13/17 01:19 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
the carb you are interested in is based off an Autolite design from the late 50's / early 60's. They were reliable carbs in their applications. Holley reintroduced this design in the mid 80's or so to address ?? from competitors. Due to several issues, it was not well received and went away shortly thereafter. Flash forward to 2005 or so and the design reappeared mainly through Summit to my knowledge. since then they seem to have fixed the "ISSUES" prevalent with The mid to late 80's Holley Version. In my opinion Holley / Edelbrock pretty much control the market. They both have their good and bad points. on the other hand, I have not heard anything bad about about the Summit carb but do not have any 1st hand experience with them.
twocents beer popcorn
Re: Anyone tried Summit Racing M2008 Carburetors? [Re: Adam71Charger] #2320410
06/13/17 09:06 AM
06/13/17 09:06 AM
crlush Offline
crlush  Offline
I had a holley version, it worked just as good as any other carb that is well adjusted, never had any problems with it.
Re: Anyone tried Summit Racing M2008 Carburetors? [Re: TJP] #2320411
06/13/17 09:07 AM
06/13/17 09:07 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I still have one hanging on garage wall, horrible design.
The fuel curve and transitions were a train wreck (I had a vacuum gauge and O2 gauge on car for tuning) the primary boosters and fuel shooters are one piece, power valves was on underside so you had to pull carb to get at it, and the base is hollow and prone to cracking.
Mind you this is what Holley sold at one time, I have no idea if Summit fixed any of these issues. My experience is limited to the one that Holley sold.
"I think its got a hemi"
Re: Anyone tried Summit Racing M2008 Carburetors? [Re: Adam71Charger] #2320418
06/13/17 09:36 AM
06/13/17 09:36 AM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
My Dad's Camaro runs one right now without issues. In your link there is over 351 reviews averaging above 4.5 stars outta 5. I think they're safe bet for a budget carb. They're handy for changing jets since the top comes off instead of the sides. The boosters are annular discharge too.
Re: Anyone tried Summit Racing M2008 Carburetors? [Re: Adam71Charger] #2320483
06/13/17 11:45 AM
06/13/17 11:45 AM
ohio
bbtrux Offline
bbtrux  Offline
ohio
Ive got a refurbed one on a stock 318 in my 71 sweptline. Its a little too big for that engine,but thats my fault, not the carbs. Regardless of that, it works very well.
Re: Anyone tried Summit Racing M2008 Carburetors? [Re: bbtrux] #2320533
06/13/17 01:39 PM
06/13/17 01:39 PM
dogdays Offline
dogdays  Offline
It wasn't late '50s, Fords were heavily into Holley 4150 and 4160s back then. It was in the '70s that I saw my first Ford one. It was running way rich. I lowered the float level and it ran better with more mileage.
The model is 4010 for the squarebore and 4011 for the spreadbore.
I've seen Holley brand carbs in this style all over the place, and they sell for cheap. So I'd say don't bother.
For just a few dollars more you can get a Holley Street Demon which has probably the most sophisticated metering system in mass market carburetors today. It will bolt right onto either a square bore or spreadbore intake. It comes in two sizes, 625 and 750 cfm. That's where I'd spend my money.
R.
Re: Anyone tried Summit Racing M2008 Carburetors? [Re: Adam71Charger] #2320684
06/13/17 06:22 PM
06/13/17 06:22 PM
Maryland
MoparMike1974 Offline
Maryland
I had one of the Holley ones on my 340 back in the mid 90's and that carb was the most reliable holley i ever had. I never had a moment of problem with it.
If I needed a carb I wouldnt hesitate to give this one a try. Most likely Holley is making them for summit.
Re: Anyone tried Summit Racing M2008 Carburetors? [Re: Adam71Charger] #2320750
06/13/17 08:42 PM
06/13/17 08:42 PM
At the price, good reviews, and summit's return policy I think Ill try it out. Its just for a nothing special daily driver 318
Re: Anyone tried Summit Racing M2008 Carburetors? [Re: Adam71Charger] #2321299
06/14/17 10:14 PM
06/14/17 10:14 PM
dogdays Offline
dogdays  Offline
There goes the neighborhood...............
Re: Anyone tried Summit Racing M2008 Carburetors? [Re: Adam71Charger] #2321430
06/15/17 02:04 AM
06/15/17 02:04 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I have one on the shelf that was given to me. I think it is the larger 750 square bore electric choke version. It looks nearly new. I'll make you a deal on it if your interested?
Re: Anyone tried Summit Racing M2008 Carburetors? [Re: Adam71Charger] #2322131
06/16/17 01:30 PM
06/16/17 01:30 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
The one I had experience with had mixture screws that fit so poorly you could not get a reasonable adjustment on them. Touch them with a screwdriver, they would wiggle and the idle would change. Add this to the long list of other deficiencies discussed here and there you have it.
Guess there is a generous spread on what people consider "good" so I'm wondering if "good" means it starts and runs.
I have to agree with dogdays on the Street Demon for a few bucks more but hope you have better luck with your purchase than my bit of experience with the design.
Re: Anyone tried Summit Racing M2008 Carburetors? [Re: Adam71Charger] #2322749
06/17/17 08:39 PM
06/17/17 08:39 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Thanks for buying the carb, here are a few photos:
Re: Anyone tried Summit Racing M2008 Carburetors? [Re: Adam71Charger] #2322779
06/17/17 09:41 PM
06/17/17 09:41 PM
Cool! Looks like I can send back the fuel rail I ordered from summit too. Thank you for the killer deal.
Re: Anyone tried Summit Racing M2008 Carburetors? [Re: Adam71Charger] #2323467
06/19/17 08:02 AM
06/19/17 08:02 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Nice to see they filled in the base a bit so the mounting ears don't crack off. Here is a few pics of the original, you can see where we retrofitted it with a DP 50cc pump to help with the lean spot. Had to drill the shooters too.
Re: Anyone tried Summit Racing M2008 Carburetors? [Re: Adam71Charger] #2390056
10/19/17 10:40 PM
10/19/17 10:40 PM
Maryland
Maryland
You know, the Holley I had like that was spread bore. It was a very good reliable carb. I cant recall if it came in square bore or not but probably did. This was early 90's when I bought mine.
