Milodon road racing small-block oil pan... #2322511
06/17/17 04:29 AM
06/17/17 04:29 AM
the frozen wastes...
Pale_Roader Offline OP
Swears too much
Swears too much
Is this something i really need? I dont have ANY pan for my 360 Magnum yet, and one is available used... but its still gonna sink me probably $250-300 more than a basic 360 pan will. Do i need 7 quarts? Will all the tricks (baffling and such) be worth it on a corner carver/canyon killer?
And issues with using one? (install, clearance, anything i need to know, etc.)
Re: Milodon road racing small-block oil pan... [Re: Pale_Roader] #2322556
06/17/17 11:12 AM
06/17/17 11:12 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Steve Wall (AutoXCuda) has a small block one in his car, I've got the B engine version in mine- both A bodies. Trimming of the K may be needed, but really you should be pulling the K out to weld it up and gusset the box mounts anyway. I didn't have to do any additional trimming or notching. Do you need one- Come on Man! YES! or make your own pan with kickout and baffles. An Accusump is not a bad idea either.
Re: Milodon road racing small-block oil pan... [Re: Skeptic] #2322566
06/17/17 11:34 AM
06/17/17 11:34 AM
Madison, Wisconsin
chrisnben Offline
chrisnben  Offline
Madison, Wisconsin
Pale man- I have one for sale, including the pickup and good Milodon HV pump. I think I have it listed here in the small block section.
Message me
'70 Cuda "Badfish 2"- in the works
Home of MoPar University- We school 'em one at a time!!
Re: Milodon road racing small-block oil pan... [Re: Pale_Roader] #2322608
06/17/17 01:14 PM
06/17/17 01:14 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
You won't need any mods to put it in an EBody or Bbody k-member.
Only the tight A-body 73-76 spool mount k-members. It's helpful to put a notch in the k for clearance. I didn't notch mine. But it nearly touches.
Re: Milodon road racing small-block oil pan... [Re: Pale_Roader] #2322613
06/17/17 01:30 PM
06/17/17 01:30 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
IMO, a high quality, professionally built pan is cheap insurance on an engine. $500 seems expensive until you frag a $5000-8000 engine.
Now, can you build your own to save some bucks, absolutely. Oil starvation is the big issue with lateral loading, so installing shelves, gates, and extenders in a stock pan to keep oil around the pick up goes a loooong way over doing nothing. Oval track suppliers can provide kits to add capacity. While designed for left hand turns, adding two kits to both sides of the sump is possible. The kicker is that you have to understand the kit size and clearances you are working with to ensure it doesn't interfere.
A more budget friendly version may be the Kevko unit. While not as technically advanced as the Milodon pan, its better than stock.
http://kmjperformance.com/kevko-m302-new-mopar-chrysler-race-x-tra-capacity-oil-pan-360.html
Re: Milodon road racing small-block oil pan... [Re: TC@HP2] #2322621
06/17/17 01:51 PM
06/17/17 01:51 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
That might be a nice modest cost upgrade, have you seen one yourself internally for its effectiveness? work
Re: Milodon road racing small-block oil pan... [Re: jcc] #2322750
06/17/17 08:40 PM
06/17/17 08:40 PM
Swears too much
Swears too much
Hmmm... interesting. I just pulled up pics on google (most came from here). Seems a bit overkill for what i need, right now anyways, but i like planning for the future. My concern, is budget... is it worth a SLAM to my already tenuous budget right now. I had budgeted for a $50 used pan from some Mopar parts vulture. Even a $300 used set up will run me well over $400 by the time i can hold it.
The Kevco kit looks interesting, last time i looked for it i couldn't find it...
Probably gonna come down to this, or that damn 16:1 manual box...
Re: Milodon road racing small-block oil pan... [Re: Pale_Roader] #2322784
06/17/17 10:01 PM
06/17/17 10:01 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I have the road race pan on my Gen 3 which is basically the same thing. First time at Big Willow in 2016 I ran 135 mph down the straight and slammed on the brakes for the left hand turn 1. My oil pressure light lit up consistently at that corner which got me concerned. Opened up my oil filter afterwards and found zero metal bits or bearing material. I have since added an Accusump and the oil pressure light lit up maybe 3 times the last time I was there running the same speed in April 2017.
The Milodan pan is a good upgrade if you can get your hands on one
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Milodon road racing small-block oil pan... [Re: Pale_Roader] #2322826
06/17/17 11:08 PM
06/17/17 11:08 PM
Swears too much
Swears too much
Well... it just sold... so i guess now i'm looking at the Kevco pan.
Not gonna make a new thread.
Anyone have/use the Kevco pan?
Re: Milodon road racing small-block oil pan... [Re: Pale_Roader] #2322837
06/17/17 11:30 PM
06/17/17 11:30 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
the kevco pan looks like it hangs too low and its only 5 quarts as oppose to the 7 from milodon.
Re: Milodon road racing small-block oil pan... [Re: Pale_Roader] #2323204
06/18/17 06:50 PM
06/18/17 06:50 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Nope, I have not. They have been in the oval track game for quite a while though. It used to be their only mopar pan was a rear sump, modified chassis pan. This center sump stock chassis unit is newer.
Well then, modify your stock pan. Add on extension kit for $19 or a add on trap door kit for $15. Of course, both chevy based, but adaptable.
http://www.speedwaymotors.com/shop/oval-track-engine-oil-pans~142-2-10-599-5562
Other option, roll you own oil accumulator. There are some budget options around this effort as well that you could make with hardware store parts for under $30. Its not like the oil system is super high pressure;
https://grassrootsmotorsports.com/forum/...mp/32723/page1/
Re: Milodon road racing small-block oil pan... [Re: Pale_Roader] #2326287
06/25/17 01:46 AM
06/25/17 01:46 AM
AndyF Online content
AndyF  Online Content
We tried all of those pans on Tim's red Valiant. He had Kevko build him custom pans, we tried the Milodon pan as well as several other pans. The Milodon pan works pretty well but it is a real pain to install. It has been a few years but I think we ended up building a new K member in order to use the Milodon pan.
Re: Milodon road racing small-block oil pan... [Re: Pale_Roader] #2327565
06/27/17 04:09 PM
06/27/17 04:09 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
I used a Kevko baffled pan with the 360 for about four years. Nice pan, fit well.
Re: Milodon road racing small-block oil pan... [Re: Pale_Roader] #2327864
06/28/17 01:34 AM
06/28/17 01:34 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
I have a Milodon Road Race pan without any problems of fitment in my Dart. Granted I heard they fit well with the '68-72 K-frames.
Re: Milodon road racing small-block oil pan... [Re: Pale_Roader] #2327906
06/28/17 06:08 AM
06/28/17 06:08 AM
Swears too much
Swears too much
Hmmm... as it stands (sits) i'm still undecided. It was one thing to want to spend (a lot ov) money on a used Milodon system (pan, pick-up, pump), that would solve all the problems, but to spend almost as much money on a Kevco pan that really only upgrades one issue (baffling, the extra capacity is only one quart)... i dont know. If i can find something used in a stock pan for under $50 i'll go that route for now. Kinda liked the idea ov the Milodon pan... maybe another used one will come up between now an the time i actually need a road racing pan...
I used to trash the [censored] outta my Charger's 440... Hell, ran it low on oil half the time, and that was a stock 4qt pan. Saw nothing upsetting when i tore that engine down...
