Re: Australian Muscle Parts
[Re: johnnyd]
#2322466
06/17/17 01:11 AM
06/17/17 01:11 AM
Posts: 515 geezer acres rest home
dakotawilly
I have a new one going in my current build, nice piece, Mancini used to sell them, just hope it doesn't run counter clockwise,lol....
SFI 25.5 depends,no leak,even at 213 mph....
[Re: johnnyd]
#2322471
06/17/17 01:36 AM
06/17/17 01:36 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
Their product looks exactly like Jesel's , so why would you buy something that you might have a problem getting a replacement belt or pulley ? I could see buying it if you were in Australia or were not available in the USA. Just to be different? LOL
[Re: rowin4]
#2322819
06/17/17 10:49 PM
06/17/17 10:49 PM
Posts: 4,647 aotearoa
rebel
aotearoa
Their product looks exactly like Jesel's , so why would you buy something that you might have a problem getting a replacement belt or pulley ? I could see buying it if you were in Australia or were not available in the USA. Just to be different? LOL it's not the same as a Jesel since it has an idler wheel which in my opinion makes it superior. i've run mine for the past decade & i'm very happy with it. the only downside part is that it didn't come with Torque fugures for the LH thread center bolt but apart from that its an awesome piece. i didn't have to modify anything to make mine fit & the extended ATI damper fits great.
[Re: johnnyd]
#2322861
06/18/17 12:36 AM
06/18/17 12:36 AM
rowin4
My Jesel has the idler wheel and the torque for the left hand thread is 75 foot pounds
[Re: rowin4]
#2322883
06/18/17 01:58 AM
06/18/17 01:58 AM
Posts: 234 Brisvegas, Australia
Alchemi
My Jesel has the idler wheel and the torque for the left hand thread is 75 foot pounds Got a part number for that?
[Re: rowin4]
#2322903
06/18/17 04:31 AM
06/18/17 04:31 AM
Posts: 6,150 Melbourne , Australia
LA360
the belts are a HTD drive belt, which are more than readily available. They aren't a proprietary belt like the Jesel unit is.
Alan Jones
[Re: rowin4]
#2322905
06/18/17 05:02 AM
06/18/17 05:02 AM
rebel
aotearoa
My Jesel has the idler wheel and the torque for the left hand thread is 75 foot pounds thanks for that. we chose 70lbs with a drop pf Loctite. we were close.
[Re: LA360]
#2322906
06/18/17 05:05 AM
06/18/17 05:05 AM
rebel
aotearoa
the belts are a HTD drive belt, which are more than readily available. They aren't a proprietary belt like the Jesel unit is. I can buy a Mitsuboshi belt at a local supply outlet for these. Cheap too, well cheap for us maybe, last one cost me $32. I've replaced my belt as being the only changeout part i thought weas neccessary.
[Re: johnnyd]
#2324108
06/20/17 11:43 AM
06/20/17 11:43 AM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
The Jesel RAISED cam belt drive uses an idler. The std one does not use an idler...
FWIW I had an AMP belt drive on the Valiant. HAd a few small issues with it but I bought it in 2004 and think it was an early version. They helped me fix the fitment issues and it worked fine after that. Sold it to a member here and assume its still working well.
