Re: motor plate?
[Re: Just-a-dart]
#2322103
06/16/17 12:31 PM
06/16/17 12:31 PM
Triple Threat
Renton Washington
Same thing I used. Bore Spacing is identical small block to G3. Length is basically a wash depending on what timing cover and accessories you're using on the front.
Re: motor plate?
[Re: Triple Threat]
#2322341
06/16/17 08:57 PM
06/16/17 08:57 PM
Posts: 814 in front of the computer
80arrow
Same thing I used. Bore Spacing is identical small block to G3. Length is basically a wash depending on what timing cover and accessories you're using on the front. Ok, just tossing it around and was wondering if my tabs for my current motor plate would work. Trying to figure stuff out before it goes to the body shop.
Re: motor plate?
[Re: 80arrow]
#2323705
06/19/17 05:23 PM
06/19/17 05:23 PM
Posts: 625 Indianapolis In. usa
Quickrunner
AEI here as well. He can modify the outer dimensions if you need, hes easy to work with, did a few custom things I asked for on mine.
05 Ram 1500 Daytona package 71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: motor plate?
[Re: Quickrunner]
#2323843
06/19/17 09:45 PM
06/19/17 09:45 PM
80arrow
AEI here as well. He can modify the outer dimensions if you need, hes easy to work with, did a few custom things I asked for on mine. Is that a Bob's Profab front end? If it is, does it look like the oil pan and everything will clear the k-member? Can you guys tell me the benefits of having the water inlet and outlet as an fittings vs a waterpump? And what sizes of fittings to go with? The Gen 3 is a whole new bag of questions for me, lol. Quickrunner, do you know what the measurement from the back of your motor plate to the back of your block is?
Re: motor plate?
[Re: cudadoug]
#2324094
06/20/17 11:24 AM
06/20/17 11:24 AM
Quickrunner
Curious what version of the timing covers are y'all using with this plate?
I'm thinking any one will do and I can slice and dice all the of the OE mounting points on top to clean up the appearance.
It is a truck timing cover that AEI will mill some of the extra non needed stuff off of. He did mine with a core charge I got back.
Re: motor plate?
[Re: 80arrow]
#2324099
06/20/17 11:31 AM
06/20/17 11:31 AM
Quickrunner
AEI here as well. He can modify the outer dimensions if you need, hes easy to work with, did a few custom things I asked for on mine. Is that a Bob's Profab front end? If it is, does it look like the oil pan and everything will clear the k-member? Can you guys tell me the benefits of having the water inlet and outlet as an fittings vs a waterpump? And what sizes of fittings to go with? The Gen 3 is a whole new bag of questions for me, lol. Quickrunner, do you know what the measurement from the back of your motor plate to the back of your block is? Yes it is a Bobs front end, I went with a custom pan from Charlies. I chose to go remote water pump route so I could route hoses out of the way of whatever belt drive system for supercharger I decide to go with. I don't know measurement but could get it this week. I set it up with a 727 core bolted to the block on stock trans mount then got it where I wanted it and fabed the tabs for the motorplate to the frame rail. Then ditched the 727 and made new trans crosmember for the Ried case th400.
Re: motor plate?
[Re: 80arrow]
#2324103
06/20/17 11:38 AM
06/20/17 11:38 AM
Quickrunner
AEI has a option to run a BB chevy electric pump with their plate as well. It's that or remote pump with their plate.
Re: motor plate?
[Re: Quickrunner]
#2324189
06/20/17 01:53 PM
06/20/17 01:53 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
It is a truck timing cover that AEI will mill some of the extra non needed stuff off of. He did mine with a core charge I got back. Good to know; thank you!
Re: motor plate?
[Re: 80arrow]
#2326040
06/24/17 10:27 AM
06/24/17 10:27 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
The AEI plate is designed for the truck timing cover. The truck cover has the accessory mounts high, and the lower part is smaller. You just cut or mill off the high mounts. I am doing 3/4npt in and a T-stat out in the plate with a Meziere remote pump. I think most guys do the Chevy pump option www.meziere.com/Products/Cooling-System-...e-Standard.aspx
"Just a Bracket car dressed up like a streetcar"
