Re: A833 18spline, hard to put into 1st after being in neutral
[Re: lilred]
#2321812
06/15/17 09:44 PM
06/15/17 09:44 PM
fast68plymouth
So. Burlington, Vt.
I'm not a 4 speed guru by any means, but if I were having that problem, the first thing I'd do is check the air gap in the clutch.
If that checked out good, I'd dump the trans fluid and try some Pennzoil synchro-mesh gear oil.
[Re: lilred]
#2321818
06/15/17 09:55 PM
06/15/17 09:55 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Don't think changing gear oil will do anything, the gears are not moving.
Double check the shifter alignment. I had a wore out shifter on my 300 that would get the shift handle stuck between the forks on the shift mechanism, it first showed up as difficult to put into first at a stop.
[Re: lilred]
#2321839
06/15/17 10:27 PM
06/15/17 10:27 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Who did the rebuild/ There are 2 different synchros used in different year 18 spline transmissions. Possibly might have used the wrong ones? Or you have a broken synchro ring.
[Re: lilred]
#2321846
06/15/17 10:36 PM
06/15/17 10:36 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
Check the clutch adjustment, if you can have someone use a feeler to stick in between the clutch disc and flywheel or pressue plate with the pedal depressed like you drive it see how much air gap you get and let us know ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) Mopars are famous for dragging clutch disc ![runaway runaway](/ubbthreads/images/graemlins/custom/runaway.gif) Which makes them hard to shift and put into gear ![work work](/ubbthreads/images/graemlins/custom/work.gif) Good luck, you CAN fix it
[Re: lilred]
#2321894
06/15/17 11:35 PM
06/15/17 11:35 PM
Posts: 15,536 Omaha Ne
TJP
Omaha Ne
I have a 67 GTX 18 spline 4spd and after putting the car in neutral at a stop light it is hard to put into 1st gear, I have had the trans gone through and with new synchros/brgs from the kit from Brewers as well as put in the newer style roller bearing pilot brg and am using the Amsoil 75/90 synthetic gear oil that is GL4, the trans will down shift fine in all gears, its only when put into neutral at a light and than back into gear that it is real stubborn to the point that sometimes not sure it will even go into 1st or 2nd gear. Any ideas would be appreciated. Thanks. I would say based on your description that the most likely candidate is, Improperly adjusted clutch creating drag. An indicator of this is how close off the floor does the the car start to pull the motor down and move ?? Pilot bearing / input shaft issue, again creating drag. Mis-alignment of the bell housing, again creating drag. An internal Trans issue. keep us posted
[Re: rowin4]
#2321990
06/16/17 02:57 AM
06/16/17 02:57 AM
Posts: 172 katakan
lilred
katakan
The syno rings and hubs were all changed to the 70 style a few years a go. I believe there is air gap as I had checked that with a helper when I was under the car, also when the car is running if you depress the clutch by hand it takes a while till you can feel the release brg starting to contact, I will give it a bit more air gap and try to see if that helps. Thanks.
[Re: fastmark]
#2322049
06/16/17 10:44 AM
06/16/17 10:44 AM
Supercuda
About to go away
About to go away
up yours
I changed to Amsoil sysnthetic gear oil in my 4 speed and it did not shift correctly. Honestly it's been so long ago and I left it in for a short time only, so I forgot exactly what my symptoms were. I think it was just hard shifting. I called Jamie Passom and he told me the old 833 needed regular gear oil the make the synchros work properly. He told the Amsoil was too slippery. Synchros do not work when at a stop and shifting into any gear.
[Re: Supercuda]
#2322061
06/16/17 11:12 AM
06/16/17 11:12 AM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
I changed to Amsoil sysnthetic gear oil in my 4 speed and it did not shift correctly. Honestly it's been so long ago and I left it in for a short time only, so I forgot exactly what my symptoms were. I think it was just hard shifting. I called Jamie Passom and he told me the old 833 needed regular gear oil the make the synchros work properly. He told the Amsoil was too slippery. Synchros do not work when at a stop and shifting into any gear. WHAT ??? The job of the synchronizer is to slow down the gear to ease engagement. The brass ring grips the cone on the gear and slows it down before the teeth engage. I would look into the shifter adjustment first, then the dis-engagement of the clutch. Excessive bellhousing runout can also cause low speed engagement issues. You may need to change the fluid to a more syncro friendly fluid. I just use regular old dino gear oil and stay away from synthetics because they are just too slippery for the syncro rings grab the gears. If this happened all of the sudden I would look into some mechanical issues like shifter issues or something in the clutch linkage. Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2322064
06/16/17 11:15 AM
06/16/17 11:15 AM
Supercuda
About to go away
About to go away
up yours
WHAT ??? The job of the synchronizer is to slow down the gear to ease engagement. Go back and reread what I wrote then tell us what gear needs slowing down when at a stop. Hint, NONE.
[Re: lilred]
#2322113
06/16/17 12:44 PM
06/16/17 12:44 PM
fast68plymouth
So. Burlington, Vt.
The op says he's in neutral, then can't get it back into gear.
If the trans is in neutral, and the clutch is engaged, everything is turning. When you push the clutch pedal in, there is usually still some amount of drag helping to keep everything spinning, and when you go to put it into gear, the synchro has the job of stopping the rotation and aligning the teeth so it will slide into gear.
Surely you've heard someone grinding a gear to get it engaged........ They don't grind when they're not turning.
I still say a fluid change would help, and the Pennzoil synchro-mesh was recommended to me by a guy who does a lot of transmissions.
It's not that expensive and it's easy to do.
[Re: lilred]
#2322126
06/16/17 01:18 PM
06/16/17 01:18 PM
rowin4
I have also heard that slippery [ synthetic ] gear lube doesn't work well in older transmissions .
[Re: lilred]
#2322128
06/16/17 01:22 PM
06/16/17 01:22 PM
Posts: 2,368 Wheatfield, NY
Cuda340
Wheatfield, NY
Do you recall as to exactly what oil you ended up using as I would definitely give it a try, was it just regular of the shelf 80/90 gear oil??? Thanks NAPA sells a GL-4 rated gear oil. Just make sure its not the GL-5 rated stuff. I also head that Pennzoil Syncromesh works as well.
[Re: lilred]
#2322153
06/16/17 02:21 PM
06/16/17 02:21 PM
fast68plymouth
So. Burlington, Vt.
I think I bought the Pennzoil at AutoZone or Advance.
[Re: lilred]
#2322163
06/16/17 02:33 PM
06/16/17 02:33 PM
Posts: 5,167 CT
GTX MATT
CT
Were the shift forks replaced?
Does it grind when it finally goes into gear?
