Page 1 of 4 1 2 3 4
A833 18spline, hard to put into 1st after being in neutral #2321810
06/15/17 09:40 PM
06/15/17 09:40 PM
katakan
lilred Offline OP
lilred  Offline OP
katakan
I have a 67 GTX 18 spline 4spd and after putting the car in neutral at a stop light it is hard to put into 1st gear, I have had the trans gone through and with new synchros/brgs from the kit from Brewers as well as put in the newer style roller bearing pilot brg and am using the Amsoil 75/90 synthetic gear oil that is GL4, the trans will down shift fine in all gears, its only when put into neutral at a light and than back into gear that it is real stubborn to the point that sometimes not sure it will even go into 1st or 2nd gear.
Any ideas would be appreciated. Thanks.
Re: A833 18spline, hard to put into 1st after being in neutral [Re: lilred] #2321812
06/15/17 09:44 PM
06/15/17 09:44 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I'm not a 4 speed guru by any means, but if I were having that problem, the first thing I'd do is check the air gap in the clutch.
If that checked out good, I'd dump the trans fluid and try some Pennzoil synchro-mesh gear oil.
Re: A833 18spline, hard to put into 1st after being in neutral [Re: lilred] #2321818
06/15/17 09:55 PM
06/15/17 09:55 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't think changing gear oil will do anything, the gears are not moving.
Double check the shifter alignment. I had a wore out shifter on my 300 that would get the shift handle stuck between the forks on the shift mechanism, it first showed up as difficult to put into first at a stop.
Don't be the exception.
Re: A833 18spline, hard to put into 1st after being in neutral [Re: lilred] #2321839
06/15/17 10:27 PM
06/15/17 10:27 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Who did the rebuild/ There are 2 different synchros used in different year 18 spline transmissions. Possibly might have used the wrong ones? Or you have a broken synchro ring.
Re: A833 18spline, hard to put into 1st after being in neutral [Re: lilred] #2321846
06/15/17 10:36 PM
06/15/17 10:36 PM
Check the clutch adjustment, if you can have someone use a feeler to stick in between the clutch disc and flywheel or pressue plate with the pedal depressed like you drive it see how much air gap you get and let us know scope
Mopars are famous for dragging clutch disc runaway
Which makes them hard to shift and put into gear work
Good luck, you CAN fix it thumbs
Re: A833 18spline, hard to put into 1st after being in neutral [Re: lilred] #2321859
06/15/17 10:48 PM
06/15/17 10:48 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
I remember this was a common thing back in the day.. Seems like it was easier to put into second to stop the gears, then move up into 1st.
Re: A833 18spline, hard to put into 1st after being in neutral [Re: lilred] #2321894
06/15/17 11:35 PM
06/15/17 11:35 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I would say based on your description that the most likely candidate is,
Improperly adjusted clutch creating drag. An indicator of this is how close off the floor does the the car start to pull the motor down and move ??
Pilot bearing / input shaft issue, again creating drag.
Mis-alignment of the bell housing, again creating drag.
An internal Trans issue.
keep us posted beer
Re: A833 18spline, hard to put into 1st after being in neutral [Re: rowin4] #2321990
06/16/17 02:57 AM
06/16/17 02:57 AM
katakan
lilred Offline OP
lilred  Offline OP
katakan
The syno rings and hubs were all changed to the 70 style a few years a go.
I believe there is air gap as I had checked that with a helper when I was under the car, also when the car is running if you depress the clutch by hand it takes a while till you can feel the release brg starting to contact,
I will give it a bit more air gap and try to see if that helps.
Thanks.
Re: A833 18spline, hard to put into 1st after being in neutral [Re: lilred] #2321992
06/16/17 03:31 AM
06/16/17 03:31 AM
I think that you will find that if you have between .060 and .100 air gap between the throw out bearing and pressure plate fingers with the clutch pedal up all the way the clutch will work way better thumbs scope
Re: A833 18spline, hard to put into 1st after being in neutral [Re: lilred] #2322046
06/16/17 10:40 AM
06/16/17 10:40 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I changed to Amsoil sysnthetic gear oil in my 4 speed and it did not shift correctly. Honestly it's been so long ago and I left it in for a short time only, so I forgot exactly what my symptoms were. I think it was just hard shifting. I called Jamie Passom and he told me the old 833 needed regular gear oil the make the synchros work properly. He told the Amsoil was too slippery.
Re: A833 18spline, hard to put into 1st after being in neutral [Re: fastmark] #2322049
06/16/17 10:44 AM
06/16/17 10:44 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Synchros do not work when at a stop and shifting into any gear.
Re: A833 18spline, hard to put into 1st after being in neutral [Re: Supercuda] #2322061
06/16/17 11:12 AM
06/16/17 11:12 AM
Rittman Ohio
fourgearsavoy Online tonguue
fourgearsavoy  Online Tonguue
Rittman Ohio
WHAT ??? The job of the synchronizer is to slow down the gear to ease engagement. The brass ring grips the cone on the gear and slows it down before the teeth engage. I would look into the shifter adjustment first, then the dis-engagement of the clutch.
Excessive bellhousing runout can also cause low speed engagement issues. You may need to change the fluid to a more syncro friendly fluid. I just use regular old dino gear oil and stay away from synthetics because they are just too slippery for the syncro rings grab the gears.
If this happened all of the sudden I would look into some mechanical issues like shifter issues or something in the clutch linkage.
Gus beer
64 Plymouth Savoy
Dana 60
Re: A833 18spline, hard to put into 1st after being in neutral [Re: fourgearsavoy] #2322064
06/16/17 11:15 AM
06/16/17 11:15 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Go back and reread what I wrote then tell us what gear needs slowing down when at a stop. Hint, NONE.
Re: A833 18spline, hard to put into 1st after being in neutral [Re: lilred] #2322095
06/16/17 12:18 PM
06/16/17 12:18 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
All I can tell you is I bought an NOS NP 833 installed it with regular gear oil and ran it for about 10,000 miles. I changed to the Amsoil and it shifted poorly. I changed back to gear oil and all is still well.
Re: A833 18spline, hard to put into 1st after being in neutral [Re: fastmark] #2322112
06/16/17 12:42 PM
06/16/17 12:42 PM
katakan
lilred Offline OP
lilred  Offline OP
katakan
Do you recall as to exactly what oil you ended up using as I would definitely give it a try, was it just regular of the shelf 80/90 gear oil??? Thanks
Re: A833 18spline, hard to put into 1st after being in neutral [Re: lilred] #2322113
06/16/17 12:44 PM
06/16/17 12:44 PM
So. Burlington, Vt.
So. Burlington, Vt.
The op says he's in neutral, then can't get it back into gear.
If the trans is in neutral, and the clutch is engaged, everything is turning.
When you push the clutch pedal in, there is usually still some amount of drag helping to keep everything spinning, and when you go to put it into gear, the synchro has the job of stopping the rotation and aligning the teeth so it will slide into gear.
Surely you've heard someone grinding a gear to get it engaged........ They don't grind when they're not turning.
I still say a fluid change would help, and the Pennzoil synchro-mesh was recommended to me by a guy who does a lot of transmissions.
It's not that expensive and it's easy to do.
Re: A833 18spline, hard to put into 1st after being in neutral [Re: lilred] #2322126
06/16/17 01:18 PM
06/16/17 01:18 PM
rowin4 Offline
rowin4  Offline
I have also heard that slippery [ synthetic ] gear lube doesn't work well in older transmissions .
Re: A833 18spline, hard to put into 1st after being in neutral [Re: lilred] #2322128
06/16/17 01:22 PM
06/16/17 01:22 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
NAPA sells a GL-4 rated gear oil. Just make sure its not the GL-5 rated stuff. I also head that Pennzoil Syncromesh works as well.
Re: A833 18spline, hard to put into 1st after being in neutral [Re: lilred] #2322153
06/16/17 02:21 PM
06/16/17 02:21 PM
So. Burlington, Vt.
So. Burlington, Vt.
I think I bought the Pennzoil at AutoZone or Advance.
Re: A833 18spline, hard to put into 1st after being in neutral [Re: lilred] #2322163
06/16/17 02:33 PM
06/16/17 02:33 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Were the shift forks replaced?
Does it grind when it finally goes into gear?
Page 1 of 4 1 2 3 4
