Re: sb oil slinger question
[Re: BlakDak]
#232170
02/22/09 12:12 AM
02/22/09 12:12 AM
RapidRobert
Modern timing cover oil seals are much better than old time ones but DEFINITELY put the timing cover on loosely then draw on the harmonic dampener part way onto the crank to center the timing cover then finish tightening the timing cover bolts cover bolts & at the same time useing the 2 lower oil pan to timing cover bolt to draw the tcover down onto the seal which will line up the timing cover bolts.
[Re: 69340Scoupe]
#232172
02/22/09 12:33 AM
02/22/09 12:33 AM
RapidRobert
take the tcover back off & drill a 1/64" oil hole into the pass oil gallery to get a pressurized spray onto the tchain/eccentric which fixes a SB weakness & will give them a long life, the dribble hole and or the drip tray did not provide enough lubrication over the long run in a stock app & definitely is inadequate for a performance engine. Pretty soon you'll be able to R&R the tcover blindfolded.
[Re: MoparforLife]
#232175
02/22/09 11:29 AM
02/22/09 11:29 AM
Posts: 2,533 God's Country Maryland
GODSCOUNTRY340
Take the timing cover off and put that slinger back on. It's main purpose is the lubricate the fuel pump eccentric and pump arm. (see picture). There's a reason the slinger is in direct alignment with the eccentric. It's NOT there to keep oil off the front seal, it needs oil on it to keep it from burning up. The seals made today from China are not better than the seals made back then in the USA. The only engines that didn't come with it were the fuel injected engines with electric fuel pumps. Put the slinger on or you'll be replacing the eccentric and fuel pump in a hurry.
[Re: MoparforLife]
#232178
02/22/09 01:24 PM
02/22/09 01:24 PM
GODSCOUNTRY340
The oil dripper is behind the timing gear so that oil doesn't reach the eccentric, it gets shielded by the cam gear. HP engines had windage trays to reduce oil fogging, so the slinger is there to help create that fog in the timing chain area. I didn't say the only reason was to oil the eccentric, I said it's the main reason. Big blocks have them to create the oil fog to lube the timing chain, gears and fuel pump pushrod. Think of the pressure that's put on the eccentric, it's steel spinning at 1,000- 3,000 rpms with a steel arm pressing on it with spring pressure, pumping a non compressible liquid (Gasoline). Imagine the heat build up there. It needs a lot of oil to lubricate and cool that area or it would burn up.
[Re: GODSCOUNTRY340]
#232180
02/22/09 02:21 PM
02/22/09 02:21 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
No not listening to a journalist but showing that some of us are of a different opinion than yours. I have been around this thing and was working the Mopar dealership and on race cars in the 60's too, so don't give me that longevity song and dance. If you feel that it is nessessary by all means use it. But they were not even on all the engines from the factory, they were skipped on many. Most recent being a virgin 440 last fall that didn't have one. Don't loose any sleep over not putting it in.
[Re: MoparforLife]
#232181
02/22/09 03:37 PM
02/22/09 03:37 PM
I've been "into" a few engines over my lifetime, and just cannot remember the last time I found one without a slinger. The factory put them there for a reason, and factories are not know for "throwing in extras" for free. If you were building an engine for me, I'd want the thing in there.
