Page 2 of 3 1 2 3
Re: '70 E-Body Ignition Key Light Wiring Question #232147
02/26/09 03:53 PM
02/26/09 03:53 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
2983713 is on the harness and is in the parts book.
3513427 is in the 70-71 & 72 parts books and is listed for a 71 & 72 E-Body.
Both are listed as - WIRING, Accessory Lamp, Map, Ignition Switch and Title Lamp.
One of the differences is the ignition lamp connector. I don't have a wiring diagram for the 71 or 72 cars, so I can't determine the other differences.
Re: '70 E-Body Ignition Key Light Wiring Question [Re: Snoopy] #232148
02/26/09 04:54 PM
02/26/09 04:54 PM
Snoopy Offline
Snoopy  Offline
Here is the wiring diagram for the 71 harness.
Re: '70 E-Body Ignition Key Light Wiring Question [Re: Snoopy] #232149
02/26/09 05:00 PM
02/26/09 05:00 PM
Snoopy Offline
Snoopy  Offline
It appears the only difference is the ignition light connector.
Re: '70 E-Body Ignition Key Light Wiring Question [Re: Snoopy] #232150
02/26/09 09:03 PM
02/26/09 09:03 PM
Land of 10,000 Lakes
44D6PAKCUDA Online content OP
44D6PAKCUDA  Online Content OP
Snoopy-The harness I got today has the 3513427 parts number tag still on it but has the '70 style bullet connector.Must have been a mid year change or something? Thank you for your help and diagrams!
Re: '70 E-Body Ignition Key Light Wiring Question [Re: 44D6PAKCUDA] #232151
02/26/09 10:02 PM
02/26/09 10:02 PM
Snoopy Offline
Snoopy  Offline
Just goes to show you, when it comes to Chrysler, the exception is the rule.
Re: '70 E-Body Ignition Key Light Wiring Question [Re: Snoopy] #232152
02/26/09 10:22 PM
02/26/09 10:22 PM
You said it! I just pulled out of my car what I thought was the correct A01 harness and after some comparing,it turns out to be the style with the spade connector for the key light.I'm glad I started checking into this as I had it incorrectly installed anyway.So I am either going to install the harness I got today with the correct connector or see if I can switch over the correct connector to what was a NOS 71 harness.
Re: '70 E-Body Ignition Key Light Wiring Question [Re: 44D6PAKCUDA] #232153
02/26/09 10:27 PM
02/26/09 10:27 PM
Snoopy-Forgot to ask one more question.What all plugs into the unique male/female spade connector that has the single yellow wire going into it,just off the side of the key light and the single bullet yellow w/black tracer wire? Thanks again
Re: '70 E-Body Ignition Key Light Wiring Question [Re: 44D6PAKCUDA] #232154
02/26/09 10:35 PM
02/26/09 10:35 PM
Snoopy Offline
Snoopy  Offline
Switch title lamp and the over head consolette wiring harness.
Re: '70 E-Body Ignition Key Light Wiring Question [Re: Snoopy] #232155
02/26/09 10:58 PM
02/26/09 10:58 PM
OK,that's what I thought.Just wanted to make sure.Just to check thou,the switch title light,is the light above the corner rallye dash switch panel and if I don't have an overhead console in the car,that connector stays empty correct? Thanks!
Re: '70 E-Body Ignition Key Light Wiring Question [Re: 44D6PAKCUDA] #232156
02/26/09 11:29 PM
02/26/09 11:29 PM
Snoopy Offline
Snoopy  Offline
Switch Title Lamp courtesy of BartekP
Re: '70 E-Body Ignition Key Light Wiring Question [Re: Snoopy] #232157
02/26/09 11:39 PM
02/26/09 11:39 PM
OK..I got a few thing backwards.So where does the far left side single light on the rallye dash light bar plug into??
Re: '70 E-Body Ignition Key Light Wiring Question [Re: Snoopy] #232158
02/26/09 11:40 PM
02/26/09 11:40 PM
Snoopy Offline
Snoopy  Offline
Consolette Wiring Harness. This isn't the overhead harness.
Re: '70 E-Body Ignition Key Light Wiring Question [Re: Snoopy] #232159
02/26/09 11:40 PM
02/26/09 11:40 PM
Snoopy Offline
Snoopy  Offline
Consolette Wiring Harness Plugs
Re: '70 E-Body Ignition Key Light Wiring Question [Re: Snoopy] #232160
02/26/09 11:42 PM
02/26/09 11:42 PM
So that's just if it is a console equipped car.
Re: '70 E-Body Ignition Key Light Wiring Question [Re: 44D6PAKCUDA] #232161
02/26/09 11:47 PM
02/26/09 11:47 PM
Snoopy Offline
Snoopy  Offline
Right, no overhead console, no extra wiring.
Re: '70 E-Body Ignition Key Light Wiring Question [Re: Snoopy] #232162
02/26/09 11:53 PM
02/26/09 11:53 PM
Got it.Can you help me out with my other question above about the rallye dash light bar light? Thanks Snoopy!
Re: '70 E-Body Ignition Key Light Wiring Question [Re: 44D6PAKCUDA] #232163
02/27/09 12:19 AM
02/27/09 12:19 AM
cataclysm80 Offline
cataclysm80  Offline
Wow, Great Thread!
Tav
Re: '70 E-Body Ignition Key Light Wiring Question [Re: 44D6PAKCUDA] #232164
02/27/09 01:07 AM
02/27/09 01:07 AM
Snoopy Offline
Snoopy  Offline
It plugs into the funny looking connector on the time delay wiring harness. Upper right hand corner.
Re: '70 E-Body Ignition Key Light Wiring Question [Re: Snoopy] #232165
02/27/09 01:50 AM
02/27/09 01:50 AM
Now I'm lost again.I thought the switch title light plug into that funny connector...help
Re: '70 E-Body Ignition Key Light Wiring Question [Re: 44D6PAKCUDA] #232166
02/27/09 01:54 AM
02/27/09 01:54 AM
Snoopy Offline
Snoopy  Offline
Both lights are called Title Lamps and they both plug into that connector.
Page 2 of 3 1 2 3
