wire diagram for one wire/trunk mounted #2321109
06/14/17 02:45 PM
06/14/17 02:45 PM
Suffolk County, New York
1mean340 Offline OP
1mean340  Offline OP
Hey guys, wiring is definitely not my thing and I was looking for a solid diagram for the proper wiring of a trunk mounted battery using a 1 wire GM 140 amp alternator on a mopar STREET car. I have read tons of posts and seen many diagrams when googling but there always seems to be some debate of whether or not any particular way is 'good' and many of the posts were geared towards making it NHRA compliant.
I'll be using a lot of accessories (electric fans, Fitech, MSD) and I'm also not so concerned with passing NHRA tech. I just want it to be safe on the street and not drain the battery when parked.
If anyone has a good diagram for this application, or can explain what they used on a similar setup I would greatly appreciate it!
Re: wire diagram for one wire/trunk mounted [Re: 1mean340] #2321116
06/14/17 02:54 PM
06/14/17 02:54 PM
Midwest
fuseable Offline
fuseable  Offline
Midwest
Lots of good info here.
http://www.madelectrical.com/
Re: wire diagram for one wire/trunk mounted [Re: 1mean340] #2321134
06/14/17 03:28 PM
06/14/17 03:28 PM
an8sec70cuda Offline
Run the wire from the alternator straight back to the positive post on the battery...or on that side of your master disconnect switch.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: wire diagram for one wire/trunk mounted [Re: fuseable] #2321169
06/14/17 04:34 PM
06/14/17 04:34 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
I Agree 100%
Re: wire diagram for one wire/trunk mounted [Re: fuseable] #2321175
06/14/17 04:48 PM
06/14/17 04:48 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
In particular, read this. http://www.madelectrical.com/electricaltech/onewire-threewire.shtml
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: wire diagram for one wire/trunk mounted [Re: 1mean340] #2321404
06/15/17 01:04 AM
06/15/17 01:04 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
If I was not concerned with NHRA tech AND/OR did not use a rear mounted master switch with a rear mounted battery, I would simply hook the power lead from the alternator to a battery positive lug or junction in the engine compartment, most likely at the starter relay if the wiring is mostly OEM. Many racers did this for years (including me) because it was easy, until NHRA decided to start checking and enforcing the "stop all electric functions" part of the rule pertaining to master switches.
Re: wire diagram for one wire/trunk mounted [Re: 1mean340] #2321443
06/15/17 02:22 AM
06/15/17 02:22 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Just use a dual (4 terminal) cutoff switch like the Moroso 74102
http://www.jegs.com/i/Moroso/710/74102/10002/-1
