How much power can a stock Hellcat short block take #2319908
06/12/17 02:38 PM
06/12/17 02:38 PM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
Just thinking of a future turbo project.
So what can the hellcat short block handle?
Re: How much power can a stock Hellcat short block take [Re: Dart451] #2319942
06/12/17 03:22 PM
06/12/17 03:22 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I imagine it can handle quite a bit. Plenty of the factory non HC blocks are making 1,000+ hp.
- Stu Harmon
Re: How much power can a stock Hellcat short block take [Re: Dart451] #2319989
06/12/17 04:44 PM
06/12/17 04:44 PM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
Seems like a good price for a 1000+ hp short block. The aftermarket big block are getting $$.
Re: How much power can a stock Hellcat short block take [Re: Dart451] #2320059
06/12/17 06:32 PM
06/12/17 06:32 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Yeah I don't know why people are buying stroker kits for 5.7s, they cost as much as a hellcat short block brand new from the dealer ready to drop in. All the extra money machining and time assembling for another 200 CC and your local machine shop probably ain't as acurate as the factory? It also seems I heard the 6.4 truck engine was all forged guts, it should be a good turbo build also around the same price.
Re: How much power can a stock Hellcat short block take [Re: Dart451] #2320066
06/12/17 06:47 PM
06/12/17 06:47 PM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
I have a lot to learn on modern hemi.
I was thinking the 6.4 crate engine would be a good starting combo also. Gives me everything and might be cheaper to swap good forged pistons then piece the rest of the hellcat short block together.
Planning on a MS for controlling everything.
Re: How much power can a stock Hellcat short block take [Re: Dart451] #2320230
06/12/17 10:59 PM
06/12/17 10:59 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
For boost any stock pistons other than the Hellcat are a roll of the dice with the top ring locations. The Hellcat pistons are good but also have the top ring moved down lower. There are some out there in the 1300 hp already with un-opened bottom ends. Pretty cool IMO.
Mopar to the bone!!!
Re: How much power can a stock Hellcat short block take [Re: Dart451] #2320249
06/12/17 11:28 PM
06/12/17 11:28 PM
gregsdart Offline
gregsdart  Offline
Considering the power it takes to turn the blower, and accessory losses, I bet those Hellcat shortblock and head assembly's would take a whole lot more than we think.
They are built to withstand long periods of full boost, and long life to boot.
Re: How much power can a stock Hellcat short block take [Re: gregsdart] #2320305
06/13/17 12:44 AM
06/13/17 12:44 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
The problem is the VVT. You can lock out the cam phaser but only the factory timing set is available. Im looking at making a cam adapter to use a non-VVT cam in a VVT block using the 6.1 double roller timing set.
Re: How much power can a stock Hellcat short block take [Re: Dart451] #2320325
06/13/17 01:06 AM
06/13/17 01:06 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
So if you're a gen 3 rookie like me, how can
I use this HC short block?? Will my Eagle heads bolt on?
What carb intake works?
Will front covers interchange?
Re: How much power can a stock Hellcat short block take [Re: fbs63] #2320385
06/13/17 07:59 AM
06/13/17 07:59 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Like this one?
http://www.ebay.com/itm/HEMITRONIX-5-7-6-4-HEMI-VCT-VVT-AND-MDS-ELIMINATOR-CAM-KIT
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: How much power can a stock Hellcat short block take [Re: cudadoug] #2320388
06/13/17 08:08 AM
06/13/17 08:08 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
your Eagle heads will bolt on to a HellCat short block.
There are a intakes out now, you have the Drag pak, Arrow Racing has a new single plane out now and OCP has had a dual plane out for awhile.
Eagle front cover Yes , pre 09 I'm not sure.
Re: How much power can a stock Hellcat short block take [Re: ric3xrt] #2320432
06/13/17 09:58 AM
06/13/17 09:58 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Yes, but I don't like the fact it just pilots off the spocket boss. I will probably turn the first bearing journal down and machine one for a press fit.
Re: How much power can a stock Hellcat short block take [Re: fbs63] #2320460
06/13/17 11:13 AM
06/13/17 11:13 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Sounds good, I like your Idea better .
I have the above kit in a 2014 6.4 short block I'm not to keen on how the kit,like you said pilots of the sprocket.
Re: How much power can a stock Hellcat short block take [Re: ric3xrt] #2320485
06/13/17 11:54 AM
06/13/17 11:54 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
One question. Does it use the vvt guide and tensioner or the 6.1?
Re: How much power can a stock Hellcat short block take [Re: Dart451] #2322314
06/16/17 08:03 PM
06/16/17 08:03 PM
Australia
L4staero Offline
L4staero  Offline
Australia
There is lots of cars making 900 whp but i think at that level the rods and pistons can be a ticking time bomb mainly the powdered metal rods. I would leave it at 800 fhp and call it good. I looked into it myself but want something with long term worry free reliabilty so chose to start with a BGE/Hellcat block, 6.4 truck crank and H beams/forged pistons
Re: How much power can a stock Hellcat short block take [Re: Dart451] #2323696
06/19/17 05:08 PM
06/19/17 05:08 PM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
I need to decide on power level. Think 800 fhp, I would be happy for the car its going in. 70 Dart no cage right now it has 517 big block in it
Re: How much power can a stock Hellcat short block take [Re: fbs63] #2323713
06/19/17 05:39 PM
06/19/17 05:39 PM
cudadoug Offline
cudadoug  Offline
Boy, oh boy...that would be a big help on these motors!
Re: How much power can a stock Hellcat short block take [Re: Dart451] #2333691
07/08/17 04:49 PM
07/08/17 04:49 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
There is a few cats that are putting 1050 to back tires. Was one that went for just a tad more and it blew.... so 1000 at the crank and you will be just fine
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
