Hi, so I'm in the process of restoring a 69' R/T SE Charger I'm missing the build sheet and data plate for my car and I came across a set of power windows off a car I parted out so I thought this would be a perfect car to add them onto. Only the missing(I think) is the wiring harness, previous owner cut it up and threw it out..... would I be able to just find a c body, yank the harness and put it into my car? Or does anyone reproduce the harness? Is it worth doing the conversion? Any advice on a solution for the wiring harness would be greatly appreciated.
