tube flarring tools #2320175
06/12/17 09:27 PM
06/12/17 09:27 PM
btomasko Offline OP
btomasko  Offline OP
Whats a good and easy tube flaring tool ridgid #377 or #23337 or some other brand Thanks
Re: tube flarring tools [Re: btomasko] #2320217
06/12/17 10:44 PM
06/12/17 10:44 PM
A cheapie will work good for single flares. here's a BTT for ya.
Re: tube flarring tools [Re: btomasko] #2320238
06/12/17 11:07 PM
06/12/17 11:07 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ive used my Blue Point from Snapon for over 30 years.Cant beat itfor double and single flares.Ive done probally thousands of flares at work and home with it. Rocky
Chrysler Firepower
Re: tube flarring tools [Re: therocks] #2320264
06/12/17 11:43 PM
06/12/17 11:43 PM
Medford OR
FrankenScamp Offline
Medford OR
I replaced all of my brake and fuel lines myself. All with a cheap harbor freight kit.
I think it's a little less about the tools, and a little more about the user's attention to detail.
Good luck beer
Re: tube flarring tools [Re: btomasko] #2320299
06/13/17 12:35 AM
06/13/17 12:35 AM
DE
Ply72rr Offline
Ply72rr  Offline
DE
https://www.amazon.com/Mastercool-71475-PRC-Universal-Hydraulic-Flaring/dp/B007TN15EG
This is what I use, it's too expensive if you're only going to use it one time but if you plan to make many brake/fuel lines in the future it is worth it. It will make inverted flares, bubble flares, and push connect lines and it's easy to use.
Re: tube flarring tools [Re: FrankenScamp] #2320320
06/13/17 12:57 AM
06/13/17 12:57 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Good luck beer
Lots of truth here.
I have 3 flare tools of various pedrigree. They all will only flare as good as I prep.
Re: tube flarring tools [Re: Ply72rr] #2320323
06/13/17 01:05 AM
06/13/17 01:05 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I love my Mastercool setup. Most other flaring tools are not intended for thick wall tubing and will offset the flare or create a crooked sealing surface. You find this out the hard way with stainless lol.
Re: tube flarring tools [Re: therocks] #2320395
06/13/17 08:41 AM
06/13/17 08:41 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Me too, my first and best set came from Snap on and has blue point on the tool. It is actually made by Imperial Eastman and is the best there is in tubing tools.
Since then I lent it out and a couple of the inserts got lost, helped me decide years ago not to lend tools out no more.
I still lend out my engine lifting chain about 3-4 years ago and I can't remember for sure who I lent it out to. When will I learn not to lend out tools? tsk Now I need it.
Re: tube flarring tools [Re: btomasko] #2320405
06/13/17 08:54 AM
06/13/17 08:54 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Imperial.
Re: tube flarring tools [Re: Mattax] #2320429
06/13/17 09:52 AM
06/13/17 09:52 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Originally Posted By Mattax
Imperial.
^^ This ^^
Re: tube flarring tools [Re: btomasko] #2320437
06/13/17 10:22 AM
06/13/17 10:22 AM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
I picked up a USA-made Cal-Van set cheap off of Ebay and it worked fine for me when I redid all the brake lines in my '55 Plymouth.
Re: tube flarring tools [Re: justinp61] #2320439
06/13/17 10:25 AM
06/13/17 10:25 AM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
One nice thing about the Mastercool is you can make flares on the car. By the time you buy a good 45 and 37 flaring tool the Mastercool is not that expensive.
I just have cheap flaring tools that a friend gave me and they work fine for single flares with mild steel.
Re: tube flarring tools [Re: btomasko] #2320486
06/13/17 11:55 AM
06/13/17 11:55 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Challanger I broke a few of the inserts but they were warrantyed.I bet in the last 30 plus years Ive flared more lines than people could count.The rust belt is rough onlines.My kid bought a setup at Summit for like 10 bucks.It was clearance and works OK also.Rocky
Chrysler Firepower
Re: tube flarring tools [Re: therocks] #2320499
06/13/17 12:22 PM
06/13/17 12:22 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Ah yes the rust belt. What memories I have from childhood. Brake lines and exhaust systems were good for 3-7 years lol.
Since I moved out West everybody brings me there broken off bolts and stuck plug repair jobs. No coincidence there.
I will also agree that the ability to flare line on the car usually makes for a nicer finished product and/or quicker repair. The user will have long forgotten the three hundred bucks they spent years later when the tool is ready to work sitting on the shelf.
I looked at the Imperial catalog and all of there flaring sets are for thin wall tubing from what I can tell.
Re: tube flarring tools [Re: Jeremiah] #2320515
06/13/17 12:53 PM
06/13/17 12:53 PM
dogdays Offline
dogdays  Offline
First of all use 90/10 copper-Nickel alloy for the tubing. It's easier to flare, doesn't rust and isn't that expensive. It's used by many auto makers.
Second if you're fabricating lines off the car, then the expensive Eastwood tool looks nearly foolproof.
Third, Buy the best tool you can afford. If the little tubing holder teeth weren't formed properly and the tube slips backward as you apply pressure, it isn't much of a tool, is it?
I don't care if some of you are able to make double flares in steel tubing using a tool from the "all tools $4.98" bin, it doesn't work that way for me.
Fourth, the Imperial Eastman tool has been the standard of the industry for about a century. The max wall thickness they list matches nicely with DOT approved brake line sizes. See below. First are DOT approved sizes, second is the max wall thickness chart from Imperial Eastman.
R.
Re: tube flarring tools [Re: Ply72rr] #2320530
06/13/17 01:24 PM
06/13/17 01:24 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Had my eye on that one for a long time...need....thanks for the reminder
Rich H.
Esse Quam Videri
Re: tube flarring tools [Re: ZIPPY] #2320569
06/13/17 02:48 PM
06/13/17 02:48 PM
Cincinnati, Ohio
Cincinnati, Ohio
A tip for using the old fashioned/traditional flaring tool.
It is important how you approach the clamp job. You want the short side of the tool clamped down first and use the long end of the clamp to tighten it down last where you have more leverage. You don't always want the clamp bottomed out, if you do you can distort the tubing.
By doing this way one can even get most cheapo ones to work enough for a while on steel double flaring until the tool wears out and becomes worthless. Won't happen with a I Eastman tool.
Re: tube flarring tools [Re: RTSE4ME] #2320585
06/13/17 03:12 PM
06/13/17 03:12 PM
Cincinnati, Ohio
Cincinnati, Ohio
Who uses single flares on steel? Not a good idea because of the seam on steel tubing and why double flares are used.
Now single flares in soft tubing is the normal in like copper and aluminum.
I have made many AN aluminum lines with my 45° flaring tool. The type of fitting where you slide on a nut and then a 37° fule on aluminum tubing. I flare the aluminum to 45° and when I tighten it down the first time it is flared the last 7° against the fule and male AN fitting. Have done it dozens of times and never had one problem.
So you do not need a separate 37° flaring tool for soft line AN tubing work.
Re: tube flarring tools [Re: Ply72rr] #2320586
06/13/17 03:15 PM
06/13/17 03:15 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
I use one of those and still have an occasional flare leak on brake lines; lapping the flare ensures a good seal.
http://www.jegs.com/i/KOUL-tools/581/P45/10002/-1
Re: tube flarring tools [Re: Challenger 1] #2320647
06/13/17 05:03 PM
06/13/17 05:03 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
Stainless steel fuel line to AN?
