Some Pro Comp "Victor" stuff.....
#2319050
06/10/17 06:26 PM
06/10/17 06:26 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
This is a good argument for, if you're buying heads from somewhere other than a shop known for quality cylinder head prep..... It's probably a good idea to have someone familiar with what you're building to have a look at them before bolting them on.
This set was bought from some interweb seller, and just bolted on. There has been some porting done, so perhaps the seller made the impression they were a head shop.
They had been run before they came into my shop........ And had already had a problem.
Unfortunately, nobody picked up on this before they got bolted on......
1.88 ex/2.25 int......... Not quite enough room for that combo. Additionally, they're the wrong length....... About .250 too long, which I'm sure contributed to the severely worn guides. A couple were bell mouthed out to about .009 clearance at the top and bottom.
Re: Some Pro Comp "Victor" stuff.....
[Re: fast68plymouth]
#2319053
06/10/17 06:32 PM
06/10/17 06:32 PM
fast68plymouth
So. Burlington, Vt.
Another nice touch was the valve seats weren't machined for those valve sizes. The heads are supposed to use 2.20/1.81 valves, and the valve job is a little "small" for even those valves. So, when you stick your 2.25/1.88 valves on those seats, the contact pattern runs right off the inner edge of the valve. If the valves that came with the heads had narrower faces, like what some of the "better" valves have, there would have been essentially no interface of the 45deg seat angle.
The thin grey line is the lap line......
#2319058
06/10/17 06:42 PM
06/10/17 06:42 PM
fast68plymouth
So. Burlington, Vt.
So, you have valves almost touching each other, and rocker geometry that's less than optimal because the valves are .250 too long......... The guides get worn out...... And the valves are all clipping each other. Pretty good witness marks on all the valves from this going on for a while.
Well....... That can only go on for so long before........ A valve breaks.
The owner pulls the heads and has a shop start on the repairs, but for one reason or another the progress comes to a halt, and then the heads sit for what I believe is a couple of years.
When they show up at my shop the welding is already done, but that's about it.
#2319061
06/10/17 06:50 PM
06/10/17 06:50 PM
fast68plymouth
So. Burlington, Vt.
The first step was to replace the damaged guides. The two from the damaged cylinder, and the intake next to it had been removed.
These heads use guides with an odd sized OD, and I think the previous shop pulled the one to see what size it was. At this point, I hadn't really looked at the rest of the head too closely, and just took 3 larger OD guides I had here, and turned them down to fit the hole in the head. After that was done, and they were sized, I got to the business of installing the seats.....
#2319062
06/10/17 06:55 PM
06/10/17 06:55 PM
fast68plymouth
So. Burlington, Vt.
Actually, after the guides were in, I flat milled the head to give me a good surface to work from and get the head flat after all the welding.
Intake seat install.....
#2319063
06/10/17 06:58 PM
06/10/17 06:58 PM
fast68plymouth
So. Burlington, Vt.
After the seats are installed, I roughed in the chamber, and roughed in the valve job. At this point I basically just matched what the other seats had, since it was unclear how much further I would be taking this head other than finishing the repair.
#2319099
06/10/17 09:31 PM
06/10/17 09:31 PM
fast68plymouth
So. Burlington, Vt.
There wasn't quite enough weld near the seats on the quench side of the chamber to get it to look better. I blended the bottom of the seat inserts into the bowls, and hit the chamber with a sanding roll, and kissed the seats with a stone. At this point....... The repair portion of getting these heads ready to use was done.
#2319104
06/10/17 09:41 PM
06/10/17 09:41 PM
fast68plymouth
So. Burlington, Vt.
The decision was made to go ahead and fix the other issues and make the castings usable. This meant 13 more guides, machine the seats, flat mill the other head.
When I recut the seats, the 45 got pushed out quite a bit from how it was done originally, which required another angle be added below the bottom angle to help get a better transition into the bowl. Even with the bowl cut, there was a pretty noticeable ridge where the casting ended and the machining started, so that was going to need to be blended in so they wouldn't lose flow from how they were before.
The other three exhaust seats on the damaged head were severely corroded. Initially I was thinking I could just sink the valves a little and get into some new material, but after looking at them closer, and since some $$$ had been spent fixing some other issues, and the fact that the other head didn't have this problem, I just decided to replace those 3 seats.
#2319109
06/10/17 09:53 PM
06/10/17 09:53 PM
fast68plymouth
So. Burlington, Vt.
Here's a pic of the same cylinder as the first pic with the valve seats cut and the correct 2.20/1.81 valves. Plenty of space between them.
And a pic of the damaged cylinder all done. Not super pretty, but it should work okay.
As mentioned previously, these heads already had some port work done to them, otherwise it wouldn't have paid to fix it. To fix the one head was about 1/2-2/3's the cost of buying a new head and porting it an amount equal to what was done already.
Finished product(not the damaged cylinder, although I think it would be pretty much the same), still std port window:
Lift---------in/ex .100---73.1/ 56.5 .200--151.2/97.6 .300--205.7/139.5 .400--260.6/173.2 .500--302.9/205.4 .550--316.7/215.4 .600--324.2/224.9 .650--334.7/228.6 .700--342.2/235.1 .750--342.9/238.8
#2319112
06/10/17 09:54 PM
06/10/17 09:54 PM
Posts: 2,867 Pattison Texas
CSK
Pattison Texas
WOW spending some pretty good money on these. great work !!!!
#2319116
06/10/17 10:12 PM
06/10/17 10:12 PM
fast68plymouth
So. Burlington, Vt.
If there is a lesson here, I think it's that if these heads had been properly prepped prior to being installed....... a good valve job, guide clearances set, had the correct size valves installed(diameter and length)....... It's very likely this never would have happened and they'd still be on the motor today.
#2319120
06/10/17 10:19 PM
06/10/17 10:19 PM
Posts: 2,467 Sydney,Australia
tex013
Sydney,Australia
Wow a lot of work . Good work .Thanks for sharing Dwayne
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
#2319154
06/10/17 11:20 PM
06/10/17 11:20 PM
Posts: 1,361 Wild West
M_D
Wild West
Doing it right the first time is always the cheapest and easiest.
[Re: ProSport]
#2319366
06/11/17 12:20 PM
06/11/17 12:20 PM
Posts: 1,051 The Great White North
RAMM
This is a great thread with REAL tech info. Thankyou Dwayne.
Do you heat the head at all when installing the seat or do you just add "crush"? Just curious. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
