Megasquirt wiring question #2318959
06/10/17 02:26 PM
06/10/17 02:26 PM
Mesa, AZ
cagebob1 Offline OP
cagebob1  Offline OP
Mesa, AZ
Hooking up my MSPRO on my Hemi and I have a question for those with experience in these matters. The CKP sensor ...MS wiring diagram calls for 12 volt switched power, while the factory uses 5 volt reference. Will the factory sensor live on 12 volts? will MS function properly if I use the 5 volt reference for power to this(and the CMP) sensor?
Thank You bow
Re: Megasquirt wiring question [Re: cagebob1] #2319205
06/11/17 12:37 AM
06/11/17 12:37 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Not a Gen III car but I am using 5v for my crank sensor and cam sensor on my MS3X injected small block. No issues there.
68 Barracuda Formula S 340
Re: Megasquirt wiring question [Re: cagebob1] #2319346
06/11/17 11:39 AM
06/11/17 11:39 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Make sure your diagram or whatever you are referencing is the latest revision. I am pretty sure it needs 5v, I would definitely hesitate putting 12v to any engine sensor.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Megasquirt wiring question [Re: GoodysGotaCuda] #2319704
06/12/17 02:23 AM
06/12/17 02:23 AM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
Pretty sure I'm using 5v reference on mine.
Re: Megasquirt wiring question [Re: cagebob1] #2320024
06/12/17 05:44 PM
06/12/17 05:44 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Use the 5v. I used 5v on my ms3x, as directed by diyautotune.
My wiring is all posted here (and the 12v ref is on this diagram as well, but NOT what I did)
My link:
http://www.forabodiesonly.com/mopar/threads/how-to-megasquirt-your-3g-hemi.226125/
Diyautotune link:
https://www.diyautotune.com/support/tech/install/chrysler-dodge/megasquirt-your-hemi/
Who did you buy from? What did they say?
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: Megasquirt wiring question [Re: Uhcoog1] #2320122
06/12/17 08:01 PM
06/12/17 08:01 PM
Mesa, AZ
cagebob1 Offline OP
cagebob1  Offline OP
Mesa, AZ
Purchased from diyautotune, the 12v reference didn't sound right to me ... that's why I posted the question. Based on the replies, I have connected crank,cam, and tps sensors to 5v reference voltage circuit. Thank You to all that have replied. Can't wait to fire this thing up!
