Trick flow 270 with max wedge cross ram #2318934
06/10/17 01:31 PM
06/10/17 01:31 PM
Texas
dannysbee Offline OP
Texas
Anyone mocked up a set of the 270's with a max wedge cross ram yet? Any issues?
Getting old just means you were smarter than some and luckier than others.
Re: Trick flow 270 with max wedge cross ram [Re: dannysbee] #2319113
06/10/17 09:55 PM
06/10/17 09:55 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Stock Intake looks like it with hit the valve cover rail area above the ports on the TF heads.
The only Carbs I care about are under the hood!
Re: Trick flow 270 with max wedge cross ram [Re: dannysbee] #2319134
06/10/17 10:44 PM
06/10/17 10:44 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The 270's have the raised/extended intake runner, like the Indy heads.
The stock mw intake should fit, but there will be a gap on the end rails that will need to be filled.
