Re: Ringing Sound? Any help?! [Re: moparfury1970] #2318692
06/09/17 10:30 PM
06/09/17 10:30 PM
NEW JERSEY
moparfury1970 Offline OP
NEW JERSEY
Thanks for your patience and information. I tightened the pinion nut very tight. The drive shaft I ordered came with greased ujoints. They fit perfectly in the axle yoke kit. Like I said, everything I installed fit perfectly. No resistance.
Re: Ringing Sound? Any help?! [Re: amxautox] #2318694
06/09/17 10:33 PM
06/09/17 10:33 PM
Kirkland, Washington
Pacnorthcuda Offline
Originally Posted By amxautox
Did you do anything with/to the pinion gear nut on the rearend that you put it? Anything to the ring gear? Did you take out the pig at all?
No, I didn't touch the anything in the stock rear end. Didn't touch the ring gear. I literally bought a new 7290 axle yoke kit from Year One and a drive shaft and took the original rear end that came with the car when I bought it, the stock gears and assembled. I probably sound like an idiot, but I'm just trying to learn.
That's how you learn, by doing it, and asking about it. So you installed the yoke kit, but didn't torque the pinion nut when you installed it. How tight did you get the pinion nut? Very tight, VERY tight, or sorta tight?
And that axle yoke kit, is that a yoke and u-joint, or just the two sized u-joint?
Now we're getting somewhere...do NOT drive the car. As Tom is asking above, we need to know your method of torque on that yoke/pinion nut. Unless you match marked the nut's position relative to the pinion shaft I am afraid you are looking at more education. We also need to know what rear it is..489? 742? 741?
Re: Ringing Sound? Any help?! [Re: moparfury1970] #2318696
06/09/17 10:38 PM
06/09/17 10:38 PM
NEW JERSEY
NEW JERSEY
I believe it is a 742, but am not 100% sure. I've driven it twice now with no issue, but am I looking at a catastrophic failure in the near future with those noises? I initially used an air wrench and then tightened it with a wrench
Re: Ringing Sound? Any help?! [Re: moparfury1970] #2318701
06/09/17 10:48 PM
06/09/17 10:48 PM
Well, a 742 is MUCH more forgiving given your scenario than a 489... But it still takes a LOT of torque..240lbs if I recall correctly. Not easy to do, but the difference between an undertorqued 742 and a 489 is massive in terms of potential howl/whine. Meaning I don't think your torque on the pinion nut is the issue.
If it's truly a 742 or 741
Re: Ringing Sound? Any help?! [Re: moparfury1970] #2318702
06/09/17 10:49 PM
06/09/17 10:49 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Chances are the air wrench tightened it to about 50 foot pounds, depending on the air wrench of course, and how big it is. The proper torque is about 200 to 250 if I remember correctly, but I'd have to look it up, been a few years.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Ringing Sound? Any help?! [Re: Pacnorthcuda] #2318703
06/09/17 10:50 PM
06/09/17 10:50 PM
NEW JERSEY
NEW JERSEY
Gotchya. How do you differentiate between the 489, 742 and 741. Casting numbers?
Re: Ringing Sound? Any help?! [Re: moparfury1970] #2318704
06/09/17 10:52 PM
06/09/17 10:52 PM
amxautox Offline
amxautox  Offline
Yup, the last 3 digits of the numbers on the side of the case.
Tom
author unknown
Re: Ringing Sound? Any help?! [Re: moparfury1970] #2318708
06/09/17 10:54 PM
06/09/17 10:54 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
A 741 or 742 you can torque.A 489 with the crush collar and a new yoke would be tough to get back to the same spec it was.The noise while coasting,but gone when accelerating I'm thinking pinion bearing.It may be frome the yoke torque being off, but the bearings could also have rust or pitting from sitting a length of time dry.
RT
Re: Ringing Sound? Any help?! [Re: moparfury1970] #2318709
06/09/17 10:54 PM
06/09/17 10:54 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Stop using the word literally, you don't know what it means.
Don't be the exception.
Re: Ringing Sound? Any help?! [Re: moparfury1970] #2318711
06/09/17 10:56 PM
06/09/17 10:56 PM
NEW JERSEY
NEW JERSEY
Well, I just looked and its a 489! (2881489) Now I'm worried from what you said.
Re: Ringing Sound? Any help?! [Re: Supercuda] #2318716
06/09/17 11:01 PM
06/09/17 11:01 PM
NEW JERSEY
NEW JERSEY
Everyone else on here is being helpful with information. I'm trying to learn from the car vets on here. You are absolutely no help being the grammar police or making rude comments.
Re: Ringing Sound? Any help?! [Re: moparfury1970] #2318719
06/09/17 11:04 PM
06/09/17 11:04 PM
NEW JERSEY
NEW JERSEY
Thanks to RTSrunner, Pacnorthcuda and amxautox. You guys have been incredibly helpful. Thanks for your patience.
Re: Ringing Sound? Any help?! [Re: moparfury1970] #2318722
06/09/17 11:20 PM
06/09/17 11:20 PM
Well, being a 489 means you have a "crush sleeve" on the pinion that determines bearing preload on the pinion. You certainly did not replicate this on the yoke replacement. That's not easy to do even if you know what you are doing.
Do not drive it. Your looking at a pig removal, pinion removal, new sleeve or spacer upgrade and reassembly. A fair amount of work.
I suppose as a last ditch, you could try checking for pinion slop (for/aft) and torquing till that's gone, but that's a pretty shade tree approach!
Re: Ringing Sound? Any help?! [Re: moparfury1970] #2318723
06/09/17 11:25 PM
06/09/17 11:25 PM
NEW JERSEY
NEW JERSEY
Thank you so much for your input, advice and information. I sincerely appreciate the time and patience.
Re: Ringing Sound? Any help?! [Re: Pacnorthcuda] #2318726
06/09/17 11:27 PM
06/09/17 11:27 PM
amxautox Offline
amxautox  Offline
Or buy a kit and replace the crush sleeve with a solid sleeve and thin spacers, but that is a lot of work also. Measuring, taking it back apart, putting in another spacer and assembling, and measuring, and doing it again, and again until you get the back lash proper. It's one of those things I'd probably have a shop do. I guess they still have those solid spacer kits for that pumpkin/pig.
Tom
author unknown
Re: Ringing Sound? Any help?! [Re: amxautox] #2318728
06/09/17 11:28 PM
06/09/17 11:28 PM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
or simply call Dr. Diff, bite the bullet, and get one of his ready to bolt in nodular pigs and be done with it.DO NOT SHOP AROUND OR CALL ANYONE ELSE. you will be so much happier!
Re: Ringing Sound? Any help?! [Re: moparfury1970] #2318729
06/09/17 11:32 PM
06/09/17 11:32 PM
NEW JERSEY
NEW JERSEY
THANKS GUYS!
Re: Ringing Sound? Any help?! [Re: moparfury1970] #2318730
06/09/17 11:35 PM
06/09/17 11:35 PM
amxautox Offline
amxautox  Offline
I remember the first time I did a rear gear assembly. Reset the ring and pinion on my '67 Mustang after blowing the spider gears. I had to take it all apart in the winter in Illinois. Got it back together and talk about HOWLING!!! eek laugh2
Broke the side gears again, and did a better job the second time. grin
Tom
author unknown
Re: Ringing Sound? Any help?! [Re: Supercuda] #2319067
06/10/17 07:21 PM
06/10/17 07:21 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
LITERALLY LITERALLY LITERALLY LITERALLY LITERALLY LITERALLY LITERALLY LITERALLY LITERALLY ......Ooooohhhh......I can't stop.....LITERALLY.....Aargh
