Is this fuel system adequate? #2318094
06/08/17 02:41 PM
06/08/17 02:41 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
I'm beginning to piece together the fuel system for my street/strip 66 Dart. It'll eventually have a 600-650hp stroked big block.
After thinking about it some, the pump and filter would be near the fuel cell on the frame rail, running to the carb via 1/2" aluminum hard line, then to a bypass regulator and finally returning to the cell via another 1/2" aluminum hard line.
Would this fuel system be adequate? I already have many of the pieces. Is there anything you would change (parts, or hose/line sizing)?
Thanks!
Re: Is this fuel system adequate? [Re: mopowers] #2318096
06/08/17 02:56 PM
06/08/17 02:56 PM
I don't remember how much pressure that fuel pump makes but I would want the fuel regulator in line in front of the carb. and the second fuel filter to be 10 microns mounted between the regulator and carb. twocents
I have used one of the Mallory 140 pumps with the regulator that Mallory sold with it and it was marginal on a smaller 440 bracket motor under 600 HP shruggy
Maybe a better, bigger pump is needed now instead of finding out later it isn't good enough work up
Re: Is this fuel system adequate? [Re: mopowers] #2318126
06/08/17 04:30 PM
06/08/17 04:30 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
If you're running 1/2" why would you put that piece of 3/8" between the filter and the pump? The regulator needs to be in front of the carb and -6 is fine to the carb. -6 would also be fine for the return. That system will be fine for the street but a 10 sec. car will probably zero the gauge going down the track.
Re: Is this fuel system adequate? [Re: Dave Hall] #2318136
06/08/17 05:00 PM
06/08/17 05:00 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Thanks for the input Cab. Since I have the pump already, I'll probably give it a try and, if it's inadequate, I'll sell it and swap to a bigger pump. Thanks again.
Are you referring to the piece of -8 to supply the pump? Should I step that up to -10?
Thanks for the input. So, placing the regulator in front of the carb would be better. I've always thought after the carb is best since it keeps fresh (cooler) fuel feeding the carburetor, especially in a street car. When at the track, does it not regulate pressure as well in that configuration? Thanks again.
Re: Is this fuel system adequate? [Re: mopowers] #2318139
06/08/17 05:09 PM
06/08/17 05:09 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
looks like the way you have it drawn, the regulator will only regulate pressure in the return line, carb will see full pump pressure...
EDIT: oh nvm, did some quick reading, seems the pressure is constant in the whole fuel system no matter where the regulator is.
Re: Is this fuel system adequate? [Re: mopowers] #2318141
06/08/17 05:15 PM
06/08/17 05:15 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
That drawing should work perfectly. Sizes and placement of the regulator are fine assuming using the correct regulator. Much more flow to the carb with this set up. You would possibly be better off with -10 between the filter and pump.
Re: Is this fuel system adequate? [Re: mopowers] #2318156
06/08/17 05:59 PM
06/08/17 05:59 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I don't think that's going to work, you're going to have full fuel pump pressure at the carburetor that way. The regulator needs to be moved.
Rich H.
Esse Quam Videri
Re: Is this fuel system adequate? [Re: mopowers] #2318169
06/08/17 06:29 PM
06/08/17 06:29 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Looks good to me, I would use #10 between filter and pump. I ran a very similar set up for many years, went 9.60s with it in a 3400 lb car. People don't understand that it is designed to keep 7 lbs of pressure in front of regulator.(or whatever you set it to) It won't see high pressure like they think. It was the most steady pressure system I ever had on my car.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Is this fuel system adequate? [Re: 1967dartgt] #2318172
06/08/17 06:38 PM
06/08/17 06:38 PM
an8sec70cuda Offline
iagree
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Is this fuel system adequate? [Re: mopowers] #2318175
06/08/17 07:06 PM
06/08/17 07:06 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
you have the regulator in the correct place for a return system !!!
I have & do run this set up like your picture.
Re: Is this fuel system adequate? [Re: mopowers] #2318187
06/08/17 07:34 PM
06/08/17 07:34 PM
Can , Nova Scotia , Cape Breto...
caper Offline
caper  Offline
With the way you have it drawn in the pic is the way you should do it, just change the short line between the filter and fuel pump, make it bigger. The pressure is going to be the same from the regulator back to the pump.
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
Re: Is this fuel system adequate? [Re: mopowers] #2318190
06/08/17 07:37 PM
06/08/17 07:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The system looks fine... the #8 before the pump I
might change to a #10... make sure the filter will
flow the amount needed.. other than those little
things your fine.. on the section of #8 I just like
to have the first restriction at/or near the carb...
as for the pump.. rule of thumb is .5 pounds per HP
and your safe
wave
Re: Is this fuel system adequate? [Re: Dave Hall] #2318205
06/08/17 08:35 PM
06/08/17 08:35 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
I thought -8 was the AN equivalent to 1/2" OD tube. Wouldn't hurt to go bigger it is probably fine.
Re: Is this fuel system adequate? [Re: Blusmbl] #2318216
06/08/17 08:57 PM
06/08/17 08:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
#8 is equal to 1/2"... 3/8" is a #6
wave
Re: Is this fuel system adequate? [Re: an8sec70cuda] #2318257
06/08/17 10:27 PM
06/08/17 10:27 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
iagree
absolutly agree, I switched to that system several years ago and has worked flawless every since, just change that smaller line between the filter and pump and you will be golden. up
Re: Is this fuel system adequate? [Re: mopowers] #2318394
06/09/17 10:48 AM
06/09/17 10:48 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Thanks!
My twocents
I would use a 100 micron strainer in the outlet fitting in your fuel cell and do away with the 100 micron housing because you want a smooth flow of gas to the pump. A filter housing on the inlet side of the pump is not a good idea because it interrupts smooth gas flow to the pump and can cause cavatation. If you do use it keep it away from the pump so the gas has time to smooth out before getting to the pump. It really is a bad idea, a separate pre filter. Just more places for the fuel to heat up and weighs more too.
Use at least all #10 to the pump with #12 being better on the suction side. Minimize any restrictions(smooth fittings and try not to use 90s. Or at least tube 90s) on the inlet side and the fuel pump must be lower than the fuel cell. Can't suck up hill or even level can cause cavatation.
Pressure regulator is in the right place and you only need #6 coming out of the pump. It is a disadvantage to have it oversize because it makes the pump work harder pushing it forward under hard acceleration. It weighs more and then there is slower fuel flow which allows it to heat up more.
This is one kind of 100 micron discharge fitting for your fuel cell, way better than a external filter and housing. Less to heat up like I said. LINK
A fuel pump in the fuel cell is the best way to go.
Re: Is this fuel system adequate? [Re: mopowers] #2318400
06/09/17 11:03 AM
06/09/17 11:03 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
I favor fuel systems that don't run a return from the regulator all the way back down the length of the car. My Magnafuel pump has the return right at the pump, and no return from the engine compartment. I'm not a fan of running two lengths of hose that distance; waste of money on line, and just another thing that could leak/dry rot/get hit and send you home early. Obviously depends on what parts you already have in your possession.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Is this fuel system adequate? [Re: A39Coronet] #2318404
06/09/17 11:18 AM
06/09/17 11:18 AM
Cincinnati, Ohio
Cincinnati, Ohio
By returning fuel right in front of the pump you run the risk of introducing bubbles and turbulence into the inlet of the fuel pump and can cause cavatation during hot weather.
Steel line should be used front to back and not hose.
Re: Is this fuel system adequate? [Re: mopowers] #2318411
06/09/17 11:37 AM
06/09/17 11:37 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Thanks for all the input guys. I appreciate it. The main reason for the -8 line between the filter and pump was just for packaging purposes. -8 seems to bend a lot easier and the fittings are smaller, so I could pump the pump and filter closer together. Plus, since the threads on both the pump and filter are pretty small (3/8 npt), I didn't realize the -8 would causes much of a restriction. I'll go with -10 though as you folks suggested and separate the filter and pump a little more to make it doable.
Thanks again.
Re: Is this fuel system adequate? [Re: Challenger 1] #2318412
06/09/17 11:38 AM
06/09/17 11:38 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I'll use a return system any day.. when I was
testing hot fuel in Cali.(Death Valley and Baker
grade) I seen fuel temps in the low 300* range..
that fuel at the injectors was sitting there
boiling.. it took a fair amount of time to get
that hot fuel out of there.. with a return it
would be out of there in short order...I dont
mind paying more for a good system.. even if it
weighs more
wave
