SHUT OFF OVER DRIVE FOR THE QUARTER MILE? #231814
02/21/09 10:06 PM
02/21/09 10:06 PM
Walmart parking lot
yorker Offline OP
Drugs are bad
yorker  Offline OP
Drugs are bad
Walmart parking lot
HI all: Been many years since I had run at the strip.
I decided the other night to go and see what my 97 Ram would do.
I only made a couple of passes.
I shut off the overdrive and wonder if that was a bad thing to do.
I did not look at the tach, but the truck was revving pretty hard the whole time.
Wonder if it needed to shift into fourth at WOT?
I did notice on my return home that every time I shut off overdrive the motor or trans had a clicking sound.
My second pass the damn strip was wet well beyond the tree resulting in a high reving tire spinning episode where I had to let off the gas and stab it again.
My 97 Ram 360 which has not been tuned up in years ran high 16's top speed 28 mph on the slip,crappy strip computer.
And the last pass 19 seconds because of poorly maintained wet or oily strip.
If I ever go again, should the Overdrive be on or off?
Alan
( SHONEN KNIFE ) MAKING THE WORLD A BETTER PLACE. ONE SONG, ONE CONCERT AT A TIME FOR OVER 36 YEARS!!
https://www.youtube.com/user/SHONENKNIFETV
Re: SHUT OFF OVER DRIVE FOR THE QUARTER MILE? [Re: yorker] #231815
02/22/09 12:29 AM
02/22/09 12:29 AM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
Off, you don't want it to shift into overdrive at WOT.
Re: SHUT OFF OVER DRIVE FOR THE QUARTER MILE? [Re: yorker] #231816
02/22/09 01:54 AM
02/22/09 01:54 AM
Hamilton,Ohio
P
POZEST Offline
POZEST  Offline
P
Hamilton,Ohio
Turn it off. I don't know if if will make any difference or not either way. You will barely get into third gear anyways. Have fun!
Re: SHUT OFF OVER DRIVE FOR THE QUARTER MILE? [Re: POZEST] #231817
02/22/09 10:38 AM
02/22/09 10:38 AM
WASHINGTON, PA
11secaarcuda Offline
WASHINGTON, PA
it WILL NOT shift into overdrive at WOT.
67 Dart GT 340 4 speed
70 AAR Cuda 408 6 barrel
96 Indy Ram original owner
2011 Hemi Durango
Re: SHUT OFF OVER DRIVE FOR THE QUARTER MILE? [Re: 11secaarcuda] #231818
02/22/09 11:15 AM
02/22/09 11:15 AM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
When I have run my street truck, I switch the OD off.
It will also run more consistent if you leave it running while waiting in the lanes.
Re: SHUT OFF OVER DRIVE FOR THE QUARTER MILE? [Re: cgall] #231819
02/22/09 05:47 PM
02/22/09 05:47 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I tried both ways in my Dakota R/T. It made no difference. As said before, you don't get through 3rd gear anyway.
I also never turn it off when towing. Trans has almost 140,000 on it now and never misses a beat.
