Re: video of noise coming from bellhousing area 727
[Re: skep419]
#2318075
06/08/17 01:28 PM
06/08/17 01:28 PM
Posts: 782 Minnesota
skep419
Minnesota
[Re: skep419]
#2318088
06/08/17 02:31 PM
06/08/17 02:31 PM
Posts: 96,664 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
how long has it been making that noise?
when did it start? winter/summer?
What were you doing with the car when it started?
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: amxautox]
#2318124
06/08/17 04:19 PM
06/08/17 04:19 PM
Posts: 1,637 Florida
GMP440
Pull the starter and look at the starter gear. See how far forward the starter gear is shimmed. If you have another starter lying around compare both to see if there is any differences on how far forward the starter gear is. Could be the starter gear rubbing on the flywheel. This happened to me a long time ago. Installed a rebuilt starter and I was getting that same rattling sound when driving. Turned out that the starter gear was shimmed forward too much causing the starter gear to rub on the flywheel.
[Re: amxautox]
#2318130
06/08/17 04:39 PM
06/08/17 04:39 PM
skep419
Minnesota
What were you doing with the car when it started? Its a new block and new transmission housing. Basically just put it together using the internals I was using before. I noticed it as soon as I started driving it.
[Re: GMP440]
#2318131
06/08/17 04:43 PM
06/08/17 04:43 PM
skep419
Minnesota
The starter gear had plenty of clearance. I will check the gear a little better when I get home though. thanks
Its a mini starter that's very old
[Re: stumpy]
#2318160
06/08/17 06:09 PM
06/08/17 06:09 PM
skep419
Minnesota
Have you checked flexplate to crankshaft bots to see if they might be too long? Yep. thanks
[Re: skep419]
#2355015
08/16/17 06:48 PM
08/16/17 06:48 PM
skep419
Minnesota
[Re: skep419]
#2355098
08/16/17 09:33 PM
08/16/17 09:33 PM
Posts: 290 Dayton, WA
wesgtx440
Dayton, WA
Check the flex plate to converter measurement as well when you put the transmission back in. Could be putting to much rearward pressure on the crankshaft and in turn the thrust bearing specifically.
68 Charger R/T 440 auto
