Thoughts on moving 73-74 e-body bumpers in? #737683
06/30/10 08:55 PM
06/30/10 08:55 PM
eastern, pa.
cudabitten Offline OP
eastern, pa.
Hey, I've been thinking about this for a long time. I cant make up my mind about moving my bumpers in on my 74 cuda. I'm still in the middle of the restore, and I'll need to buy new bumpers sometime soon. Pretty sure I will nix the rubber bumperettes in place of the smaller ones in the rear, and none in the front. Just looking for your opinions. PS. Just making a driver.
Thanks.
Re: Thoughts on moving 73-74 e-body bumpers in? [Re: cudabitten] #737684
06/30/10 09:14 PM
06/30/10 09:14 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
Mine's a '72 and I do think it makes for a little cleaner look. Of course it wouldn't take too hard a tap and they would be in the sheetmetal.
Re: Thoughts on moving 73-74 e-body bumpers in? [Re: 5spdcuda] #737685
06/30/10 09:53 PM
06/30/10 09:53 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
They do look cleaner moved in. They can easily be moved back out in the future too. Check out this link. It mostly dealt with Challenger bumpers but most of it applies to you too.
https://board.moparts.org/ubbthreads/favl...amp;postmarker=
Re: Thoughts on moving 73-74 e-body bumpers in? [Re: cudabitten] #737686
07/01/10 03:07 PM
07/01/10 03:07 PM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
what i did for my 74 Challenger was I got the 70-72 style bumper brackets and bumpers. that easy! it should be the same for a cuda, just get the 70-72 bumper brackets and bumpers. check it though
Re: Thoughts on moving 73-74 e-body bumpers in? [Re: joelson6] #737687
07/01/10 03:09 PM
07/01/10 03:09 PM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
oh i forgot.
the front might be OK, as was mine, but the back with the filler panel, when you remove the plastic filler panel, you might have to find a filler panel for 70-72. i had to do that for my Challenger too.
Re: Thoughts on moving 73-74 e-body bumpers in? [Re: cudabitten] #737688
07/01/10 07:18 PM
07/01/10 07:18 PM
N.E. Ohio
mike69rr Offline
mike69rr  Offline
N.E. Ohio
74 chally here. got the 70-72 rear bumper brackets and redrilled the front brackets to fit. if you need the rear filler, pm me, got 2 when I ordered mine ( stuck together ). as others have said, should be same process for your car, but not sure if chally rear filler will work for you. I think this really cleans up the look of the 73-74 cars.
Re: Thoughts on moving 73-74 e-body bumpers in? [Re: mike69rr] #737689
07/01/10 07:40 PM
07/01/10 07:40 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
AMD makes it easy. Just go buy new 1970-71 Front and rear bumpers and the bumper brackets.
Cuda's do not require a filler panel as mentioned above.
You'll find the AMD bumpers are great for a driver and most likely cheaper then re-chroming your originals.
CHECK OUT MY NEW WEB SITE !
Re: Thoughts on moving 73-74 e-body bumpers in? [Re: anlauto] #737690
07/01/10 09:55 PM
07/01/10 09:55 PM
midwest
I
intragration Offline
I
midwest
I did the same thing on my 'Cuda. Bought a set of original brackets for front and rear, removed the extension fillers (that fill the gap between the later-style bumpers and the tail panel and grille) and got a set of perfect rechromed original '70 bumpers from a shop for about $150 each. Picked up new chrome rear bumperettes, bumperette fillers, and brackets from Year One. It looks fantastic and was very easy to do.
FYI, you will want to attach the bumperettes and brackets before putting the rear bumper on. I didn't have the '70 service manual, so I didn't realize this until I already had the bumper installed and adjusted. Real PITA to do after the fact. Also, you will have an open gap between the sides of the rear bumper and the quarter panel. '72-up had the plastic fillers to cover this gap, and the earlier cars had a small metal extension that filled this in. You can either leave it as-is, or make some sort of sheet metal extension.
Re: Thoughts on moving 73-74 e-body bumpers in? [Re: intragration] #737691
07/02/10 09:28 AM
07/02/10 09:28 AM
Eau Claire, WI
ResQ911 Offline
super gas
ResQ911  Offline
super gas
Eau Claire, WI
I did this too. I used my '74 bumpers AND brackets. Redrilled the front brackets like mentioned. I posted some pics in this thread: Snug Your Bumpers Up Cut, overlapped then welded rear brackets to shorten them up. I then used the nice chrome bumperettes to fill the holes in valance where those huge and ugly 5 mph bumperettes were. I had to make the mounting brackets for those as no factory bracket would allow the 70-71 bumperettes to line up nicely on the '74 bumper. I have sets of the cuda bumperettes and mounting brackets for them if you need. I thought maybe cuda stuff could be modified to work but never used them.
Re: Thoughts on moving 73-74 e-body bumpers in? [Re: cudabitten] #737692
07/03/10 01:02 AM
07/03/10 01:02 AM
Lake Elmo, MN
Evil Monkey Offline
Evil Monkey  Offline
Lake Elmo, MN
Thanks.
I did to my 74 Cuda exactly what you are thinking of doing to yours. I drilled a new hole in the front bumper brackets to pull it in (there was one factory hole on each side of the brackets that lined up so only one hole per side needed to be drilled), and took the front bumperettes off. On the rear, I fabricated some bumper brackets by using a torch to heat and bend some quarter inch steel bar, and drilled the mounting holes. It did take a little trial and error, but not too much. I then went with the small chrome bumperettes from a 70 Cuda. I think it looks much better this way. The only problem with doing it the way did is that you can still see where the old bumperettes mounted on the bumpers - there are some indentations from the edges of the old bumperettes in the bumpers, and the chrome on the bumpers is much nicer where it was protected by the bumperettes. However, if you are getting new bumpers this shouldn't be a problem. I believe I also had to drill new holes in the rear bumper to mount the 70 bumperettes, but the bumperettes covered over the old bumperette holes, so the old holes are not visable.
You can also just get 70-71 Cuda bumpers and brackets, I believe they mount right up with no fabrication needed. They are much lighter - the later bumpers have a heavy inner bumper - but those inner bumpers can help reduce damage if you get in a wreck. I was in a wreck in the late 90's that probably would have totaled my Cuda if not for the inner bumper, and it did total the Toyota that caused the accident. That's something to keep in mind if you're just making a driver and aren't too concerned with the added weight.
1974 'Cuda 360/TKO 1990 Ram Van 1998 Neon
Re: Thoughts on moving 73-74 e-body bumpers in? [Re: ResQ911] #2316654
06/05/17 03:57 PM
06/05/17 03:57 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
<img src="/ubbthreads/images/graemlins/beer.gif" alt="" />
I realize this is an old post (actually found it googling for ideas smile ) but just curious about your procedure. Did you delete the inboard brackets? I found that they hit the frame ends before it moves an inch. I am moving them 2". What about the reinforcement bar? I considered deleting this too but it seems just using the outboard brackets and no reinforcement, it wouldn't take much of a bump to really booger up the bumper. I'm done with the rear (Easy, I just cut the brackets and welded in a piece of 2" tubing that I had drilled to bolt up to stock holes.) I will post the whole project on my "Member's Projects" thread when complete.
Anyway, thanks for any input. Hope ResQ911 sees this wave
Image of front: just hanging on bracket. Need new bumper bolts...
Re: Thoughts on moving 73-74 e-body bumpers in? [Re: Scott Carl] #2317364
06/06/17 10:35 PM
06/06/17 10:35 PM
Outside
thedriver Offline
thedriver  Offline
Outside
I had to notch a small hole on the inside of my front bumper brackets where it contacted the frame rail, put the reinforcement bars up into the garage rafters.
1973 challenger
Dana. 4 speed. Low deck.
