Re: Adjusting brake drums to eliminate pull
[Re: jcastle1]
#2313805
05/30/17 09:13 PM
05/30/17 09:13 PM
RapidRobert
A pull to the right means the left side ain't doing its job (for whatever reason). open it up & see what's up.
[Re: jcastle1]
#2314359
05/31/17 10:55 PM
05/31/17 10:55 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Believe it or not, theres a lot of 50 year old cars driving around with original brake hoses. Last year I had my rear brakes starting to drag, replaced both rear wheel cylinders , both were filled with crud. Resembled , the problem was worse. It was the rear hose . The line acted like a check valve, a lot of hydraulic brake going in ,nothing coming back. I bet it's your rubber hose.
[Re: jcastle1]
#2314431
06/01/17 01:32 AM
06/01/17 01:32 AM
RapidRobert
I would get the drum setup straightened out first. I would replace the bad/unbonded shoe (if I am reading that right) then spoon em up tight then back off the other way till free & you hear a slight "tick" of contact at one point in the tires' revolution as you spin the wheel(s) forward by hand.
[Re: jcastle1]
#2314445
06/01/17 02:12 AM
06/01/17 02:12 AM
rowin4
But did you replace the front ones also at that time or do you know if they have been ever replaced?
[Re: Sxrxrnr]
#2314624
06/01/17 03:29 PM
06/01/17 03:29 PM
Posts: 2,336 Ball Ground, Georgia
Dixie
There is s good chance that if brake lining is not replaced pull will still exist if ever contaminated. . Once lining has been soaked with grease or brake fluid, it is likely you will be unable to clean throughly. Such compromised lining can/will often cause a severe pulling,,,,drums too must be throughly cleaned with carb or some such cleaner.
Be very careful when installing shoes and other components, so as greasy hands do not re-contaminate surfaces.
I learned a very long time ago not to blow compressed air to clean brakes after pulling drums. Vacuuming is advisable to start with for lung safety and not causing a general mess of your environment. Finish up with air but wear a nose mask and eye protection.
Not as critical as when asbestos was standard lining material, advisable nonetheless. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: jcastle1]
#2317327
06/06/17 09:35 PM
06/06/17 09:35 PM
Posts: 959 Cincinnati,Ohio
jcastle1
Cincinnati,Ohio
Thanks for the advice, i just ordered my kit from Dr. Diff. Incidentally, that's where i bought my S-60 Dana as well as my driveshaft from. What a great guy to deal with, a real pro at customer service (answers the phone, patient with my stupid questions, HONEST) a real asset to the hobby. I shopped it around and there are cheaper kits out there, and he did not dog any of them, simply explained the differences. If anyone is looking for a disc brake upgrade, don't waste your time looking around; I already did the homework.
