changed valve covers and oil: idle speed increased? #2316846
06/05/17 09:12 PM
06/05/17 09:12 PM
Boston area
U
ultrajosh Offline OP
U
Boston area
I just changed the oil in my 340: 4 quarts of 10-40, plus a quart of that Mystery Oil to see if it would help what sounds like a sticky lifter. While at it I put on some new valve covers. Cheap-ish Edelbrock covers with a breather in one and a PVC in the other, cork and rubber gaskets (I had old cop car 318 covers with rubber and steel gaskets on it before, also w a breather and PVC but 10 years old). After, my idle speed was way up, had to crank it down almost 3/4 turn of the idle screw. Is this because the oil is thinner? Or something about airflow with the new (tighter) valve covers?
Re: changed valve covers and oil: idle speed increased? [Re: ultrajosh] #2316866
06/05/17 09:42 PM
06/05/17 09:42 PM
vac leak-PCV issue.
Re: changed valve covers and oil: idle speed increased? [Re: ultrajosh] #2317251
06/06/17 07:06 PM
06/06/17 07:06 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
I'm thinking something with the PCV, too.
Re: changed valve covers and oil: idle speed increased? [Re: ultrajosh] #2317290
06/06/17 08:32 PM
06/06/17 08:32 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Probably half PVC and half 'Mystery Oil". I used to know of a product called "Mix-I-Go" and you would add it to your fuel and listen to your idle go up and watch the black disappear from inside the exhaust pipe.
Re: changed valve covers and oil: idle speed increased? [Re: ultrajosh] #2317300
06/06/17 08:51 PM
06/06/17 08:51 PM
md
mopars4ever Offline
mopars4ever  Offline
md
put the old pcv back in and see how it runs.
Re: changed valve covers and oil: idle speed increased? [Re: mopars4ever] #2317314
06/06/17 09:11 PM
06/06/17 09:11 PM
Ding ding ding I do believe we have a winna.
