Just Lost my .590 cam #2316177
06/04/17 08:38 PM
06/04/17 08:38 PM
Burlington,Ont.
77DragracerR/T Offline OP
Burlington,Ont.
Now the search for a newer & better cam is required
I race a 408 stroker with KB744 pistons and Eddy heads with Hughes 1111 springs
The 590 cam worked great for years but when i changed the lifters to EDM style i had a lobe go on me
Yes i did do the proper break in again but this is the second in many years i lost a MP cam when making changes to them
Car is a 77 Aspen R/T with 904 trans 5000 stall & 4.30 gears
Usually ran 10.80-10.90
77 Aspen R/T 60'@1.41 10.76 @ 123.26
http://www.youtube.com/watch?v=Eya3Ue8KoZk
Re: Just Lost my .590 cam [Re: 77DragracerR/T] #2316179
06/04/17 08:42 PM
06/04/17 08:42 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Go roller. .650 lift will be a nice pick up if you have a good converter.
Re: Just Lost my .590 cam [Re: FastmOp] #2316184
06/04/17 08:47 PM
06/04/17 08:47 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
iagree Been streetin a good sized Isky solid roller .680.660 276-281 @ .050 for years and love it........... thumbs
Re: Just Lost my .590 cam [Re: 77DragracerR/T] #2316225
06/04/17 09:46 PM
06/04/17 09:46 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
I have a 590 cam for sale and lifters all matched to the cam less then 1k miles on it
Re: Just Lost my .590 cam [Re: scottb] #2316253
06/04/17 10:10 PM
06/04/17 10:10 PM
Burlington,Ont.
Burlington,Ont.
No Thanks
I used it since 09 and it did run a best of 10.76 but i need something more up to date
Re: Just Lost my .590 cam [Re: FastmOp] #2316255
06/04/17 10:12 PM
06/04/17 10:12 PM
Burlington,Ont.
Burlington,Ont.
I have a 5000 TCS converter in there but not sure if i would have enough V/P clearance with that lift?
Re: Just Lost my .590 cam [Re: 77DragracerR/T] #2316297
06/04/17 10:58 PM
06/04/17 10:58 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Do I understand this correctly, the 590 was fine, you switched to "the best thing since sliced bread" lifter, and wiped a lobe. Is that correct?
Re: Just Lost my .590 cam [Re: BSB67] #2316421
06/05/17 02:32 AM
06/05/17 02:32 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I guess this is one of those instances where two people interpret the same situation two different ways.
I heard, "I put new lifters on my 8 year old cam and it wiped a lobe".
Which made me think......."why would one try and put new lifters on a well used cam"?
Re: Just Lost my .590 cam [Re: fast68plymouth] #2316523
06/05/17 12:03 PM
06/05/17 12:03 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I have added a couple of things to my list that I got away with years ago but will NEVER try again.
1. I will never buy a used solid lift cam.
2. I will NEVER take a good used solid lift cam from one block and install it in a new build. (different block)
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Just Lost my .590 cam [Re: pittsburghracer] #2316562
06/05/17 01:19 PM
06/05/17 01:19 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
ME; I will NEVER buy ANY solid lifter cam for ANYTHING...........problem solved.......... biggrin
Re: Just Lost my .590 cam [Re: Thumperdart] #2316567
06/05/17 01:26 PM
06/05/17 01:26 PM
PA.
"Little"John
"Little"John
PA.
I haven't totally given up on them. I've gone low 9.50's in my small block with them so they have their place.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Just Lost my .590 cam [Re: Thumperdart] #2316575
06/05/17 01:50 PM
06/05/17 01:50 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
I use a solid lifter (tool steel) in my RBRE 496 ci.
Gone 9.08 @ 146, I have thought about a roller. Maybe when I want to hit the 8s?
Don
Re: Just Lost my .590 cam [Re: cudadon] #2316622
06/05/17 02:54 PM
06/05/17 02:54 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Good #`s and obviously they work as you and others have proven just never again for me personally............ beer
Re: Just Lost my .590 cam [Re: 77DragracerR/T] #2316758
06/05/17 06:59 PM
06/05/17 06:59 PM
Guitar Jones Offline
That .590 cam was good in its day, which was at least 30 years ago. There is so much better out there now. I went roller awhile back and will never look back.
Re: Just Lost my .590 cam [Re: fast68plymouth] #2316969
06/06/17 12:56 AM
06/06/17 12:56 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Thought that too
Re: Just Lost my .590 cam [Re: Guitar Jones] #2317299
06/06/17 08:48 PM
06/06/17 08:48 PM
Burlington,Ont.
Burlington,Ont.
Yes I agree so i ordered a Comp cam 20-740-9 Extreme Energy Roller
286/292 duration 248/254 @ .050
.576/.582 lift
110* LS
106* IC
Will be running HRC91717 Howards lifters
Heck of a lot more $$ then a flat tappet but better in the long run
Re: Just Lost my .590 cam [Re: 77DragracerR/T] #2317321
06/06/17 09:26 PM
06/06/17 09:26 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
thumbs
Re: Just Lost my .590 cam [Re: 77DragracerR/T] #2317387
06/06/17 11:24 PM
06/06/17 11:24 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Remember the bronze dizzy gear. Cam button, and check cam endplay.
Re: Just Lost my .590 cam [Re: FastmOp] #2317397
06/06/17 11:52 PM
06/06/17 11:52 PM
Burlington,Ont.
Burlington,Ont.
Yep ordered one of them also
Re: Just Lost my .590 cam [Re: 77DragracerR/T] #2317420
06/07/17 12:21 AM
06/07/17 12:21 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I like the specs of that cam. I think you will pick up power across the rpm range
