Jw bellhousing #2316077
06/04/17 05:50 PM
06/04/17 05:50 PM
ohio
slomoshun Offline OP
ohio
Wanted to know if the jw ultrabell for a big block to torque flight transmission will bolt up to a 46re or 46rh transmission
Re: Jw bellhousing [Re: slomoshun] #2316090
06/04/17 06:09 PM
06/04/17 06:09 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yes, the 92457 Ultrabell fits the 46RH and RE. Must use an 11" or smaller converter.
Re: Jw bellhousing [Re: slomoshun] #2316099
06/04/17 06:19 PM
06/04/17 06:19 PM
ohio
ohio
Looks like you've already done it next question is does anyone make a good lockup convertor for it would be going in a pulling truck 830 hp 760 ft lbs torqe
