4.7 injector "chatter" question #231589
02/21/09 06:07 PM
02/21/09 06:07 PM
Tulsa, OK
73cudaproject Offline OP
Tulsa, OK
Recently I began to hear chatter from the 4.7L motor in my '01 Dakota. After researching this morning I have discovered the noise is on the fuel rail. The noise only occurs at initial startup for a few seconds, upon initial acceleration from a stop, and I can get it to "chatter" at idle if I rev it up then let off the pedal it will chatter for a few seconds.
Is this what happens when injectors get old? The truck has 172,000 miles. Can a fuel injector cleaner help reduce this noise?
Re: 4.7 injector "chatter" question [Re: 73cudaproject] #231590
02/22/09 12:09 AM
02/22/09 12:09 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Put a fuel gauge on it. Does it fire right up? or crank for 10-20 seconds? Our you sure its not a valve or timing chain rattle?
Re: 4.7 injector "chatter" question [Re: SALEM1912] #231591
02/22/09 05:30 PM
02/22/09 05:30 PM
Tulsa, OK
Tulsa, OK
The truck fires right up and runs great except for this noise which I thought for sure was a valve type noise or now that you mention it seems like it would be a worn out timing chain; however when I use the mechanics stethoscope these things sound fine. The noise is very loud when I put the probe on the fuel rail. When I put the probe on the heads, block, accessories, etc. everything sounds fine.
Maybe the fluid is just able to pickup and amplify the noise which might be created elsewhere; however with the probe I can only detect the noise on the fuel rail. I am going to try a fuel injector cleaner to see if it helps.
I do have a fuel pressure tester so I will test the pressure.
