Re: Battery overcharging. Ignition box causing voltage drop at regulator
[Re: lunacy]
#2315686
06/03/17 07:14 PM
06/03/17 07:14 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Nothing to do with your ignition box, not even sure why you went there.
The regulator is what controls the alternator output. Of course it needs good clean connections to work properly.
[Re: lunacy]
#2315689
06/03/17 07:18 PM
06/03/17 07:18 PM
Posts: 25,894 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Unplug the voltage regulator connector when the engine is running, if the voltage stays at 15V there is a short to ground in the green field wire or internally in the alternator.
[Re: lunacy]
#2315691
06/03/17 07:21 PM
06/03/17 07:21 PM
Supercuda
About to go away
About to go away
up yours
Been my observation that the voltage goes way past 15v with a short in the ground circuit.
[Re: ahy]
#2315726
06/03/17 09:35 PM
06/03/17 09:35 PM
RapidRobert
I think the reg is bad but first unplug the field terminals at the reg & confirm that neither male alt terminal is grounded & you might note how many ohms there is on that circuit & there is a spec for that & you spin the pulley by hand which woouldn't involve anymore than removing the belt for a quick test tho likely if the brushes & that circuit ain't grounded then the alt is good but it would be a good first step (& costs nothing). Do NOT run the eng any longer than 5 seconds at a time just long enough to take a voltage reading with your VOM as you proceed with the diagnosing & keep all lights/accessories/radios etc off even for that 5 seconds.
