Re: new 8 3/4 chunk - driveline vibration - pinion angle?
[Re: ultrajosh]
#2315395
06/03/17 12:28 AM
06/03/17 12:28 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Your axle should not be able to rotate, there is a perch welded to the axle housing on each side that prevents that.
I suppose the Ubolts could be loose though.
When setting pinion angles you want the output shaft of the trans an the pinion of the rear to be parallel under load. So typically your pinion will be nose down a couple degrees at rest.
[Re: ultrajosh]
#2315401
06/03/17 12:35 AM
06/03/17 12:35 AM
RapidRobert
Or could it be the universal joint? yes, recheck the ujoint/pinion flange fitment. EDIT in neutral & moving it is OK? Nothing else was altered/changed?
[Re: ultrajosh]
#2315572
06/03/17 01:43 PM
06/03/17 01:43 PM
Posts: 765 Boston area
ultrajosh
Boston area
And by checking the u-joint-pinion fitment, what exactly do I check for? The straps and bolts are pretty old, would new ones make a difference?
^^ I'll check the C-clips - are they supposed to keep the cups in place?
[Re: ultrajosh]
#2315933
06/04/17 01:44 PM
06/04/17 01:44 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Also one of the u-joint caps fell off while removing the driveshaft - I straightened out the pin bearings and added a dab of grease, pushed it back on. Is there more to it? Are you sure all the pins were back in? Or not got pushed into the bottom of the cap and cap not square now?
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: ultrajosh]
#2316003
06/04/17 04:01 PM
06/04/17 04:01 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
^^ If the u-joint is bigger on the new pinion, wouldn't the bolt holes be farther apart? e.g. the old straps wouldn't fit? That's not what RE said. A 7260 joint (smaller) in a 7290 yoke (larger) will cause problems. Not only are the 7290 strap bolt holes further apart and will allow the 7260 joint to go in, the 7260 cap diameter is also smaller so the 7290 straps will never fully tighten up. A 7260 joint in a 7290 yoke will bolt up but give a loose fit. A 7290 joint in a 7260 yoke would never bolt up due to the caps not seating in the yoke from the larger cap diameter, and the straps being too short.
[Re: B5 Bee]
#2316210
06/04/17 09:20 PM
06/04/17 09:20 PM
RapidRobert
FYI. cap dia. 7260-1.078". 7290-1.125"
[Re: ultrajosh]
#2316352
06/05/17 12:34 AM
06/05/17 12:34 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
You say that it is a new chunk, Used but new to you? I have seen the yoke spread so the U-joint was not seated centered in the yoke causing a vibration. You should check that the cups fit tight in the yoke.
