Re: Clear spray bomb on roll cage? [Re: Hemi_Joel] #2313682
05/30/17 05:40 PM
05/30/17 05:40 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
I just did this. I used POR 15 top coat. I went with black but its available in clear spray can. Won't rust or chip.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Clear spray bomb on roll cage? [Re: Hemi_Joel] #2313888
05/30/17 11:32 PM
05/30/17 11:32 PM
Medina, OH
dart440_72 Offline
dart440_72  Offline
Medina, OH
I used Penetrol on mine. Works pretty well. Do a search for coating bare metal with penetrol.
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
Re: Clear spray bomb on roll cage? [Re: Hemi_Joel] #2313956
05/31/17 12:45 AM
05/31/17 12:45 AM
River Falls, WI
urdustd Offline
urdustd  Offline
River Falls, WI
Joel, do a search on Gibbs penetrant. Just spray or wipe it on and it'll keep the metal from rusting. You can apply a little to a rag and clean off fingerprints,etc. It will darken the metal some. If in the end you don't like it you can use it as a primer and paint right over it. I used it on some old painted headers that I stripped and repainted. Worked beautifully.
BTW - I am no way involved with Gibbs, but the stuff works amazingly!
Re: Clear spray bomb on roll cage? [Re: Hemi_Joel] #2313987
05/31/17 01:09 AM
05/31/17 01:09 AM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Unreal, we just painted them with appliance epoxy black. To me clear would look like unfinished water pipe.
Re: Clear spray bomb on roll cage? [Re: Hemi_Joel] #2314137
05/31/17 12:51 PM
05/31/17 12:51 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Originally Posted By Hemi_Joel
Originally Posted By ProSport
I have a 6 point bar coming to my street car soon so I'm subscribing to this thread.
Got any pics of your hot rod Joel?
It's not done yet, still a work in progress. I'm planning on Drag Week this year. Hopefully I don't have any more big setbacks, and will be ready. 31 Plymouth, 392 early Hemi, T56 Magunum 6 speed.
Looks great Joel! 2 questions; Where are the holes for spark plugs in the valve covers?
How are you going to mount the mermaid hood ornament?
I hope to see you and the other competitors at DW.
Don
Re: Clear spray bomb on roll cage? [Re: Hemi_Joel] #2314139
05/31/17 01:04 PM
05/31/17 01:04 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Very cool car!!
Re: Clear spray bomb on roll cage? [Re: cudadon] #2314146
05/31/17 01:21 PM
05/31/17 01:21 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Don
The holes are there for the plugs, Joel has white rags stuffed in them, and they are just not showing up.
"Flipper" AKA Joel's mascot will probably get to sit in the front seat, and his trunk Monkey, well in the trunk...
69 GTX 68 Road Runner
Re: Clear spray bomb on roll cage? [Re: Hemi_Joel] #2314195
05/31/17 03:12 PM
05/31/17 03:12 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Some nostalgia dragster folks use Remington Oil (gun oil) on the bare chassis metal.
Re: Clear spray bomb on roll cage? [Re: Hemi_Joel] #2331282
07/04/17 12:30 PM
07/04/17 12:30 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Do any of you have pics of a roll bar done with the ECS rpm product?
I want my roll bar to be satin black, on the youtube videos it looks like the ECS RPM is a dark gray color.
Re: Clear spray bomb on roll cage? [Re: Hemi_Joel] #2331342
07/04/17 01:16 PM
07/04/17 01:16 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
My car isn't done yet. Every time I add another bar or bracket, the last one is already surface rusting. I guess that's what I get for living in NC. I'm going with the opposite thoughts: I know the cage is going to get nicked and scratched, so I'm painting it with Rustoleum purple. If I have to touch up an area or sand down to add something, it's nothing more than a trip to Walmart for some touch up.
[image][/image]
Re: Clear spray bomb on roll cage? [Re: Hemi_Joel] #2331399
07/04/17 02:58 PM
07/04/17 02:58 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
I started with the rpm coating. It is pretty easy to apply. First I used a Scotch-Brite pad to remove the surface rust in a few areas where it had formed. Then wiped the whole cage down with wax and grease remover, then started heating it with a heat gun and brushed on the RPM coating. It does not change the way the bar looks. I can't tell were I stopped using it.
This kind of work is hard on my back, so I'm just going to do about a half hour at a time till it's done. I estimate the whole job is going to be about 2 - 3 hours
Re: Clear spray bomb on roll cage? [Re: Hemi_Joel] #2331421
07/04/17 03:37 PM
07/04/17 03:37 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Sounds good, I might have to try the RPM if I don't do the satin black.
Re: Clear spray bomb on roll cage? [Re: ProSport] #2331426
07/04/17 03:50 PM
07/04/17 03:50 PM
jersey
Spaceman Spiff Offline
jersey
it's clear.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Clear spray bomb on roll cage? [Re: Spaceman Spiff] #2331491
07/04/17 06:08 PM
07/04/17 06:08 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
it's clear.
Ok thanks, looked like a gray color in the vids.
Re: Clear spray bomb on roll cage? [Re: Hemi_Joel] #2331632
07/04/17 11:12 PM
07/04/17 11:12 PM
Minnesota
Minnesota
After I applied RPM coating, it looked exactly the same as before I applied it.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
