trans cooler question #231419
02/21/09 03:36 PM
02/21/09 03:36 PM
beentheredonethat
AverageJoe Offline OP
beentheredonethat
Apparently makes no difference which is inlet/outlet since they aren't marked as such ? Got a cooler from a friend and am installing today, bypassing radiator.
Re: trans cooler question [Re: AverageJoe] #231420
02/21/09 03:47 PM
02/21/09 03:47 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
They aren't directional if that's what you are asking. If you mount it horizatally you want the pressure line at the top and return at the bottom.
Re: trans cooler question [Re: stumpy] #231421
02/21/09 03:57 PM
02/21/09 03:57 PM
beentheredonethat
beentheredonethat
Pressure line is towards front of 727 - correct ?
Re: trans cooler question [Re: AverageJoe] #231422
02/21/09 04:58 PM
02/21/09 04:58 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I believe it's the front line.
Re: trans cooler question [Re: stumpy] #231423
02/21/09 06:05 PM
02/21/09 06:05 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
yes front line is pressure rear line is return
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: trans cooler question [Re: dusturbd340W5] #231424
02/21/09 06:16 PM
02/21/09 06:16 PM
scratchnfotraction Offline
why would it need to be on the top and return on the bottom?
I thought you would fill it from bottom to top of cooler when horz
thats the way I took the stock one I pulled from an 87 dippy police car off
I put it back the same way on my truck,seems to work fine so far
wouldnt the tranny pump and cooler stay some what full with it feeding from bottom to top and not leak down?
man I dont want to change them back around,I just got it done
Re: trans cooler question [Re: scratchnfotraction] #231425
02/21/09 06:36 PM
02/21/09 06:36 PM
Kissimmee Fl.
Kissimmee Fl.
really doesn't matter it will be fine
Re: trans cooler question [Re: scratchnfotraction] #231426
02/21/09 06:36 PM
02/21/09 06:36 PM
Bristol, Va
fasteddie Offline
fasteddie  Offline
Bristol, Va
We always put the in line on the bottom of the cooler so it would purge the air from the cooler better. We also never bypassed the rad cooler because it helped heat up the fluid when cold. This is on a bracket car, 72 Dart
It will probably work either way though.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
Re: trans cooler question [Re: fasteddie] #231427
02/21/09 06:38 PM
02/21/09 06:38 PM
Kissimmee Fl.
Kissimmee Fl.
it will push all the air out either way and I agree I prefer to run them in series with the rad.
Re: trans cooler question [Re: dusturbd340W5] #231428
02/21/09 06:47 PM
02/21/09 06:47 PM
North Florida
RebelDart Offline
super street
RebelDart  Offline
super street
North Florida
I bypassed based on alot of research and the fact that I'm in Florida and too of cold tranny fluid's rarely an issue so don't need radiator to bring up to temp.
Re: trans cooler question [Re: RebelDart] #231429
02/21/09 07:06 PM
02/21/09 07:06 PM
Kissimmee Fl.
Kissimmee Fl.
I run a transmission shop in central fl and the couple test i have done showed unless you have a HUGE external cooler the trans will run cooler with the rad in series with an external compared to an external alone results will very depending on a lot of things like cooler size stock or stall converter how much air flow ect.
Re: trans cooler question [Re: dusturbd340W5] #231430
02/21/09 08:02 PM
02/21/09 08:02 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Top to bottom uses less pressure to move the fluid through the cooler. I just figure it works better that way.
