Centering ring for MSD trigger wheel on Fluidampr #2313850
05/30/17 10:27 PM
05/30/17 10:27 PM
Dallas, TX
440Brian Offline OP
440Brian  Offline OP
Dallas, TX
Anybody know who makes a centering ring to mount an MSD crank trigger wheel on a big block Fluidampr balancer?
One of the rings included from MSD fits the balancer center, but isn't long enough. I read a 4 year old magazine build article online that got one from Fluidampr. I called them and they said it was specially made and they will get back to me. I searched here and saw Mopar65 had one made a few years ago.
This must be a fairly common combination so it should be available, right?
Thanks for any help,
Brian
Re: Centering ring for MSD trigger wheel on Fluidampr [Re: 440Brian] #2313912
05/30/17 11:47 PM
05/30/17 11:47 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
what dimensions do you need. I could whip one up for you
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Centering ring for MSD trigger wheel on Fluidampr [Re: 440Brian] #2314060
05/31/17 09:30 AM
05/31/17 09:30 AM
Wild West
M_D Offline
M_D  Offline
Wild West
I ran into that exact issue myself years ago, so I designed a spacer which can be used for spacing crank trigger wheels or pulleys. Mancini Racing might have some on the shelf, if not I have some.
Re: Centering ring for MSD trigger wheel on Fluidampr [Re: 440Brian] #2314081
05/31/17 10:50 AM
05/31/17 10:50 AM
Cranberry Twp PA (North of Pit...
rumblefish72 Offline
I'm running into the same problem. I have the Fluidamper on my B-Block and I want to mount the 36-1 trigger wheel I got from AndyF. But I need a spacer since the pulley mounting area on the Fluidamper is recessed (actually, the damper ring is thicker). I haven't measured how thick of a spacer I need yet but I see the spacer that Mancini sells (http://www.manciniracing.com/bicrpusp.html) is 0.375" (3/8") thick for $47. And Mancini has another spacer (http://www.manciniracing.com/prprpusp.html) that's 0.512" thick and costs $23. The Doty spacer (https://www.dotymi.com/motor-sports/21-mopar-crankshaft-pulley-spacer-.html) is 0.625" thick and costs $41.30.
My plan is to measure how much I need to space out to get a little proud of the Fluidamper ring since I want a clean signal from the trigger wheel. Then I'll buy whichever spacer fits the best. I'll have to check to see if the Fluidamper ring is steel or aluminum. The Doty spacer is the nicest and the thickest. If that was too thick, I could cut it down on my trusty SB Lathe. I see that Jerry mentioned that he could CNC one up for you. I wouldn't hesitate to get a price from him and go that route to get exactly what I needed. I suppose that you might have to fiddle with the pulley mounting bolt holes depending on if you have that one offset bolt hole or not. But I think that the Fluidamper has all the holes evenly spaced.
Of course, once I do all that, I'll have to see where I'm at for the crank pulley alignment with all the other pulleys. At a min, I'll need a shorter crank pulley since I don't want to space all the rest of the pulleys out by whatever I'm adding here. Doty sells v-belt and serpentine pulleys and all the rest of my pulleys are from March so I'll have to do some more pulley alignment engineering.
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: Centering ring for MSD trigger wheel on Fluidampr [Re: 440Brian] #2314177
05/31/17 02:33 PM
05/31/17 02:33 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
[quote=440Brian]Anybody know who makes a centering ring to mount an MSD crank trigger wheel on a big block Fluidampr balancer?
Brian [/quote
Hi. Yes I had a friend at work machine one for me. He said it was pretty easy. All I did was take him the balancer and the msd wheel. But I still see MSD doesn't put a note stating you might have to do this.
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Centering ring for MSD trigger wheel on Fluidampr [Re: mopar65] #2314296
05/31/17 08:41 PM
05/31/17 08:41 PM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
DMI. Great stuff!
Re: Centering ring for MSD trigger wheel on Fluidampr [Re: 440Brian] #2314424
06/01/17 01:08 AM
06/01/17 01:08 AM
Dallas, TX
440Brian Offline OP
440Brian  Offline OP
Dallas, TX
Thanks for all the responses and help. It looks like a spacer that moves everything out 0.9" and a DMI 0.7" pulley would work perfect. The pickup would require minimal spacers and the belt would still line up.
I don't see one that size listed anywhere. Can they be stacked or do I need a custom made item?
