Re: 8 3/4 swap in driveway, solo with jack stands - tips?
[Re: ultrajosh]
#2314062
05/31/17 09:50 AM
05/31/17 09:50 AM
Posts: 3,923 Richmond, Indiana
19swinger70
Richmond, Indiana
Would unbolting the shackle hangars from the frame rails and letting the suspension and housing pivot downward help?
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: ultrajosh]
#2314162
05/31/17 02:08 PM
05/31/17 02:08 PM
Posts: 2,256 IL
furious70
IL
I think unbolting the springs or housing will just make it more difficult in the car as things will move around. You should be able to get a jack under, the pig under, then put the pig on the jack and jack up without having to have the car up to the moon. If you're not able to pick the pig up off the ground at all when on your back/side under the car, your only option is to get the car way in the air on some good stands. Know any bigger guys? Give him $20 or some beer and pizza to put it in there for you .
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: furious70]
#2314171
05/31/17 02:28 PM
05/31/17 02:28 PM
Posts: 15,976 Chilliwack B.C. Canada
RUNCHARGER
I generally roll under the car on a creeper with the pig on my chest. Then I lift it in. It seems to work if you tilt it down slightly and hook a bottom stud and then tilt the top in. Steadying it on a trolley jack would work too but would be a lot better with two people, one on each side.
Sheldon
[Re: ultrajosh]
#2314173
05/31/17 02:29 PM
05/31/17 02:29 PM
Posts: 17,904 S.E. Michigan
ZIPPY
S.E. Michigan
Been awhile. Not really a fun job...
If I recall correctly I found a series of higher items to slide/drag the pumpkin on to. First I had the pumpkin on a piece of plywood and slid it under the car, and then I slid/lifted/dragged the pumpkin up a few inches higher on to a couple pieces of lumber, then it was something else a little higher, and so on. Then at some point it was high enough off the ground where I had enough leverage and strength to pick it up and install it.
Was a bit like a game of Jenga, with a big heavy object on top...kind of tilt the pumpkin enough to put a piece under one side, tilt it the other way and put another piece under it, and so on.
scrap lumber is your friend.
Another approach is put it on a milk crate or similar, and then weasel pieces of scrap lumber under the crate.
A trans jack would be nice to have....
Rich H.
Esse Quam Videri
[Re: Cab_Burge]
#2314176
05/31/17 02:32 PM
05/31/17 02:32 PM
Posts: 2,530 God's Country Maryland
GODSCOUNTRY340
Remove the muffler that's in the way. I usually lay on a large piece of cardboard, crawl under there and lift it up in. I don't like using a creeper for this job cause they seem to roll around just when you're in that awkward position with the third member in the air. Eat your Wheaties, put on a light pair of leather gloves and go for it.
[Re: ultrajosh]
#2314221
05/31/17 04:35 PM
05/31/17 04:35 PM
Posts: 1,271 Vista, California
67Satty
Vista, California
When I did it, I jacked the rear end up pretty high, then placed the third member on a floor jack, jacked it up high enough, then rolled it on in. I'm too chicken to lay my chest and head in a confined space under an awkwardly shaped, greasy chunk of metal that weighs 80 pounds but I know many people just put it on their chest and bench press it on up there.
[Re: ultrajosh]
#2314371
05/31/17 11:27 PM
05/31/17 11:27 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Sorry about the leaks . Most of us have done this more than once, even me. And not all can just pick up a center section and put it in. The guide studs are a good idea, holds the gasket in place to avoid damage which now you have. You can use more than 2 guide studs , 4 would be better. 2 on top 2 on the bottom. AS for trying to do a fix without removing the pig, Screw in 3-4 longer bolts to slide it out on, then dry the gasket and metal seal area off, you then should be able to see where the gasket is damaged, if reparable , then coat that spot with some gasket maker. Reassemble again using a chris cross pattern for tightening . Good luck
[Re: rowin4]
#2314440
06/01/17 01:51 AM
06/01/17 01:51 AM
RapidRobert
^^^ Ding ding ding I do believe we have a winna. if there ain't enough stud showing to double nut em (should be I just never noticed that) to get em out then cut a screwdriver slot in the stud with a hacksaw. EDIT or maybe just some vice grips
[Re: RapidRobert]
#2314539
06/01/17 12:55 PM
06/01/17 12:55 PM
Posts: 5,112 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
I'm trying to picture where your screwing these longer studs in for guide studs...??? Last and every 8 3/4 I ever messed with the studs were pressed in with a knurl from the inside. 64 up anyway... That means the pig is already out and on the ground again to get inside the housing to swap out the studs to longer ones...Sure will make fixing the leak easier... I understand most here have great intentions when offering advise...but damn...To someone whose never done this and is truly trying to learn he is unbelievably confused now...
...FAFO...
[Re: Sxrxrnr]
#2314545
06/01/17 01:15 PM
06/01/17 01:15 PM
67Satty
Vista, California
HF sells a low price trans jack.
After their oft time 25% discount, you are at 75 bucks. You will like use it again.
https://t.harborfreight.com/automotive-motorcycle/transmission-jacks.html?utm_referrer=https%3A%2F%2Fwww.google.com%2F Thanks for the link. I'm gonna get one of these the next time I have to do it.
[Re: skicker]
#2314557
06/01/17 01:44 PM
06/01/17 01:44 PM
ZIPPY
S.E. Michigan
I'm trying to picture where your screwing these longer studs in for guide studs...??? Last and every 8 3/4 I ever messed with the studs were pressed in with a knurl from the inside. 64 up anyway... That means the pig is already out and on the ground again to get inside the housing to swap out the studs to longer ones...Sure will make fixing the leak easier... I understand most here have great intentions when offering advise...but damn...To someone whose never done this and is truly trying to learn he is unbelievably confused now... What he said LOL
Rich H.
Esse Quam Videri
