Aluminum radiators?
#2313073
05/29/17 04:51 PM
05/29/17 04:51 PM
Posts: 2,863 middle Tennessee
mopower440
middle Tennessee
I know many here like the champion radiators, but I was wondering about these here? Anyone used them?
http://www.ebay.com/itm/THE-BEST-Mopar-Big-Block-26-ECP-Aluminum-Radiator-CRUSH-YOUR-COOLING-PROBLEM-/352021756905?hash=item51f621bbe9:g:-3MAAOSwB-1Y4tuC&vxp=mtr
or these
http://www.ebay.com/itm/3-Rows-KKS-ALUMINUM-RADIATOR-68-69-70-71-72-73-74-DODGE-MOPAR-CARS-26-CORE-/281790647173?hash=item419c080b85:g:wBkAAOSwsB9WCLxS&vxp=mtr
Re: Aluminum radiators?
[Re: mopower440]
#2313076
05/29/17 04:58 PM
05/29/17 04:58 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
I run the ECP in my 68 Charger, works GREAT!!!
[Re: mopower440]
#2313234
05/29/17 09:34 PM
05/29/17 09:34 PM
RapidRobert
You might ask one of the eBay sellers to measure the total width of their 26 incher & how wide the lateral side flat flange is on each side as you possibly can trim em in for fitment with the widest rad that will fit inbetween your frame rails. EDIT your rad support may be blocking some of the fin area on each side but I would still want to get the widest rad in there that I could.
[Re: mopower440]
#2313330
05/30/17 12:31 AM
05/30/17 12:31 AM
CSK
Pattison Texas
I did have to trim the mounting rails on the radiator, it is a 2 row, 26in, keeps my 512ci with AC nice & cool, 180ish all day long in temps over 100 deg here in southeast Texas.
[Re: komninon]
#2313355
05/30/17 01:17 AM
05/30/17 01:17 AM
CSK
Pattison Texas
18in 7 blade direct drive,Flex a lite.
