Clear spray bomb on roll cage? #2313068
05/29/17 04:43 PM
05/29/17 04:43 PM
Minnesota
Hemi_Joel Online content OP
Hemi_Joel  Online Content OP
Minnesota
On my Hot Rod, the interior is all natural metal finish, no paint. That's the way I want it to stay. But the cage is starting to get some surface rust. Is there anything wrong with spraying it with flat or semi-gloss clear out of a rattle can? THis cage is NHRA certified to 8.50
THanks, Joel
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Clear spray bomb on roll cage? [Re: Hemi_Joel] #2313089
05/29/17 05:24 PM
05/29/17 05:24 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
THanks, Joel
Yes there's something wrong with that, it will chip off.
I use red scotch bright pads and wd 40 or the like for 17 years now. None of my dragsters were ever painted.
This car is 11 years old.
Re: Clear spray bomb on roll cage? [Re: Hemi_Joel] #2313095
05/29/17 05:29 PM
05/29/17 05:29 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
What material? I would think clear would be your best protection, for a number of reasons, IMO
Re: Clear spray bomb on roll cage? [Re: Hemi_Joel] #2313106
05/29/17 05:44 PM
05/29/17 05:44 PM
Minnesota
Minnesota
chrome moly
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Clear spray bomb on roll cage? [Re: Hemi_Joel] #2313109
05/29/17 05:47 PM
05/29/17 05:47 PM
P
Porter67 Offline
Porter67  Offline
P
I wonder if that rpm finish protector would do the job?
Id use clear possibly, yes it might chip but if your car is finished id think your not going to do alot of heavy banging around.
I painted my cage black 23 years ago and have not scuffed it up yet other then the drivers entry point but just a few light scuffs.
Re: Clear spray bomb on roll cage? [Re: Hemi_Joel] #2313113
05/29/17 05:48 PM
05/29/17 05:48 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
One thing to keep in mind is that once you use the WD-40 don't plan on painting it. A guy I know had a rat rod that he did the WD -40 thing to the body. Looked good for a rat rod finish 1/2 paint half rust for a few years. Then took it to a professional for paint removal [ blaster ] The main flat panels cleaned up but the WD-40 kept weeping out of the seams even after extreme solvent cleaning. On the clear paint look , I would think a flat or semi gloss would look better than gloss.
Re: Clear spray bomb on roll cage? [Re: rowin4] #2313121
05/29/17 05:59 PM
05/29/17 05:59 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
RPM made by ECS should be fine for that. Call and ask them.
Re: Clear spray bomb on roll cage? [Re: Neil] #2313265
05/29/17 10:07 PM
05/29/17 10:07 PM
Minnesota
Minnesota
Interesting.
How time consuming is it to apply? How hot does the metal have to be to melt it?
Thanks for all the replys.
Re: Clear spray bomb on roll cage? [Re: Hemi_Joel] #2313279
05/29/17 10:45 PM
05/29/17 10:45 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
You don't have to get the metal hot so much as warm enough to get the stuff to bond. I have a can and used it to do the metal parts on a heater box and a hair dryer worked fine for me. A heat gun would have made it even faster.
A whole roll cage might take a few hours, but you don't have to do it all in one swipe. You could do one tube at a time in your spare time over a few weekends and next thing you know it's done.
To buy the stuff you have to call and order it over the phone so I would tell them what you want to do with it and they can answer your questions. I can't see why it wouldn't work great for that. No masking the whole inside of the car off, if it gets bumped you can touch it up. etc.
Re: Clear spray bomb on roll cage? [Re: Hemi_Joel] #2313286
05/29/17 11:03 PM
05/29/17 11:03 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I have a 6 point bar coming to my street car soon so I'm subscribing to this thread.
Got any pics of your hot rod Joel?
Re: Clear spray bomb on roll cage? [Re: Hemi_Joel] #2313305
05/29/17 11:48 PM
05/29/17 11:48 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I'd use the clear. If it scratches or chips..easy touch up
Nautilus Racing-
Re: Clear spray bomb on roll cage? [Re: Hemi_Joel] #2313307
05/29/17 11:55 PM
05/29/17 11:55 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Go with a 2-component clear urethane, and it'll never chip off. I sell paint in the Seattle area, but I'm sure if you go to any reputable industrial paint store, they should be able to set you up. If you were near me, I'd put this in your hands:
http://www.roddapaint.com/industrial/product-search/product-detail/299/armourshield-urethane
We only make it in a gloss, but it can be flattened with OK412 powder. Since it's a 2-component product, you'd have to use a paint gun, but it would stand up to just about anything you throw at it (as would most any 2k urethane product).
Re: Clear spray bomb on roll cage? [Re: ProSport] #2313317
05/30/17 12:07 AM
05/30/17 12:07 AM
Minnesota
Minnesota
It's not done yet, still a work in progress. I'm planning on Drag Week this year. Hopefully I don't have any more big setbacks, and will be ready. 31 Plymouth, 392 early Hemi, T56 Magunum 6 speed.
Re: Clear spray bomb on roll cage? [Re: Hemi_Joel] #2313377
05/30/17 01:53 AM
05/30/17 01:53 AM
Nice ride bow up
Re: Clear spray bomb on roll cage? [Re: Hemi_Joel] #2313405
05/30/17 06:22 AM
05/30/17 06:22 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Very cool hot rod!
Re: Clear spray bomb on roll cage? [Re: Hemi_Joel] #2313427
05/30/17 09:47 AM
05/30/17 09:47 AM
Spencer NY
killermopar Offline
killermopar  Offline
Spencer NY
That thing is sweet. I couldn't see the cage any color other than clear. It would look killer.
Re: Clear spray bomb on roll cage? [Re: Hemi_Joel] #2313428
05/30/17 09:53 AM
05/30/17 09:53 AM
CJD AUTOMOTIVE Offline
They use this on aircraft, https://boeshield.com/about/
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: Clear spray bomb on roll cage? [Re: Hemi_Joel] #2313505
05/30/17 12:42 PM
05/30/17 12:42 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
So much for keeping progress a secret...
Better get busy, HUGE bet on the line...
69 GTX 68 Road Runner
Re: Clear spray bomb on roll cage? [Re: Hemi_Joel] #2313637
05/30/17 04:34 PM
05/30/17 04:34 PM
Minnesota
Minnesota
Well, I ordered a can of RPM. I'll see how it goes. Thanks for the help!
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Clear spray bomb on roll cage? [Re: Hemi_Joel] #2313642
05/30/17 04:40 PM
05/30/17 04:40 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I would be careful around the headliner if you use a heat gun so you don't ruin it. Other than that it should be easy.
