413 stampings? #2312912
05/29/17 12:37 PM
05/29/17 12:37 PM
Canada
WO23Coronet Offline OP
Canada
Can someone decipher this? It's supposed to be a 413. Has a block casting number of 2205697 and a casting date of July 26 1963. Top pad reads as such:
VC3
18 94C
V means 1964 but should there not be a "41" after the V?
Re: 413 stampings? [Re: WO23Coronet] #2313114
05/29/17 05:49 PM
05/29/17 05:49 PM
Houston
I
it's Bob Offline
it's Bob  Offline
I
Houston
Could be a level 3 industrial block? Chrysler used 1-3 on their truck/industrial motors to show light duty -1, medium duty -2, and HD -3.
Just throwing out an idea for you.
Just checked your casting number and it does not show as a truck/industrial block number. It also shows that that casting number was good through 1963 and changed for 1964. Maybe just a late '63 block that was a replacement block?
Re: 413 stampings? [Re: WO23Coronet] #2313285
05/29/17 10:59 PM
05/29/17 10:59 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
A Chrysler New Yorker body is called a PC-3 in the factory literature. Maybe that is where the C3 comes from.
Re: 413 stampings? [Re: WO23Coronet] #2313311
05/29/17 11:59 PM
05/29/17 11:59 PM
Canada
Canada
Thx for the reply, the PC-3 thing sounds like it could be it. I think I read that the 300K's had "300K" stamped into the pad. A friend is looking at buying this motor and the stampings had me abit perplexed.
