Big Block oiling diagram #231237
02/21/09 12:59 PM
02/21/09 12:59 PM
Puyallup, WA
StealthWedge67 Offline OP
Puyallup, WA
Can anyone link me to a good one?
Re: Big Block oiling diagram [Re: StealthWedge67] #231238
02/21/09 01:18 PM
02/21/09 01:18 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
This OK?
Re: Big Block oiling diagram [Re: Dodgem] #231239
02/21/09 01:20 PM
02/21/09 01:20 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
This better
Re: Big Block oiling diagram [Re: Dodgem] #231240
02/21/09 02:10 PM
02/21/09 02:10 PM
Puyallup, WA
Puyallup, WA
Thanks. I'm taking my first foray into solid lifters, and want to understand the upper end oiling system (without oiling through the pushrods). This helps.
Re: Big Block oiling diagram [Re: StealthWedge67] #231241
02/21/09 02:24 PM
02/21/09 02:24 PM
AndyF Offline
AndyF  Offline
The stock oiling system gives each rocker shaft one squirt of oil very every two turns of the crank. It sounds like an odd design but it works just fine for lower speed motors with moderate valve spring loads.
Re: Big Block oiling diagram [Re: AndyF] #231242
02/21/09 02:37 PM
02/21/09 02:37 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
What kind of heads??
everything oils fine only if you go to jezzel stile rockers do you have to oil through the pushrod!
Re: Big Block oiling diagram [Re: Dodgem] #231243
02/22/09 02:59 PM
02/22/09 02:59 PM
Puyallup, WA
Puyallup, WA
It's pretty basic. It'll have Stealth heads and see 6500-6800 RPM.
Re: Big Block oiling diagram [Re: StealthWedge67] #231244
02/22/09 03:03 PM
02/22/09 03:03 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
For high RPM use with heavier valve springs it's not a bad idea to have the #4 cam journal grooved so there is a constant oil supply...
