Your facing the same problem I was looking at last year. I was out to build a stock appearing engine for FAST racing. For that there is really only one choice, a set of extensively ported 915 iron heads.
However, since I was going to actually drive the car on the street 99.9% of the time I looked into a better set of heads that also looked stock, or darn close to it, that I could swap onto my FAST engine for running a bit more HP while street driving it. I've found nothing currently avaible or manufactured that fills the bill so I went "antique shopping".
Here's what I found:
#1. Early (cast iron) W2 castings, circa 1979, look VERY much like 915 heads externally and flow allot better when ported. You need to modify the intake/head bolts to accomodate a stock intake but it's easy. Stock exhaust manifolds work fine also. These early W2 head castings have a freeze plug in the ends of the heads like 915 heads, later W2 castings do not.
#2. Batten Aluminum W2 heads, circa late 70's/early 80's. They look just like an early W2(freeze plugs and all) but are aluminum. They are rare, very few good sets around, and on top of that have a really bad reputation for being porus/leakers. If you get a set that doesn't leak they'd be a decent choice.
#3. Diamond Racing Aluminum W2 Heads, circa 1979/80. I have a set of these, very rare heads. They don't have a feeze plug in the ends but otherwise look much like a 915, have a raw "as cast" look unlike the machined from billit look of modern Edelbrocks. These are what I bought and had built as a spare set for my FAST engine. They have flow numbers that impress!
The bottom line is that nothing looks 100% exact as compared to a stock original 915 head, but some get closer than others. So far the iron and aluminum versions of the W2 heads by the various vendors are all I have found that even remotely resemble a stock 915 head. I think someone is missing out on a nice sized market segment by ignoring the small block mopar guys who desire a stock looking aluminum head.
![](/ubbthreads/images/graemlins/Twocents.gif)
*Diamond Aluminum Heads
