Holley 670 Street Avenger Primary Metering Block #231222
02/21/09 12:41 PM
02/21/09 12:41 PM
Urbana, MD
bordin34 Offline OP
bordin34  Offline OP
Urbana, MD
Does anybody know the part number for the primary metering block on a 670cfm Holley Street Avenger. One jet in mine is cross threaded and I think I need a new one. I have searched summit and cannot seem to find it. I have also asked Holley's online help and have not received a response.
Dan
Re: Holley 670 Street Avenger Primary Metering Block [Re: bordin34] #231223
02/21/09 12:44 PM
02/21/09 12:44 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
you need to get the number off of the choke horn and cross reference it with this chart. It will tell you which metering block you need
http://www.holley.com/data/TechService/Technical/Carb%20Numerical%20Listing.pdf
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Holley 670 Street Avenger Primary Metering Block [Re: goldduster318] #231224
02/21/09 05:57 PM
02/21/09 05:57 PM
Urbana, MD
bordin34 Offline OP
bordin34  Offline OP
Urbana, MD
It is listed as N/S or not serviced ,does not sound good.
Re: Holley 670 Street Avenger Primary Metering Block [Re: bordin34] #231225
02/21/09 06:12 PM
02/21/09 06:12 PM
Lake Orion, MI
Lake Orion, MI
if holley can't solve your problem you probably could use this proform main metering block:
http://www.proformparts.com/mistore/prod...mpany_id=100719
and sold at
http://store.summitracing.com/partdetail.asp?part=PRO-67166C&view=32&N=700+
