Re: AAR speedo
[Re: Knillse]
#2311158
05/25/17 08:55 PM
05/25/17 08:55 PM
Posts: 8,398 Highland, MI.
Sunroofcuda
Highland, MI.
I am a bit confused. My Cuda AAR does have the standard tach with a 120 mph speedo. When I look into the specs of the AAR it shows a top speed of 137 mph. Could it be that the AAR used the speedo from the rallye instruments which shows 150mph? I'll tell you right now, with 3:55 gears there is NO WAY an AAR will do 137. Maybe 125 tops. Might be able to do 137 with 3:23 gears. Trust me, I know what the top end is on a 1970 340 Cuda with 3:55's!
Re: AAR speedo
[Re: Dave Hall]
#2311178
05/25/17 09:25 PM
05/25/17 09:25 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
If the car came with a tach doesn't it have the rally cluster? Which would be a 150 mph speedo? Correct
Re: AAR speedo
[Re: Sunroofcuda]
#2311382
05/26/17 05:27 AM
05/26/17 05:27 AM
Posts: 16 Pfalz
Knillse
Pfalz
sorry guys, i mixed some names. In Germany we use the word tach(o) for a speedo. I do have a std. cluster, with no tach. However, the technical authority here will not let my Cuda get street legal until i have this issue fixed (typically German behaviour). Since i have to adapt mph to kmh just with tape stripes for 30, 50 and 100 kmh, my idea is to get a 39 teeth speedo pinion and remove the existing with this. I have 3.55 gears and 245/60 15 rear tires.
Re: AAR speedo
[Re: Knillse]
#2311548
05/26/17 02:43 PM
05/26/17 02:43 PM
Morty426
Sacramento CA
sorry guys, i mixed some names. In Germany we use the word tach(o) for a speedo. I do have a std. cluster, with no tach. However, the technical authority here will not let my Cuda get street legal until i have this issue fixed (typically German behaviour). Since i have to adapt mph to kmh just with tape stripes for 30, 50 and 100 kmh, my idea is to get a 39 teeth speedo pinion and remove the existing with this. I have 3.55 gears and 245/60 15 rear tires. Alles gut. Just stripe your speedo at 19, 31 and 62.5 MPH and you're done. The term Typical German Behavior is too funny - those guys are wound too tight
