AAR speedo #2310386
05/24/17 02:58 PM
05/24/17 02:58 PM
Pfalz
K
Knillse Offline OP
Knillse  Offline OP
K
Pfalz
I am a bit confused. My Cuda AAR does have the standard tach with a 120 mph speedo. When I look into the specs of the AAR it shows a top speed of 137 mph. Could it be that the AAR used the speedo from the rallye instruments which shows 150mph?
Re: AAR speedo [Re: Knillse] #2310462
05/24/17 05:22 PM
05/24/17 05:22 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The 120 was standard in all BS23/BS27 Cudas. The rally gauges with 150 was optional. You ever see a road test with the bicycle wheel attached to the car? That is what they use for their information not the speedometer.
Problem #1: The 120 mph speedo did not have a tachometer option with it. Have a photo?
Re: AAR speedo [Re: Knillse] #2310464
05/24/17 05:25 PM
05/24/17 05:25 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The std. cluster was, well, standard in all Cuda & The Rallye Cluster was optional.
It is certainly possible to peg a 120mph speedo & exceed that MPH, the RPM & rear gears would determine the top speed along with other factors.
Re: AAR speedo [Re: Knillse] #2311158
05/25/17 08:55 PM
05/25/17 08:55 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
I'll tell you right now, with 3:55 gears there is NO WAY an AAR will do 137. Maybe 125 tops. Might be able to do 137 with 3:23 gears. Trust me, I know what the top end is on a 1970 340 Cuda with 3:55's!
Re: AAR speedo [Re: Knillse] #2311169
05/25/17 09:16 PM
05/25/17 09:16 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
If the car came with a tach doesn't it have the rally cluster? Which would be a 150 mph speedo?
Re: AAR speedo [Re: Dave Hall] #2311178
05/25/17 09:25 PM
05/25/17 09:25 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Correct
Re: AAR speedo [Re: Morty426] #2311277
05/26/17 12:10 AM
05/26/17 12:10 AM
Maryland
MoparMike1974 Offline
Maryland
There was a tach option for the standard cluster. Its not very common but I have seen them.
Im sorry, it was a clock I was thinking of.
That being said, classic industries makes a tach that will fill the empty hole where the clock would go.
http://www.classicindustries.com/product/mopar/e-body-challenger/parts/me1316.html
Re: AAR speedo [Re: MoparMike1974] #2311336
05/26/17 01:38 AM
05/26/17 01:38 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Now that's pretty cool! Never seen one of those before.
Re: AAR speedo [Re: Sunroofcuda] #2311382
05/26/17 05:27 AM
05/26/17 05:27 AM
Pfalz
K
Knillse Offline OP
Knillse  Offline OP
K
Pfalz
sorry guys, i mixed some names. In Germany we use the word tach(o) for a speedo. I do have a std. cluster, with no tach. However, the technical authority here will not let my Cuda get street legal until i have this issue fixed (typically German behaviour). Since i have to adapt mph to kmh just with tape stripes for 30, 50 and 100 kmh, my idea is to get a 39 teeth speedo pinion and remove the existing with this. I have 3.55 gears and 245/60 15 rear tires.
Re: AAR speedo [Re: Knillse] #2311548
05/26/17 02:43 PM
05/26/17 02:43 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Alles gut.
Just stripe your speedo at 19, 31 and 62.5 MPH and you're done.
The term Typical German Behavior is too funny - those guys are wound too tight
Re: AAR speedo [Re: Knillse] #2311559
05/26/17 02:55 PM
05/26/17 02:55 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Re: AAR speedo [Re: Morty426] #2311663
05/26/17 06:14 PM
05/26/17 06:14 PM
Pfalz
K
Knillse Offline OP
Knillse  Offline OP
K
Pfalz
Originally Posted By Morty426
....and you're done.
that would be too easy. Unfortunately the pre owner already switched the speedo pinion. I have no idea why. Means when I drive 120 km/h the speedo shows 120mph. When I understand the pinion tables and tire calculators correctly, I have to use a 39 teeth pinion to cover the complete mph range with my 120 mph instrument.
