Alternative headers for 2wd D-series small block. #1482558
08/10/13 09:32 PM
08/10/13 09:32 PM
Milwaukee, WI
Prince_Valiant Offline OP
Milwaukee, WI
Well, bit the bullet and went for it. Tried TTi headers on my Little Red Express.
Their A-body headers fit like a glove...better than the D-series headers I had on before! A LOT better
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph
1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD)
1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD)
1989 Shelby CSX #500/500
Re: Alternative headers for 2wd D-series small block. [Re: Prince_Valiant] #1482559
08/10/13 09:40 PM
08/10/13 09:40 PM
Milwaukee, WI
Milwaukee, WI
Driver side...
Re: Alternative headers for 2wd D-series small block. [Re: Prince_Valiant] #1482560
08/10/13 09:40 PM
08/10/13 09:40 PM
Milwaukee, WI
Milwaukee, WI
passenger side...
Re: Alternative headers for 2wd D-series small block. [Re: Prince_Valiant] #1482561
08/10/13 09:42 PM
08/10/13 09:42 PM
Milwaukee, WI
Milwaukee, WI
And of course, the best part is there are absolutely no leaks...quieter than even most cars I've seen with stock manifolds
Re: Alternative headers for 2wd D-series small block. [Re: Prince_Valiant] #1482562
08/10/13 10:14 PM
08/10/13 10:14 PM
Crockett ,TX
9
98RAM1500 Offline
98RAM1500  Offline
Crockett ,TX
looks good, clean installation
Re: Alternative headers for 2wd D-series small block. [Re: Prince_Valiant] #1482563
08/10/13 10:51 PM
08/10/13 10:51 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
sweet.
Re: Alternative headers for 2wd D-series small block. [Re: Golden-Arm] #1482564
08/10/13 11:29 PM
08/10/13 11:29 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
sweet.
Second that!
Re: Alternative headers for 2wd D-series small block. [Re: Golden-Arm] #1482565
08/10/13 11:30 PM
08/10/13 11:30 PM
Milwaukee, WI
Milwaukee, WI
Thanks...Jim at Kilpatrick's engine and trans (a mopar specialist) was pretty sure they'd fit since he's installed about a 1000 of 'em on cars (but never a D-series). They did great work; I was told it was a pretty straight forward installation too, far easier than most cars
My best personal installation was leak-free for ~ 3 months. After that, the "tick-tick-tick" header leaks returned inforce . This was with 1/4 inch thick flange hedman hedder's. I thought I could beat them .....
Better yet, for my application, it feels like more power too! I felt that the 408, 2.08/1.65 valved cnc'd eddy heads/roller cammed engine wanted more than basic 1 5/8th headers. While I wouldn't have minded 1/34 all the way, I actually think how mine is configured, it may make broader power w/ the stepped 1 5/8th-1 3/4 step than a basic 1 3/4 header, even if it gives up a little peak power.
Truth be told it could also be because of the new MSD ignition (replacing a mismatched stock unit that had a good ignition curve none-the-less) and the increased traction from the sure-grip diff too...all put together, this truck feels like a different animal. Will still spin them easily at 40mph
Re: Alternative headers for 2wd D-series small block. [Re: Prince_Valiant] #1482566
08/11/13 08:52 AM
08/11/13 08:52 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
passenger side...
I like the routing better there rather than D-Series headers.
Re: Alternative headers for 2wd D-series small block. [Re: redraptor] #1482567
08/11/13 01:41 PM
08/11/13 01:41 PM
HellsGate
outcast Offline
outcast  Offline
HellsGate
what year a-body headers did you use.
Re: Alternative headers for 2wd D-series small block. [Re: outcast] #1482568
08/11/13 02:43 PM
08/11/13 02:43 PM
Milwaukee, WI
Milwaukee, WI
I don't have the part# in front of me, but based on the price I paid, it looks like it's the 67-76, so the pretty basic/fit everything tti headers...lol, I guess they really do fit just about everything.
Re: Alternative headers for 2wd D-series small block. [Re: Prince_Valiant] #1482569
08/11/13 07:06 PM
08/11/13 07:06 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
The passenger side fits perfect with all manufacturers
The drivers side is always the problem
I used 1 7/8" Hookers for a E body & had to move one tube
Thanks for not being scared to try when a bunch of others said "You're better off using headers made for a truck"
I bet they tuck inside the frame for a cleaner fit too
Re: Alternative headers for 2wd D-series small block. [Re: Prince_Valiant] #2311541
05/26/17 02:37 PM
05/26/17 02:37 PM
Minnesota
1LilRed79 Offline
1LilRed79  Offline
Minnesota
Prince_Valiant,
I have a 1979 LilRed Express and want to know how the TTi headers worked for you. Do you remember which part number you used? Did you have any issues with the installation or make any modifications to either the headers or the truck?
Thanks!
1LilRed79
Re: Alternative headers for 2wd D-series small block. [Re: Prince_Valiant] #2311621
05/26/17 04:39 PM
05/26/17 04:39 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
I used TTI 360W5ED on my beater 78 Lil Red, got a year out of it before gasket leakage, perfect fit
My cousin useed TTI header # 340,on his 79 Lil Red , which from Prince_Valiant description I think there are the one's he used also.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Alternative headers for 2wd D-series small block. [Re: Prince_Valiant] #2474331
03/30/18 12:23 PM
03/30/18 12:23 PM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
interesting.. i happen to have a set of tti and dougs headers out in the shed for a 67-up abody.. just may have to try this with my LRE..
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: Alternative headers for 2wd D-series small block. [Re: abodyjoe] #2474341
03/30/18 12:52 PM
03/30/18 12:52 PM
Grove, OK
hosehead Offline
hosehead  Offline
Grove, OK
Yep! Me too! I'll be installing my tti's in my d100 once I do the cam swap! Thanks guys!
63 Plymouth savoy
65 d100
66 dart race project
58 plymouth suburban
Re: Alternative headers for 2wd D-series small block. [Re: Prince_Valiant] #2583723
11/27/18 03:41 PM
11/27/18 03:41 PM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
Doing a search on header availability and options for my customers 79 Lil Red Express and found this thread. So I guess TTi A-Body small block headers fit fine? Just want to make sure before I buy them.
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: Alternative headers for 2wd D-series small block. [Re: Prince_Valiant] #2583889
11/27/18 10:10 PM
11/27/18 10:10 PM
Central Florida
larrymopar360 Online content
Stud Muffin
larrymopar360  Online Content
Stud Muffin
Central Florida
I have TTI headers on my M body Police car and great fit and leak free for years now. Pay more up front, pays you back later. People wanted to poo-poo on me for spending that much on headers, but was well worth it.
Facts are stubborn things.
Re: Alternative headers for 2wd D-series small block. [Re: larrymopar360] #2584296
11/28/18 06:11 PM
11/28/18 06:11 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
The only people that would give a hard time for getting a good set of headers are those that have never had the pleasure of running a car with a cheap set installed and trying to maintain it.
Re: Alternative headers for 2wd D-series small block. [Re: mgoblue9798] #2584303
11/28/18 06:27 PM
11/28/18 06:27 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Probably so. There were a few people that did though.
