Page 2 of 3 1 2 3
Re: 70 340 4 bbl engine detail photos [Re: ScottSmith_Harms] #231149
02/21/09 04:02 PM
02/21/09 04:02 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Note that the unrestored engines pictured have black dipsticks.
Re: 70 340 4 bbl engine detail photos [Re: Alaskan_TA] #231150
02/21/09 04:07 PM
02/21/09 04:07 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Heres another unrestored 340 with a black dip stick handle.
Nice catch Barry !
Re: 70 340 4 bbl engine detail photos [Re: AdamR] #231151
02/21/09 06:11 PM
02/21/09 06:11 PM
Dallas, TX
70challrtse Offline
super gas
70challrtse  Offline
super gas
Dallas, TX
Let me try again. These are a few pics I took last year.
Re: 70 340 4 bbl engine detail photos [Re: 70challrtse] #231152
02/21/09 06:12 PM
02/21/09 06:12 PM
Dallas, TX
70challrtse Offline
super gas
70challrtse  Offline
super gas
Dallas, TX
Another.
Re: 70 340 4 bbl engine detail photos [Re: 70challrtse] #231153
02/21/09 06:14 PM
02/21/09 06:14 PM
Dallas, TX
70challrtse Offline
super gas
70challrtse  Offline
super gas
Dallas, TX
One more.
Re: 70 340 4 bbl engine detail photos [Re: 70challrtse] #231154
02/21/09 06:22 PM
02/21/09 06:22 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Common small block restoration errors also include the spark plug looms, they should not be painted.
Also, the negative battery cables were not attached to the engine when painted. (this is a big block only thing)
Re: 70 340 4 bbl engine detail photos [Re: Alaskan_TA] #231155
02/21/09 06:29 PM
02/21/09 06:29 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I agree with all of that Barry, however my mind is open for the possibility that some battery cables may have been painted with the engine. I haven't seen absalute proof yet but have seen some pretty convincing evidence. As common as they are you'd think the details of small blocks would be set in stone by now but it seems that allot of people are still pretty confused on what's correct or not, self included on some smaller details. Still learning,little things everytime I see a good survivor example.
Re: 70 340 4 bbl engine detail photos [Re: ScottSmith_Harms] #231156
02/21/09 06:38 PM
02/21/09 06:38 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
What about the fuel pump ? I believe they were installed on BBs, How about SBs ?
Re: 70 340 4 bbl engine detail photos [Re: ScottSmith_Harms] #231157
02/21/09 06:41 PM
02/21/09 06:41 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
And until we learn of a small block with an original painted battery cable, we have to say none are known.
I will also add that I usually only look at 1970 cars, so I have no clue if it changed later.
Re: 70 340 4 bbl engine detail photos [Re: Alaskan_TA] #231158
02/21/09 06:44 PM
02/21/09 06:44 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Original 1970 fuel pump;
Re: 70 340 4 bbl engine detail photos [Re: Alaskan_TA] #231159
02/21/09 06:47 PM
02/21/09 06:47 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Someone asked about the alternator as well;
Re: 70 340 4 bbl engine detail photos [Re: Alaskan_TA] #231160
02/21/09 07:05 PM
02/21/09 07:05 PM
MO
cdp Offline
cdp  Offline
MO
Mopar Action showed an untouched...I think late 71-up small block (as it was blue/turquise) that clearly had the neg. battery cable installed when painted and was laying across the valve cover when done.
This doesn't help, of course, on a 70. But never say never. It would be nice to see more untouched 69-72 340's documented for reference.
Re: 70 340 4 bbl engine detail photos [Re: cdp] #231161
02/21/09 07:09 PM
02/21/09 07:09 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
That's correct Barry, and I haven't seen a documented painted 70 cable either......Yet (just leaving the possibility open since I have seen later ones as noted above).
Here's one for you, what year do you think these valve covers came off of? That's original paint.
Re: 70 340 4 bbl engine detail photos [Re: ScottSmith_Harms] #231162
02/21/09 07:10 PM
02/21/09 07:10 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Another view
Re: 70 340 4 bbl engine detail photos [Re: ScottSmith_Harms] #231163
02/21/09 07:11 PM
02/21/09 07:11 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Inspection mark
Re: 70 340 4 bbl engine detail photos [Re: Alaskan_TA] #231164
02/21/09 07:15 PM
02/21/09 07:15 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
How about a list
intake - painted
Coil bracket
throttle bracket
clamp
return spring bracket
spring
auto trans return spring
temp sending unit
therm housing
Bypass hose - Painted
clamps - painted
Valve covers painted
bolts
grommets
PCV valve
Breather
oil cap
wire looms
Dip stick tube
Dip stick handle
Alt brackets
Spacer
bolts
Alt pulley
Fuel pump
Bolts
motor mounts
hardware
Battery cable
bolt
Oil press sending unit
Distributor clamp
bolt
Re: 70 340 4 bbl engine detail photos [Re: AdamR] #231165
02/21/09 08:51 PM
02/21/09 08:51 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
this is my I did learn LONG ago never say never on mopars
How about a list
intake - painted
Coil bracket - clear zinc
throttle bracket - engine color
clamp - clear zinc with a dark/black phosphate captive washer nut
return spring bracket - engine color
spring - depends on number of coils, and I'm not completly 100% convinced which one IS correct. I can say for 100% certainty a 1971 duster 318 2bbl with 3 spd trans it was yellow
auto trans return spring - see line above
temp sending unit- yellow zinc di-chromate
therm housing - engine color
Bypass hose - - engine color
clamps - - engine color
bolts - engine color
grommets- engine color
PCV valve- engine color
Breather - lower gloss black
oil cap - engine color
wire looms ?
Dip stick tube - engine color
Dip stick handle - on my own 1970 340 challenger it was still original paint - orange
Alt brackets - low gloss black
Spacer - dark phosphate
bolts -dark phosphate
Alt pulley - low gloss black
Fuel pump ?
Bolts - obviously phosphate if the pump is unpainted
motor mounts - low gloss black
hardware - phosphate
Battery cable . I removed the original from my brothers 41K mile 1971 duster 318 and it was definitly engine color at the cyl head end ( blue btw )
bolt - see above
Oil press sending unit - yellow zinc di-chromate
Distributor clamp - Plated in ??????
bolt - same 1971 duster the bolt was yellow zinc with a captive washer
Re: 70 340 4 bbl engine detail photos [Re: AdamR] #231166
02/21/09 08:54 PM
02/21/09 08:54 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
70 340. Taken before I got the correct hoses and PVC from Scott or was that Bill? Fuel line is incorrect from filter to carb. What else?
Re: 70 340 4 bbl engine detail photos [Re: Steve340] #231167
02/21/09 08:56 PM
02/21/09 08:56 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
another
Re: 70 340 4 bbl engine detail photos [Re: Steve340] #231168
02/21/09 08:59 PM
02/21/09 08:59 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
another1
Page 2 of 3 1 2 3
