Forged Crankshaft 70 440-6 ? #231085
02/21/09 05:51 AM
02/21/09 05:51 AM
Sweden
6pakdude Offline OP
6pakdude  Offline OP
Sweden
Have a forged crankshaft in my 70 440 engine.
Crank stamped "Sabatine 11-76" no chrysler part# on the crank.
Anybody know what Crank I have, DC crank or?
Ust curious what crank I have in my engine.
Thanks Peter
calmas@comhem.se
Re: Forged Crankshaft 70 440-6 ? [Re: 6pakdude] #231086
02/21/09 06:26 AM
02/21/09 06:26 AM
Gateway to the West.
hemi_harvester Offline
I would guess its from an engine rebuilder but thats just a guess
is it still std ?
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
Re: Forged Crankshaft 70 440-6 ? [Re: hemi_harvester] #231087
02/21/09 07:51 AM
02/21/09 07:51 AM
Sweden
6pakdude Offline OP
6pakdude  Offline OP
Sweden
It was 010" on both rod and main bearings. Now after the rebuild it is 020" on both.
The org match block that was std bore before, now 030" is stamped with an "A" on the oilpan/block surface both sides.
Also an "A" and a maltese coss on engine pad.
Peter
Re: Forged Crankshaft 70 440-6 ? [Re: 6pakdude] #231088
02/21/09 09:41 PM
02/21/09 09:41 PM
Minn
SportF Offline
SportF  Offline
Minn
I think that Maltese cross refers to factory undersize main or mains. It might be the rods too, but from like 35 years ago with a 63 Dodge that's what it meant. One or more bearings might be like .001 under. Since it has been rebuilt, that won't make any difference now.
Re: Forged Crankshaft 70 440-6 ? [Re: SportF] #231089
02/21/09 09:48 PM
02/21/09 09:48 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: Forged Crankshaft 70 440-6 ? [Re: SportF] #231090
02/21/09 09:49 PM
02/21/09 09:49 PM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
From my Factory Service Manual:
Re: Forged Crankshaft 70 440-6 ? [Re: vdriver] #231091
02/21/09 09:59 PM
02/21/09 09:59 PM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
Also:
Re: Forged Crankshaft 70 440-6 ? [Re: vdriver] #231092
02/22/09 05:41 AM
02/22/09 05:41 AM
Sweden
6pakdude Offline OP
6pakdude  Offline OP
Sweden
Thanks for the replys,since the crank was turned 010" undersize on both rod and main by previous owner in PA, USA late 80th's, this crank must have been std before that. So somebody had it replaced earlier than that???? 1976?
So why was the stock crank 001" undersize, because of some damage to the crank at assembly at the factory?
Or was it extra bearing clearence with a 70 440 sixpack.
And finally the block was std bore not 020" over that the stamped A indicate.
Thanks Peter
