Re: pro tree bypass wiring for reverse
[Re: dartman366]
#2310206
05/24/17 09:21 AM
05/24/17 09:21 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
On a 3 prong switch the middle terminal is the ground for the starter relay. The outer 2 are for reverse lights. So bring power to 1 terminal and the other goes to your trans brake wire. So when you put it into reverse it activates the trans brake.!!!! You can not do it if is a clean neutral valve body.
JAKES AUTOMOTIVE
[Re: JAKE68]
#2310216
05/24/17 09:44 AM
05/24/17 09:44 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
On a 3 prong switch the middle terminal is the ground for the starter relay. The outer 2 are for reverse lights. So bring power to 1 terminal and the other goes to your trans brake wire. So when you put it into reverse it activates the trans brake.!!!! You can not do it if is a clean neutral valve body. this is how i did mine and never had a prob in the 2 years i had the TB,mabey only 100 passes but used reverse alot.
[Re: bonefish]
#2310608
05/24/17 09:52 PM
05/24/17 09:52 PM
dartman366
Mt. Vernon, Ohio
On a 3 prong switch the middle terminal is the ground for the starter relay. The outer 2 are for reverse lights. So bring power to 1 terminal and the other goes to your trans brake wire. So when you put it into reverse it activates the trans brake.!!!! You can not do it if is a clean neutral valve body. this is how i did mine and never had a prob in the 2 years i had the TB,mabey only 100 passes but used reverse alot. Ok thanks guys, this sounds like the way I am going to do it but one last question, by activating the transbrake this way how does that affect the delay box by back feeding the 12 volt power.
[Re: dartman366]
#2310623
05/24/17 10:09 PM
05/24/17 10:09 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
Not trying to be negative , but what's the big deal about holding in a button on your wheel when backing up. Your hand( hands are on the wheel anyhow) guess I don't understand the issue.
[Re: B3422W5]
#2310634
05/24/17 10:31 PM
05/24/17 10:31 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
Not trying to be negative , but what's the big deal about holding in a button on your wheel when backing up. Your hand( hands are on the wheel anyhow) guess I don't understand the issue. nothin if you only back straight up.
[Re: B3422W5]
#2310637
05/24/17 10:38 PM
05/24/17 10:38 PM
dartman366
Mt. Vernon, Ohio
because I am old fat and lazy,,,,it is a bit of a pain trying to back out away from the trailer turn the wheel while trying to pay attention to other cars and people and not take your thumb off the button while criss crossing your arms,, some one said to add a bunch of delay in the box, then I would just forget to take it out and sit on the line waiting to launch for 3 minutes all the while thinking to myself gawd I hope Don don't find out about this. LOL!!
[Re: bonefish]
#2310638
05/24/17 10:38 PM
05/24/17 10:38 PM
B3422W5
Portage,michigan
Not trying to be negative , but what's the big deal about holding in a button on your wheel when backing up. Your hand( hands are on the wheel anyhow) guess I don't understand the issue. nothin if you only back straight up. And with a dedicated race only car, that's about all you would need to back up for, is out of the trailer or off the starting line if somebody broke.......or put the button on a detachable cord so you have better control if you have to saw the wheel
[Re: B3422W5]
#2310734
05/25/17 02:27 AM
05/25/17 02:27 AM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
Not trying to be negative , but what's the big deal about holding in a button on your wheel when backing up. Your hand( hands are on the wheel anyhow) guess I don't understand the issue. nothin if you only back straight up. And with a dedicated race only car, that's about all you would need to back up for, is out of the trailer or off the starting line if somebody broke.......or put the button on a detachable cord so you have better control if you have to saw the wheel Absolute pain in the butt with button on the steering wheel Had a car in my barn for a while and moved it around while working on it.Trying to turn it hand over hand you have to let go bumping in and out of reverse.much prefer the Terminator style buttons.
Founder and CEO of the Central Valley Mopar Drag Pack
