Hellcat legal for FS/D NHRA stock eliminator? #2310582
05/24/17 09:15 PM
05/24/17 09:15 PM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
I heard that as of the 17th of this month a showroom Challenger Hellcat would be legal for stock eliminator under FS/D with a 10.60 index.
Anyone have anymore info...?
Re: Hellcat legal for FS/D NHRA stock eliminator? [Re: Forest] #2310602
05/24/17 09:47 PM
05/24/17 09:47 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
That index will need adjusted pretty early lol
Re: Hellcat legal for FS/D NHRA stock eliminator? [Re: Forest] #2310672
05/24/17 11:57 PM
05/24/17 11:57 PM
Loganville, GA
Stewart Offline
Stewart  Offline
Loganville, GA
NHRA doesn't adjust the indexes in most S and SS classes. They will add HP and the HCat will go to FS/C then B, then A. The same as happened to the 5.7 Dragpak. It is up several classes. At 600hp and 7.5 lb/hp that's a heavy car at 4500 plus 170 for driver if I read everything right.
Strange thing to me is NHRA has the HCat listed for the 2015 Chally too. Maybe the 2016 too, I didn't check that year.
Re: Hellcat legal for FS/D NHRA stock eliminator? [Re: Forest] #2310683
05/25/17 12:17 AM
05/25/17 12:17 AM
Renton Washington
Triple Threat Offline
Renton Washington
Yep it's true, it was added to the classification guides.
600hp and 4500# I believe. It is not a favorable combo compared to the normal drag pak stuff.
There is a thread on class racer about it
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Hellcat legal for FS/D NHRA stock eliminator? [Re: Forest] #2310695
05/25/17 12:32 AM
05/25/17 12:32 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
That weight and hp is hard on a 9 inch slick. I was at the Dinwidde divisional and saw many of the high hp cars just blow the tires clean off, very fine line to hook or not. Of course with the blower, one could be soft at the line then book out the back door, unlike the NA cars.
Re: Hellcat legal for FS/D NHRA stock eliminator? [Re: Triple Threat] #2310719
05/25/17 01:36 AM
05/25/17 01:36 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
quickly becoming one of "them" I see.... laugh2
Re: Hellcat legal for FS/D NHRA stock eliminator? [Re: Forest] #2310743
05/25/17 03:14 AM
05/25/17 03:14 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
http://classracer.com/classforum/showthread.php?t=66331
Looks like a regular Stock/SS car based on a production car, not a Drag Pack type Challenger. The DP is about 1000 pounds lighter. Not sure how they came up with the 600 HP rating. Lot's of chatter on that. The classification guide lists it as the Hellcat.
Floyd Lippencott IV
Re: Hellcat legal for FS/D NHRA stock eliminator? [Re: Forest] #2310822
05/25/17 10:47 AM
05/25/17 10:47 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I look at these blower cars (Ford-Chevy-Dodge) as the same as athletes on steroids, cheating in a way. Too easy to turn the wick up. Cool, but how can it be fair to the NA cars. Put them in their own class with the correct hp and no soft index( at the least 1/2 second faster) so they don't make up the top ten qualifiers at each race. Doesn't matter what class they run if the index is right.
