VInyl top woes: Why I'm replacing the top half my 68 B Body #2309955
05/23/17 07:09 PM
05/23/17 07:09 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Basically, I've got a rotten rear window area from a vinyl top. I pulled the top off and surveyed the damage. I wan't to do as little fab work as I can, and I'm already budgeting a new roof skin. I've got the following problems:
THE BAD
Roof skin needs replacement (pinholes and previous bondo repairs) There is no getting around this. I'm happy the roof is available new.
Rear window frame is rusty at the lip, filler pannel is full of bondo and extensions leading to the trunk have body filler.
Lower portion of the A pillars has rust and is shot.
The rivets for the vinyl top rusted out. Area above the quarter is rusty. The C pillar below the roof skin and up to the edge of the window on the bottom is bad.
The good:
The car has been sealed with a cruddy enamel paint job for years.
Engine bay is rust free as well as fenders and its painted.
Trunk floor is new.
Rockers were replaced years ago.
Floor panels are new.
No frame rot.
Rear quarter skins are new from several years ago. Goodmark pieces.
Bottom of front windshield frame is rust free. Cowl has no rot.
Everywhere that there is a hole, was full of body filler. I knew that the car had bondo, and that there was rust under the top but this was overdone.
It looked pretty until I started poking holes in it. I'm going to strip back all around to fresh metal. Once I get all the parts, I'm going to find a shop that only wants to do the top half of the car and do a basic paint job.
Can someone here post their experiences with these replacement panels?
I'm looking at buying the following to address the top.
Roof Skin
Pair of Drip Rails
Deck filler panel
Deck filler support
Deck Filler Patch Set
Lower rear window frame
Currently searching for salvaged A Pillars and lower C pillar sections. This and the new AMD stuff will get me 90% of the rotten metal fixed.
Any experience is appreciated.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: VInyl top woes: Why I'm replacing the top half my 68 B Body [Re: AlexP] #2309988
05/23/17 08:33 PM
05/23/17 08:33 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
If that's an amd dutchman/deck filler panel, they fit worse than the cheap bare metal Taiwan made ones... Honestly I think you would be better off finding a used roof that was cut down past the quarter seam and with a pillars cut down into the cowl. I worked on a car that had an amd roof skin put on, it was really flimsy vs oem sheetmetal. I'd even consider buying full quarters to at least to get the upper area to roof and rear corner. That's honestly probably the most rusted I ever saw b-body roof/pillars and I live in sw PA where they rot in half.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: VInyl top woes: Why I'm replacing the top half my 68 B Body [Re: AlexP] #2309991
05/23/17 08:43 PM
05/23/17 08:43 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
i agree with Joe
2 votes for a real roof
especially if you plan on keeping the car.
you might even be getting into the speaker tray or the ends of it
once you dig it apart.
also get a goodmark dutchman panel
it fits better then AMD and looks more to original
the AMD panel has a extra bump that gives it away
if you have a clue about what you are looking at..
Re: VInyl top woes: Why I'm replacing the top half my 68 B Body [Re: AlexP] #2310003
05/23/17 09:20 PM
05/23/17 09:20 PM
KY
65pacecar Online happy
65pacecar  Online Happy
KY
I was just in Desert Valley and they had a nice solid 68 Satellite that would be a great donor for that issue.
Re: VInyl top woes: Why I'm replacing the top half my 68 B Body [Re: 65pacecar] #2310457
05/24/17 05:13 PM
05/24/17 05:13 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I called them first, and they didnt have it any longer.
I'm talking to a place called wild cat in oregon.
They had a front cowl set up and a rear window section.
Re: VInyl top woes: Why I'm replacing the top half my 68 B Body [Re: AlexP] #2310518
05/24/17 06:46 PM
05/24/17 06:46 PM
KY
KY
I was looking for 65 Fury stuff, but the Satellite was a pretty new arrival and there was a guy hovering around it, must have made a deal on it.
Wildcat in Oregon is good to deal with too. Did you try Texas Acres (If they are still in business), they are expensive but the shipping cost would be much better.
Re: VInyl top woes: Why I'm replacing the top half my 68 B Body [Re: AlexP] #2310589
05/24/17 09:31 PM
05/24/17 09:31 PM
GMP440 Offline
GMP440  Offline
I just finished doing metal work on the right and left
lower window patches. I used the large , lower corner patches you pictured. The work came out great. The mouldings even fit
the round corners very well. This was on my 68 Coronet.
If only the front part of your dutchman is rotted use the front
piece that is pictured or if everything is rotted get the roof and all the other pieces you have pictured.
Here is a link to a thread on this kind of repair on "For Bbodies only".
Look for the postings by GMP440; that's me. It shows pics of the lower corner repairs.
http://www.forbbodiesonly.com/moparforum/threads/69-rr-b-body-rear-window-corner-repair.119437/
Re: VInyl top woes: Why I'm replacing the top half my 68 B Body [Re: AlexP] #2310761
05/25/17 05:12 AM
05/25/17 05:12 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Look up Clay Kossuth in Catawissa Missouri. All mopar junkyard outside of St. Louis.
Re: VInyl top woes: Why I'm replacing the top half my 68 B Body [Re: 68KillerBee] #2311074
05/25/17 05:47 PM
05/25/17 05:47 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I just gave him a call. I'm hoping he has what I need. If I can get a front cowl, I'll be in good shape.
I also went ahead and bought the Goodmark Filler panel for the rear. Next up is quarters and a roof skin.
If I don't find a rust free top by the end of next week, I'll buy the aftermarket stuff.
Re: VInyl top woes: Why I'm replacing the top half my 68 B Body [Re: AlexP] #2311222
05/25/17 10:42 PM
05/25/17 10:42 PM
GMP440 Offline
GMP440  Offline
A friend of mine bought the AMD complete roof panel for his 69 Superbee.
The job came out perfect. Looks great.
Re: VInyl top woes: Why I'm replacing the top half my 68 B Body [Re: Silver70] #2311276
05/26/17 12:09 AM
05/26/17 12:09 AM
St. Croix, US Virgin Islands
David_in_St_Croi Offline
Wait until I start posting what I need to do metal work wise. I need similar parts but not roof (I hope)so interested in seeing any pictures of how this lower roof, window, deck filler panel, quarter panel goes together. If you replace th quarter panel and the deck filler panel do you need that outer patch panel or just the inner one?
I hope you are planning on not replacing the vinyl top.... Cars down here rust from the top down, and anything with a vinyl roof it is as if you added an accelerator to the process.
https://www.facebook.com/THENEWCDRA
Proud member of the liberal scientific elite
Re: VInyl top woes: Why I'm replacing the top half my 68 B Body [Re: David_in_St_Croi] #2311358
05/26/17 02:39 AM
05/26/17 02:39 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Look at my thread in the members projects, did a full roof/cowl, quarters etc, but not because of rust... the roof sections like this one needs really isn't that hard to do.
If he goes aftermarket full quarters, he'll still need the smaller inner corners, although I prefer to make my own... they didn't used to have the right bend when I tried them years ago.
Re: VInyl top woes: Why I'm replacing the top half my 68 B Body [Re: AlexP] #2311377
05/26/17 04:17 AM
05/26/17 04:17 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Putting a vinyl top back on isn't a terrible thing if you do it right. AKA, not how the factory did it. But you also wont need to explain that your car isn't a convertible even though it has a "rag top".
I say that bc of a guy in a junkyard telling us he has a 69 coronet ragtop he's selling, then you tell your uncle and he pulls up to find a 69 coronet 4 door with a vinyl top lol.
Re: VInyl top woes: Why I'm replacing the top half my 68 B Body [Re: AlexP] #2311650
05/26/17 05:48 PM
05/26/17 05:48 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Big Job, Alex. Good luck to you.
My junker needs some of the same, hopefully won't be long now.
Rich H.
Esse Quam Videri
Re: VInyl top woes: Why I'm replacing the top half my 68 B Body [Re: AlexP] #2312557
05/28/17 07:31 PM
05/28/17 07:31 PM
GMP440 Offline
GMP440  Offline
Take a look at this thread from B Bodies Only. This person did the full roof replacement and lower window corner replacement.
The roof and corner work starts at bottom of page 3.
http://www.forbbodiesonly.com/moparforum/threads/1969-gtx-the-t-stands-for-tetanus.111018/page-3
Re: VInyl top woes: Why I'm replacing the top half my 68 B Body [Re: GMP440] #2312599
05/28/17 09:11 PM
05/28/17 09:11 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I know a guy who just had to replace the roof on a GTO with a new AMD roof because the guy who installed it many years ago trimmed the edges of the top with a utility knife and cut into the new paint job underneath. Water held in place by the top crept inside the cut and the rust quietly took over.
Many cars rust out because the factory didn't put much, if any, paint on the roofs of cars destined for a vinyl top. My Dart had super thin primer dusting on the roof only. I was tickled to death it wasn't rusty as it sure could have been.
If you have the roof painted with a nice epoxy primer and paint then a new top is nothing to worry about. They also made these cars with two-tone painted roofs so you could paint the roof white or black and put the vinyl top moldings back on and still call it "factory".
Make sure to protect the glass from any grinding sparks if you do the work yourself.
Re: VInyl top woes: Why I'm replacing the top half my 68 B Body [Re: AlexP] #2312722
05/29/17 12:56 AM
05/29/17 12:56 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I found a parts car with a roof in great shape that I've purchased. Completely random and it will give me most of the parts I need in one panel.
I'll get the whole cowl with a rust free front window channel, a pillars with far less rust than mind, a spot less roof (not a vinyl top car) and a rear window channnel with only the typical corner rust.
I'm really lucky. Pictures to come soon.
Re: VInyl top woes: Why I'm replacing the top half my 68 B Body [Re: AlexP] #2312898
05/29/17 12:16 PM
05/29/17 12:16 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
that is the best way to go!
the extra time it takes to harvest and prep
will give you a much better job in the end! twocents
Re: VInyl top woes: Why I'm replacing the top half my 68 B Body [Re: AlexP] #2314259
05/31/17 06:07 PM
05/31/17 06:07 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
With the help of Moparts, I've found the parts to fix my car.
It's a basket case 70 Roadrunner 383/4speed car that was in a flood up to before the roof. Frame and floor pans are gone, bottom of the car is caving in on itself and it's breaking under it's own weight.
But the roof and front/rear windows are in good shape. I'm sectioning off the top in one very generous piece and grafting the roof panel onto my car, while the rest will be use as patch panels in conjunction with some new repro metal where needed.
Re: VInyl top woes: Why I'm replacing the top half my 68 B Body [Re: AlexP] #2314335
05/31/17 10:11 PM
05/31/17 10:11 PM
Ohio
lockjaw-express Offline
Ohio
Looking at the condition of that car makes me want to cry😭
The roof looks like it would work out for you...my '68 Super Bee, was rough, but AMD replaced the left and right rear quarter panels, the front floor and trunk pan.
You might be asle to see if the have any blemish/ruined panels you might be able to salvage some of the lower roof pieces.
Good luck with your project!
