4.250 Crank in "X" Block #2310281
05/24/17 11:53 AM
05/24/17 11:53 AM
Alexandria, LA
Blucuda413 Offline OP
Alexandria, LA
What problems can I anticipate in using a 4.250 crank in an LA style block. I'm using steel rods, rear sump (no pickup tube issue), and block has been clearanced for 4" stroke with alum rods. Any issues???? Thanks, Max
Re: 4.250 Crank in "X" Block [Re: Blucuda413] #2310303
05/24/17 12:31 PM
05/24/17 12:31 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
My BPE 4.250 fit My X block with minimum grinding.
On My Molnar 4.125 I had to turn the counter weights to clear the oil pump in my R-3 block.
Re: 4.250 Crank in "X" Block [Re: Blucuda413] #2310815
05/25/17 10:43 AM
05/25/17 10:43 AM
Alexandria, LA
Alexandria, LA
Thanks, that's what I hoped would be the answer. Max
Re: 4.250 Crank in "X" Block [Re: Blucuda413] #2311379
05/26/17 04:31 AM
05/26/17 04:31 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
My BPE 4.250 crank fit a production 360 block with very small notches on the bottom of each cylinder. Crank has 2" journals. I am sure a 4.500 stroke crank could be fit into a stock block.
Re: 4.250 Crank in "X" Block [Re: Blucuda413] #2311578
05/26/17 03:10 PM
05/26/17 03:10 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Do they make good power with the over square bore-stroke?
Re: 4.250 Crank in "X" Block [Re: Blucuda413] #2311801
05/26/17 11:22 PM
05/26/17 11:22 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Mine made 778 at 6100 with a very mild roller and 360-1 neads
