New thread for my 37
#2310094
05/24/17 12:03 AM
05/24/17 12:03 AM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
I starting a new thread on my 37 Plymouth pickup and its transformation from marginally driveable with a 289/C4 to a 6.4 Hemi/545RFE/4.10 Dana 60 monster.
Today I dropped it off for getting a 4 inch mini-tubs in the bed so the bed is even with the frame rails so I can fit these 295/50/15s on 10 inch wheels under the truck. The next step will be to order a narrowed Dana 60 with 4.10 gears so we can do the 4 link rear.
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
Re: New thread for my 37
[Re: AZ_A12_BEE]
#2310100
05/24/17 12:10 AM
05/24/17 12:10 AM
moparpollack
Lil Herman
Lil Herman
85086
This should be good.
[Re: AZ_A12_BEE]
#2310124
05/24/17 12:37 AM
05/24/17 12:37 AM
AZ_A12_BEE
Dreaming of the 808
What do you guys think of these brakes for the rear?
37 Plymouth PU
[Re: AZ_A12_BEE]
#2310236
05/24/17 10:18 AM
05/24/17 10:18 AM
Posts: 1,510 AZ
Mike P
AZ
Those tires are going to look great under there. "........4 inch mini-tubs in the bed so the bed is even with the frame rails so I can fit these 295/50/15s on 10 inch wheels under the truck....." Yeah , I had to go look under the back end of mine. That would be a fairly easy job to pick up a bunch of tire clearance. Those brakes should be plenty for the truck.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
[Re: AZ_A12_BEE]
#2310370
05/24/17 02:29 PM
05/24/17 02:29 PM
Posts: 26 VA
41MoChev
VA
Looks like it will be awesome. Tires & brakes look perfect and swapping out the old Ford 289 for a 6.4 Hemi is a big plus! Good luck with the build.
Building '41 Chevy street rod with Mopar LA power. I tell my Chevy buddies it's on the Chevrolet improvement Program.
[Re: Mike P]
#2310397
05/24/17 03:13 PM
05/24/17 03:13 PM
AZ_A12_BEE
Dreaming of the 808
Those tires are going to look great under there. "........4 inch mini-tubs in the bed so the bed is even with the frame rails so I can fit these 295/50/15s on 10 inch wheels under the truck....." Yeah , I had to go look under the back end of mine. That would be a fairly easy job to pick up a bunch of tire clearance. Those brakes should be plenty for the truck. Milke, I don't think you can find a much easier vehicle to mini tub
37 Plymouth PU
[Re: 41MoChev]
#2310399
05/24/17 03:15 PM
05/24/17 03:15 PM
AZ_A12_BEE
Dreaming of the 808
Looks like it will be awesome. Tires & brakes look perfect and swapping out the old Ford 289 for a 6.4 Hemi is a big plus! Good luck with the build. I got the crate Hemi about 6 months ago, hope it's sitting in the truck by August
37 Plymouth PU
[Re: AZ_A12_BEE]
#2310408
05/24/17 03:30 PM
05/24/17 03:30 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Regarding the rear brakes, let whom ever is building your Dana know what brakes you wan to run so they can use the correct housing ends and axle offsets.
As for how they work, well got a 98 Exploder with those brakes and they seem to work fine.
[Re: Supercuda]
#2310559
05/24/17 08:35 PM
05/24/17 08:35 PM
AZ_A12_BEE
Dreaming of the 808
Definately will let the rear end builder know, I need just a bare housing with axles to do the 4 link, then I will have it all powdercoated before it gets gears
37 Plymouth PU
[Re: RodStRace]
#2311874
05/27/17 02:41 AM
05/27/17 02:41 AM
AZ_A12_BEE
Dreaming of the 808
John, I already own the crate 6.4 and 545RFE
37 Plymouth PU
[Re: AZ_A12_BEE]
#2313244
05/29/17 09:48 PM
05/29/17 09:48 PM
Posts: 7,506 Az
Crizila
Az
Definately will let the rear end builder know, I need just a bare housing with axles to do the 4 link, then I will have it all powdercoated before it gets gears Angled 4 link or straight with a pan hard bar?
Fastest 300
[Re: Crizila]
#2314806
06/01/17 09:28 PM
06/01/17 09:28 PM
AZ_A12_BEE
Dreaming of the 808
Definately will let the rear end builder know, I need just a bare housing with axles to do the 4 link, then I will have it all powdercoated before it gets gears Angled 4 link or straight with a pan hard bar? I haven't decided yet
37 Plymouth PU
[Re: AZ_A12_BEE]
#2315234
06/02/17 06:43 PM
06/02/17 06:43 PM
AZ_A12_BEE
Dreaming of the 808
Picked up this Dana 60 today for $100 to be narrowed, it's pretty clean, came out of a 73 Ford F-250
37 Plymouth PU
[Re: AZ_A12_BEE]
#2315242
06/02/17 06:53 PM
06/02/17 06:53 PM
AZ_A12_BEE
Dreaming of the 808
Mini-tub progress, it's looking great
37 Plymouth PU
